05-05-2005, 07:57 AM | #1 |
help on turbo timer install!!
ok i just bought a blitz DCII turbo timer....and i dint know that i needed to buy a harness so i ordered that and i got it all here...i hooked most of it up just need to find.....12V wire under the steering wheel to splice into..and a ignition wire to hook it up to....so if anyone knows what they may look like help me out...(tell me if its green with a yellow line or what not)
then i have that vacumm line that i need to hook up for boost reads..they say it goes to the throttle body but where..there is a spot on the lower left hand side that i can use but is that correct...please help |
05-05-2005, 11:33 AM | #2 |
I'm going off a S13 wire diagram.
B/R- ign 12v B/W - 12v constant As for the boost hose, tap it off you wastegate. You need a t- tap hose connector. Does the kit you bought have the connectors and the manual>? Anyway, it should be straight forward from there.
I'm driving fast -drew |
