Old 06-16-2010, 09:49 AM   #1
badwolf4822
badwolf4822's Avatar
badwolf4822 is an unknown quantity at this point
1974 260z $3000
this is a 1974 260z with a 240z L24 engine and a 280z 5speed transmission
full cage, sparco quick disconnect steering wheel, battery relocated to the back
fully adjustable suspension including coil-overs, sway-bars, tie-rods, end-links, and more
the car is a little over an inch off the ground at the frame rails
all wheels disc conversion, longer studs, brand new wheels and tires
exhaust is header to cherry bomb to man pipe (sticking about 1 1/2 feet out the back of the car
car has some rust, previous owner did some riveted panels on the floor and there is some in the corners like before the back wheels
worst part is the dent in the passenger side rear corner, could probably be pulled but I just dont have the time or $ right now
coil-overs are apex miata coil-overs modified by partshop max to work on a Z
badwolf4822 is offline
Old 06-16-2010, 12:04 PM   #2
mrmephistopheles
mrmephistopheles's Avatar
I said in your last thread, quite clearly, to try again in a WEEK.
Now you're out of the marketplace for 3 weeks.
This is what ignoring moderation staff gets you.
Originally Posted by PHLIP
mrmephistopheles is offline
240z, cage, datsun, slammed, wheels
