Old 03-27-2017, 09:29 AM   #3751
travon47
travon47 is an unknown quantity at this point
Originally Posted by 2bar_silvia View Post
Here's mine. 18x9.5 +15 with 265/35/18 for the fronts and 18x10.5 +18 with 315/30/18 for the rears. Tires are Toyo R888's.
I have yet to see your car around (grew up in Rogers) Looking forward to checking it out sometime. Looks great!
travon47 is offline   Reply With Quote
Old 03-27-2017, 09:32 AM   #3752
600supersport
600supersport's Avatar
600supersport is an unknown quantity at this point
Maximum TIRE(Rubber) fitment thread
Very nice, I didn't know they were making those and I got these a while ago so maybe they weren't available then anyway, idk. I would have had a harder time justifying cutting up the HLSD stubs unless I found a set without the diff included.
600supersport is offline   Reply With Quote
Old 03-27-2017, 09:43 AM   #3753
travon47
Makes sense, yeah they haven't been doing them as long as the adaptors that is forsure.
Here you go bud!
https://www.z1motorsports.com/rear-d...le-p-9926.html
Old 03-27-2017, 10:40 AM   #3754
jr_ss
Originally Posted by travon47 View Post
Never seen a wheel run into the rlca , mine use to hit my coilover when it would gain camber when it pushed up. Plus how his rlca is adjustable (knuckle side) it pushes the wheel away from where it could possibly hit it, it will probably hit the coilover first since that is fixed the knuckle.
The inner wheel hits the LCA on the front side, usually having the factory arms is the culprit. Plenty of people have had to notch theirs to fit 11" plus wheels with enough offset to not mess with factory sheet metal.
Old 03-27-2017, 11:33 AM   #3755
travon47
Ah word, yeah the camber I had probably helped out to clear the rlca but aided in rubbing on the coilover
Old 03-27-2017, 11:36 AM   #3756
600supersport
Here you go bud!
Thanks buddy
Old 03-30-2017, 09:28 PM   #3757
600supersport
I measured the clearances today and have just over 1" between both the springs & LCAs to the wheel/tire so if I got really ambitious (which I won't), I could squeeze in 335s on 18x11.5 +25 just fine or 18x12 +30 would juuuust squeeze in there, but I wouldn't recommend that.
Leaving a bit of room for suspension travel and things flexing a bit under load, it's probably not wise to go much closer than a 1/2" gap. However, it is possible.
Old 05-20-2017, 10:55 PM   #3758
Thatfast240
Thatfast240 has a spectacular aura aboutThatfast240 has a spectacular aura aboutThatfast240 has a spectacular aura aboutThatfast240 has a spectacular aura aboutThatfast240 has a spectacular aura aboutThatfast240 has a spectacular aura aboutThatfast240 has a spectacular aura about
My setup, nothing crazy
295's on rear 265's up front
Thatfast240 is offline   Reply With Quote
Old 05-24-2017, 12:09 PM   #3759
stockbee
stockbee's Avatar
stockbee is an unknown quantity at this point
Send a message via AIM to stockbee
That looks sick. What's the offset on the wheels up front and out back?
stockbee is offline   Reply With Quote
Old 05-24-2017, 12:11 PM   #3760
bshotts
bshotts's Avatar
bshotts is making a name for him/her selfbshotts is making a name for him/her self
Send a message via AIM to bshotts
That is indeed, extremely sick, and should be checked by a medical professional. I second the motion for offset info sir!!
Quote of the year?
Originally Posted by projectRDM View Post
Zoom in a little more, it's not blurry enough.
bshotts is offline   Reply With Quote
Old 05-25-2017, 08:06 PM   #3761
Thatfast240
Thanks guys!
Rears 18x9.5 +30
Fronts 18x8.5 +25
Old 05-31-2017, 04:18 PM   #3762
Black R
Black R's Avatar
Black R is an unknown quantity at this point
Hi guys,
I'm back again - this time with 335/30/18 hoosiers on 18x12's.
I'm really posting just to keep notes of my changes, but also so that others may benefit.
Rear is pretty easy - 50mm rear overfenders bowed to about 80mm and about 2 deg of camber. Total offset of +13.
I think +10 or zero offset would be ideal here - for just a little extra clearance inboard for if you want to run a bit more camber.
Front is a LOT more work - depending on how much you want to bring the wheels inboard.
If you just want to use spacers and that's it, then you have to cut like crazy and offset ends up being -18 (yes negative 18).
The other option is to extend the ears on the front lower coilover mount a couple of inches, and move the upper coilover mount inboard a bit also.
This is more invasive, but doable, and is common among the SM autox 240's.
I will likely end up going this route in the future...
Again, this is assuming you are trying to run 335's and 18x12 wheels at all four corners.
My car is at the fabricators shop right now getting tubes up front because it fouls too hard in the wheelwell even after cutting what I could.
I'm using kts coilovers, and I believe the springs are 60mm diameter.
* I have the car as low as it will go (even removed both lower collars in the front), so that I can make sure I get all the clearances sorted.
ymmv.
S13 XE coupe: Aristo GTE, R154, GT37, Defsport Wilwood kit, KTS coilovers
Black R is offline   Reply With Quote
Old 06-03-2017, 07:49 PM   #3763
Pblesh85
Pblesh85's Avatar
Trader Rating: (48)
Pblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of light
Feedback Score: 48 reviews
Originally Posted by 1988montecarloss View Post
I know it's not max tire possible but is still more than most people on this site run so figured this would be the place to look, anyone have pics of an s13 coupe on 17x9 with 235/40 and 17x10 with 255/40 that sits actually low? This is the best pic I could find but would like to see more up close ones if possible
image hosting
Look at my build thread, same tire sizes.
If you want pm me and I can text some pics. I'm going through a fitment experiment right now.
Do you suffer from vaginal dryness...
Pblesh85 is offline   Reply With Quote
Old 06-30-2017, 08:14 PM   #3764
S14AZ
S14AZ's Avatar
S14AZ is an unknown quantity at this point
2" megan racing "gay springs I know...supported with AGX adjustables"
Anyways front 2004 350z wheels 18x8 225/40/18 and 255/40/18 rear fenders rolled .
Sent from my SM-J700T using Tapatalk
S14AZ is offline   Reply With Quote
Old 06-30-2017, 08:17 PM   #3765
S14AZ
S14AZ's Avatar
Also 1.2 camber in rear . Adjustable camber and toe arms of course.
Old 07-21-2017, 12:41 PM   #3766
whosawmike
whosawmike is an unknown quantity at this point
Hey Guys... First off, Please forgive my newbishness. This is going to be my first go at wheel fitment.
I have a BONE stock S13 Silvia. I am looking at picking up set of Work Emotion D9Rs (and coilovers). If my research on this subject have not led me astray, I think I can fit:
Front---18x8.5+32 245/40
Rear--- 18x10.5+23 285/30
I am willing to roll, but would like to avoid pulling the fenders. I am not looking to drop this thing on its belly. As long as there is no poke, I will just lower the car as far as I can on the setup I go with.
Does anyone have any examples of this or opinions on this setup?
Thanks! You guys have already taught me a ton.
whosawmike is offline   Reply With Quote
Old 07-21-2017, 12:44 PM   #3767
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
18x10.5+23 and 285 on stock fender s13 coupe with no pull? lol no way at all.
Old 07-21-2017, 01:06 PM   #3768
whosawmike
haha... I was basing that off of a picture I saw of a setup running 18x10 +44 275. D9Rs dont come in 10".
Looking at another picture, I see that 10.5 is going to be very pokey....
What do you think about 18x9.5 +30 with 275s?
Old 07-21-2017, 02:45 PM   #3769
CornSpeed
CornSpeed's Avatar
CornSpeed is an unknown quantity at this point
That was probably Broadfield's car. He didn't have to pull the tears then because he was still at 4x4 height. When he finally lowered it properly, it required a 25mm pull
CornSpeed is offline   Reply With Quote
Old 07-21-2017, 03:31 PM   #3770
whosawmike
It was his. If I were confident that I could pull them as well as he did, I would have no problem with a pull. My fenders would probably look like bacon though.
Old 07-21-2017, 04:02 PM   #3771
e1_griego
e1_griego's Avatar
Trader Rating: (24)
A 10 +44 can fit at a tall height, but a 10.5+23 is going to stick out 27mm more than that.
http://www.1010tires.com/Tools/Wheel-Offset-Calculator#
Depending on what you're actually doing with the car, I'd skip the 245/285 stagger, too. If it's just for looks then it's whatever, but generally for an s-chassis a square tire setup is what you want.
Old 07-21-2017, 05:22 PM   #3772
whosawmike
Thank you for the input.
The car will be a fair weather street car with the very occasional track day.
I want maximum grip. For that I just figured that max contact patch was the way to go. Can you explain what makes square setups better?
Old 07-24-2017, 04:44 AM   #3773
TheRealSy90
TheRealSy90's Avatar
Idk if this counts as maximum fitment, but it's a decent amount of rubber.
Rear is 18x10+15 with 285/35 Nitto NT01's. -1.5 camber.
Such a good signature.
Old 08-11-2017, 03:24 PM   #3774
NHTKID
NHTKID is an unknown quantity at this point
Instagram: @nhtkid
NHTKID is offline   Reply With Quote
Old 08-24-2017, 08:27 PM   #3775
HayabusaKLR
HayabusaKLR's Avatar
HayabusaKLR is an unknown quantity at this point
Hey everyone, finally got my Work Wheels in this past weekend (ordered back in December!!).
Specs: 18x9.5 E +12 // 18x10.5 E +24
Going on a 98 240SX with FA coilovers. What size tires would you guys recommend for a CLEAN look (meaning minimal camber AND not sticking out past the fenders). I do plan to roll/pull the rear and hopefully just roll the front fenders but would be willing to pull the fronts as well.
From hours of searching on here, the sizes I have it narrowed to would be the following:
255/35/18 with 295/30/18
OR
255/35/18 with 285/30/18
OR
245/40/18 with 285/35/18
Thoughts?!? Thanks everyone!
'11 CTS-V coupe...runs low 10s
'98 240SX...2JZ soon
HayabusaKLR is offline   Reply With Quote
Old 08-25-2017, 07:34 AM   #3776
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Feedback Score: 18 reviews
OR
OR
The first size combo would yield the same diameter tires front and rear. The other combos listed would have a taller front tire. Those would fit nicely on those sized wheels as well.
The last size choice would put your speedo off by 4%.
Old 08-25-2017, 01:56 PM   #3777
HayabusaKLR
I would like to do the first choice but I'm afraid that I'll be really close to sticking out which would require aggressive pulling.
Not a huge fan of 40 series 18's in the front either as I've read they tend to rub on turns. The point of these wheels is to improve the look without taking away practicality/drivability.
Old 09-08-2017, 03:47 PM   #3778
Kuma
Kuma's Avatar
Kuma is an unknown quantity at this point
I'm having trouble with something. I've done willtheyfit, and googled. Most threads with people talking about 16's are so old, the pic links don't work anymore. Kind of leaning towards 225... but I figured I'd check here before I pull the trigger.
Rears I'm wanting to go 255/50 on 16x8.5
The fronts are 16x7.5, and I'm trying to figure out if 215/50 or 225/50 would match the bulge of the rear.
The 7.5/8.5 is the true measurement from inside of bead to inside of bead, not the total width.
Kuma is offline   Reply With Quote
Old 09-10-2017, 01:27 PM   #3779
1Day
1Day's Avatar
1Day is an unknown quantity at this point
Anyone have any experience with running Kumho XS? Do they run fat or skinny? Looking at some 315/30's for my 18x12 Rezax. I know a 305/35 or a 335/30 are a better choice but I'd like to keep the overall diameter under 25.5". I know NT01 look good and not over stretched but they don't offer a tire sized in what I want for the front.
1Day is offline   Reply With Quote
Old 09-10-2017, 02:18 PM   #3780
LoSt180
LoSt180's Avatar
Trader Rating: (18)
R33 GTR wheels 17x9 +30. 245/40R17 tires on all four corners. Put 2.5 mm spacers on the front since knock on weights were hitting the struts. Lowered on Tein S-tech springs.
