06-02-2011, 08:17 PM | #6331 | |
Trader Rating: (22)
Feedback Score: 22 reviews
msglength
-Kyle Last edited by soreballz; 06-02-2011 at 08:51 PM.. |
06-02-2011, 08:31 PM | #6332 |
Got a new starter installed and now my motor stalls out after a few seconds. Friend suspects two possibilities:
-bad/low gas -timing I don't think it's timing since my motor never stalled out before I had to change the starter. Any other suspected possibilities? |
06-02-2011, 08:48 PM | #6333 | |
Full Time Student for Life |
06-02-2011, 08:57 PM | #6335 | |
06-02-2011, 09:03 PM | #6336 |
Three questions:
1) One of the terminals of the rear defogger got desoldered? Is nit possible to solder it back? 2)Does anyone has pics on this particular mod: http://forums.nicoclub.com/zerothread?id=127078. It had pics at one time, but are no longer available. 3) Are the center A/C vent frames easy to find, buy and install? The plastic frame on the center vent is missing and I know peole often remove the vents to install aftermarket gauges. |
06-02-2011, 10:13 PM | #6337 |
Trader Rating: (68)
Feedback Score: 68 reviews
soooooooooooooooo my ride height fluctuates and i don't know why...
I'm on megan streets and the ride height adjust on its on.. Coilovers aren't blown and all the lockrings are tight.. ex. car is parked and it's at the ride height i set it at. Then i drive it and an hour later it's raised about a half inch to an inch. Some days it won't change at all and it'll be perfect, but most of the time it's fluctuating. I've heard from someone that it could be worn out bushings..
Late Night Crew... #02 <3 Bought anything from me? Please leave me a review! http://zilvia.net/f/private-sellers/...meistah21.html |
06-02-2011, 10:57 PM | #6338 | |||||
Trader Rating: (58)
Feedback Score: 58 reviews
Check ebay. Quote:
Do you have any preload in your coilover spring? If so remove it (unlock the cop collar that touches the sprung, and lower it until you can rotate the spring around in the housing (not so it rattles, just loose enough to spin)
06-03-2011, 11:00 AM | #6339 |
So I adjusted my clutch pedal to stock settings today, and I absolutely hate how high up it grabs. Not to mention my knee hits the steering wheel. But I was wondering if I set it to be lower, if that would mess up the clutch in any way?
GLEAM//★☆Street Dancer☆★ IG: streetdncr // tumblr: steve-strtdncr |
06-03-2011, 11:20 AM | #6340 |
Trader Rating: (58)
No, you should follow FSM on freeplay and engagement height to help you out. Remember the upper adjustment adjusts where the clutch pedal sits.
06-03-2011, 11:56 AM | #6341 |
Okay. It seems like its slipping now that its adjusted. But ill play with it some more I guess and set it properly. Thanks.
06-03-2011, 12:06 PM | #6342 |
3 part question, and hopefuly not too dumb.
1: At what power level will a z32 chassi start self-destructing due to flexing from torque? 2: Where on the car should I reinforce first and where is it unnecessary? 3: At what point should I just stick a 4 point cage in the car? |
06-03-2011, 02:26 PM | #6344 | |
2. depends on what your using it for 3. the point when you feel its needed
06-03-2011, 03:48 PM | #6345 |
Trader Rating: (68)
my steering response is super slow in my 91 coupe.. Recently installed full arms, went from 15x8 to 17x9's, got an alignment and now i have slow steering response.. Could it be that my steering rack bushings are worn?
06-03-2011, 04:33 PM | #6346 | ||
Trader Rating: (58)
Going to a 9 tire up front is going to be a big change in 'response' of steering (which I don't underadn
06-03-2011, 04:49 PM | #6347 | |
Trader Rating: (68)
ex. Im going down a straight road and there's a bend to the right coming up. I get to the beginning of the turn and i turn my wheel but it's still going straight.. My car doesn't actually start turning until the top of my steering wheel gets to the 3o'clock position. So from the 12 o'clock position to the 3 o'clock position im not getting any steering response. It's FUCKING DANGEROUS and SCARY! my alignment guy said its worn out steering rack bushings.. Cause my car still pulls left or right after the alignment.. If i make a sharp right turn it'll pull right, if i make a sharp left it'll pull left..
06-03-2011, 05:02 PM | #6348 |
i found this cable janging around my door panel, its a manual windows, i was wondering where this cable goes?
thanks in advance Last edited by Yad; 06-03-2011 at 05:06 PM.. Reason: forgot the pic |
06-03-2011, 05:02 PM | #6349 |
Trader Rating: (38)
Feedback Score: 38 reviews
Just got my 300ZX brakes in last night and I took it for a test drive just now. While applying the brakes at very low speeds, there is a loud high pitch squeal type sound that I hear from the front driver's side. I looked it up on google and some people say it is normal, some say I need to clean my brake pads, and some say the rotors are warped.
To get rid of some speculation, the brakes do not make this sound when applying brakes at 40mph. The brake rotors aren't warped since the brake pedal doesn't shake when I apply the brakes. The brake system was used by previous owner before selling it to me and I know they had some pad left on the pads. I don't know the brand but the color is like a turquoise/teal kind of color. What could be the problem? Do I have to bed the brakes? If it is my pads, what brands do you recommend that I get (non-track)? |
06-03-2011, 05:14 PM | #6350 | |
Trader Rating: (68)
06-03-2011, 09:21 PM | #6351 |
crazy question, but does anybody know how much higher the koguchi power hood vents sit from the actual hood? or dmax.. or anything that looks similar to those. hatchback by the way
06-04-2011, 08:33 AM | #6353 |
Turn the key from on all the way to the stop where you'd have to press the release button to turn the key another little bit.
If I were to pull the key out (no lock) without pressing the release and turning that final click would that drain my battery?
06-04-2011, 08:48 AM | #6354 |
Do you have play in the steering wheel at low speeds also (even a little) might be time to replace your steering bushing. Rack bushings couldn't hurt either. How are your tie rods?
06-04-2011, 08:53 AM | #6355 |
Aftermarket lifters?
Im upgrading all my valve train and i was just wondering if there were aftermarket lifters other then the tomei solid ones? I dont want the hassle of dealing with solid lifters! I did that enough on my old drag car!
06-04-2011, 07:10 PM | #6358 |
my pedal was working nice and dandy today then i hit a huge bump and locked up my brakes and ripped the ebrake prior to hitting it (slowed down enough so i didn't go flying but i still hit it) and now the pedal is SUPER soggy
lines don't seem to be leaking or something, cause my reservoir is full, anybody have an idea?
street dancer. GLEAM |
