Old 02-18-2010, 08:39 AM   #1
whatbrokethistime
whatbrokethistime is an unknown quantity at this point
Exclamation FS: S14, RB25, RB26, Aero, Navan, Interior, Lighting
S14 / RB Parts For Sale
– Pioneer DEH-P4100 Radio w/ aux input CD changer adapter, speaker outputs on harness are chopped off, but was used with external amp so didn’t matter. Just need a new harness if you want to use the speaker outputs - $40 shipped
– S14 Sunroof Weather stripping Brand new in box from dealership, $70
– R34 RB25DET Neo Exhaust camshaft. Make offer
– RB25 Head studs OEM used, not sure of mileage. Make offer $50
– R34 RB25DET Cylinder head camshaft oil splash covers, gold in color, 4 of them, $25
– S14 Radio brackets, slightly bent, still work perfect - $20
– S14 left front corner light, broken top tab, and small internal crack on lenses, but does not leak, still useable with other mounting points. $30
– 5-bolt turbo downpipe gasket, with brand new bolts $20
– RB25 neo upper intake plenum gasket rubber, have two of these, $18
– R34 RB25det turbo manifold OEM $80
– RB25DET top mount turbo manifold, eBay brand, modified to fit properly, need Wastegate flange, $120
– S14 oem used rear traction rods, $50
– Apexi 3” power intake filter, used, great shape, $80
– S14 SE power mirror switch, small crack on the face of switch, but still fully functional $10
– S14 Stock rubber shift knob, dirty, needs some cleaning up, $10
– JDM Navan S14 oem front amber corner lights, new in box, $80
– S14 sunroof assembly complete minus fiberglass trim ring around outer edge of glass. Comes with drain tubes as well. $ Make offer, prefer pickup only, large item
– S14 SE sunroof headliner, great shape no stains, cracks, etc. Pick-up only $50
– S14 SE sunroof headliner trim ring around pull shade, $40
– S14 SE overhead light console with sunroof switches $35
– S14 M-sport D-style FRP +20mm wide front fenders new in box, $290, buyer pays shipping, large box approx $110 to ship
– RB25 oem head gasket new in box, $70
– S14 SE airbag control module $90
– S14 SE airbag control harness $50
– S14 SE passenger side airbag, $100
– RB25DE Neo Cylinder Head (machined, no cams) $400 plus shipping FS: R34 RB25EDE Neo Cylinder head, Complete Machined head minus cams: Engine / Drivetrain (for sale): Nissan Forums / Infiniti Forums - NICOclub
-- Perrin Universal Dual Gauge Pod $40
Im picking up a new shortblock soon, just throwing this out there. Anyone interested?
May part out the block depending on what i get offered for the various parts.
fresh never run completely assembled. Sitting on engine stand at the moment at a shop.
R34 RB25DET Block
.40 Over Bore, Line Honed, Deck Re-surfaced & Micropolished
R33 RB26DETT Crank, longer Crank Collar
R33 RB26DETT Rods, Micro-polished
CP 87mm RB26DETT Pistons, 8.5:1 Compression, CP Piston Rings
ARP Rod, Main, Head Bolts
ACL Race Rod & Main Bearings
Tomei Oil Restrictors
here are the specs for the bottom end:
Cylinder Bore Size 87
Piston Stroke Length 73.7
Head Gasket Bore Diameter 88
Piston Deck Clearance Negative If ABOVE Deck (Use '-') : -0.5715
Make me an offer, something reasonable. no loballers. lots of time and money went into this build.
All prices are OBO, do not include shipping unless stated, and i can be reached best by email at [email protected]
Thanks for looking
whatbrokethistime is offline   Reply With Quote
Old 02-21-2010, 06:34 PM   #2
BspeedIL82
BspeedIL82 is an unknown quantity at this point
you dont by chance have the aluminum mount for the CAS for the rb25? the mount attaches to the head with 3 bolts and covers the cam, then the CAS bolts to it.
BspeedIL82 is offline   Reply With Quote
Old 02-21-2010, 07:55 PM   #3
whatbrokethistime
I dont, im sorry. best bet though is to contact Ricky @ rawbrokerage.com he always has RB parts that are hard to find. good luck!
Old 02-21-2010, 08:06 PM   #4
thisisthenewsic
thisisthenewsic is an unknown quantity at this point
Post pics of the cd deck please
thisisthenewsic is offline   Reply With Quote
Old 02-24-2010, 08:51 AM   #5
wannabe-silvia
wannabe-silvia is making his/her stupidity well-knownwannabe-silvia is making his/her stupidity well-knownwannabe-silvia is making his/her stupidity well-knownwannabe-silvia is making his/her stupidity well-knownwannabe-silvia is making his/her stupidity well-known
u have an email about exhasut cam
FVCK THE HATERS
wannabe-silvia is offline   Reply With Quote
Old 03-05-2010, 09:45 PM   #6
whatbrokethistime
Bump
bumpbumpbump
Old 03-25-2010, 12:02 AM   #7
Darkvillin
Darkvillin's Avatar
Darkvillin is an unknown quantity at this point
will usdm sockets plug into the navan bumper blinkers? or is anything else needed? if possible n u still have them, please email me pics at [email protected]
S14-vlsd/coilovers. L33 swap, ENGAGE! www.arnaturalselection.blogspot.com
Last edited by Darkvillin; 03-25-2010 at 12:04 AM.. Reason: interested in the item...wanna see pics.
Darkvillin is offline   Reply With Quote
Old 05-08-2010, 11:25 AM   #8
wannabsi
wannabsi is an unknown quantity at this point
Im local to u and interested in the rb26dett block. give me a call when you have a second and still have this stuff
Thanks
alex
919-939-3285
wannabsi is offline   Reply With Quote
Old 08-15-2010, 06:48 AM   #9
whatbrokethistime
Thanks
alex
919-939-3285
alex, sorry i didnt get back to you, i havent been watching this thread. I've got it still.
I'll call you later on this afternoon.
-John
Old 08-15-2010, 06:50 AM   #10
whatbrokethistime
Yes they do plug in. I dont have pics of them as they are sealed in the box.
search google for "navan bumper" and you'll see the bumper lights
they do not fit in USDM bumpers
part out, rb25, rb26, s14, sr20
