Old 02-14-2018, 07:04 AM   #1
Asmar
Asmar's Avatar
Asmar is an unknown quantity at this point
s14 Car Won't Warm Up
Stock '95 S14. Car won't warm up. I thought it was the thermostat (as that's almost always the case in these situations) so I replaced it with an OEM Nissan thermostat. Car still won't warm up. Am I overlooking something else that's preventing the car from warming up? Searched around and couldn't find an answer.
Asmar is offline   Reply With Quote
Old 02-14-2018, 09:00 AM   #2
Agamemnon
Agamemnon's Avatar
Is the heater blowing hot air?
If the thermostat is indeed operating as intended it may be a faulty temp sensor. There are two of them. one for the gauge and one for the ECU to help control fuel ratios. If you car runs rich check both.
Old 02-15-2018, 06:51 PM   #3
92SEric240sx
92SEric240sx's Avatar
Trader Rating: (32)
92SEric240sx is an unknown quantity at this point
Feedback Score: 32 reviews
Temp sensor for the gauge in the block- probably went out on you
RELAX BRO!!!!
92SEric240sx is offline   Reply With Quote
Old 02-16-2018, 09:17 AM   #4
jedi03
use laser thermometer to check actual running temp, if hot replace your sensor, if not check the sensor...if not hot thermostat or possibly fan clutch
Old 04-21-2018, 06:41 AM   #5
jimcfl
jimcfl is an unknown quantity at this point
Could also be a bad ground. Sometimes brand new thermostats stick open, but an open thermostat will still let the car warm up, it just takes a lot longer.
jimcfl is offline   Reply With Quote
Old 04-21-2018, 08:03 AM   #6
tuzzio
tuzzio's Avatar
Running a stock gauge or after market?
Never trust an s-chassis oem coolant temp gauge.
Old 04-21-2018, 09:34 AM   #7
Pandemonium
Pandemonium is an unknown quantity at this point
are you getting heat? hows the coolant level? is the air all bled out?
Pandemonium is offline   Reply With Quote
