Old 09-05-2008, 01:08 AM   #1
icemhan_21
icemhan_21 is on a distinguished road
s14 oil feed line banjo bolt
hey guys im going to swap in my sr20det this sunday and im missing this banjo bolt for my oil feed line for the turbo. ive went everywhere but nobodys selling any banjo bolt. so my question is is there any options or fitting that i can use? or if any of you guys have it just pm me asap..
heres some pics where the banjo bolt goes..
icemhan_21 is offline   Reply With Quote
Old 09-05-2008, 08:23 AM   #2
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
you can use this but iirc the stock banjo bolt has a restrictor, so you would need to get a restrictor
Pegasus -Male 12 x 1.25mm Metric Convex Seat to 3AN Male, Steel
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 09-05-2008, 08:45 AM   #3
shmiddy
shmiddy's Avatar
nice !!! pretent +1 for you!! i was wondering the same thing i needed the size for that thing cuz the one i put on mine is leaking. i might have put the wrong one in.
i fully de-volved
Old 09-05-2008, 08:55 AM   #4
japslapsilvia
if you put that wrong one in chances are that you may have stripped the block i hear they are really easy to strip, i would carefully take the fitting out and inspect the threads it they arent all galled or damaged you may want to pick up a thread chaser. DO NOT USE A TAP TO CLEAN threads always use a chaser..
if they are stripped you will need to get a heli-coil to repair it, search someone posted a like to a really good heli-coil for this same problem
