Old 09-02-2008, 04:34 PM   #1
Vinny
Vinny's Avatar
Vinny is a jewel in the roughVinny is a jewel in the roughVinny is a jewel in the roughVinny is a jewel in the roughVinny is a jewel in the roughVinny is a jewel in the roughVinny is a jewel in the rough
Transmission buzz at shift
Alright, so this has been going on for about a week now.
Everytime I shift/engage the clutch there's a weird buzzing sound.
Gears don't grind, Clutch doesn't slip, No leaks, Tranny fluid was replaced about 4 months back. There's no way to check tranny fluid level, is there? Also I asked some other friends of mine...one said syncros were going (which I highly doubt) and then my bro said possibly the flywheel?
Any suggestions in whats wrong or what I could do?
I mean, if I'm gonna take the tranny apart, I'm gonna might as well replace clutch/flywheel...just wondering if anyone else had this kind of problem.
Thanks for any help.
Kolab Agency | Limitless Society
Vinny is offline   Reply With Quote
Old 09-02-2008, 04:37 PM   #2
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
you can take the side plug out of the tranny with the car jacked up, and put your finger in, it it's right at the bottom of your finger then it's fine, also could be your throwout bearing.
Slip Gypsies Blog
not sure if you realize this
Old 09-02-2008, 05:42 PM   #3
Vinny
Vinny's Avatar
where and how much can I get a TOB?
Never even heard of the term...I'm noob. bash me. -.-
Old 09-02-2008, 07:43 PM   #4
nismo racer
nismo racer's Avatar
nismo racer is making a name for him/her selfnismo racer is making a name for him/her self
it could also be the the syncros are busted.
PEGASUS
nismo racer is offline   Reply With Quote
Old 09-03-2008, 01:00 AM   #5
soreballz
soreballz's Avatar
Trader Rating: (22)
Feedback Score: 22 reviews
Bad pilot bushings make sort of a buzzing sound when you clutch in and hit the gas...
-Kyle
Old 09-03-2008, 06:58 AM   #6
sil80forme
sil80forme's Avatar
sil80forme can only hope to improve
Send a message via AIM to sil80forme
Trans buzz
If the buzz is when u are shifting and the clutch is engeged then ur throw out bearing (tob) is bad....
sil80forme is offline   Reply With Quote
Old 09-03-2008, 06:59 AM   #7
sil80forme
sil80forme's Avatar
if the the syncros were busted it wouldnt go into gear at all and or grind like hell when goin into gear...which he states doesnot happen
Old 09-03-2008, 08:46 AM   #8
Vinny
Vinny's Avatar
Thats what I thought as well.
Thanks guys, really appreciate it!
I actually only hear the buzz if I'm shifting over 3k rpms
and it's when I push the clutch pedal in
Old 09-03-2008, 12:34 PM   #9
Vinny
Vinny's Avatar
Just got back from lunch.
I left it in 3rd gear and went up to 4500 rpms and then let go and I actually heard the buzzing sound. Would the bearing still make a noise or could it be something else now?
Old 09-03-2008, 01:21 PM   #10
S14DB
AFC #1
S14DB's Avatar
Is it only when the clutch is disengaged or when you have pressure on the clutch pedal? Are you holding the shift knob when it buzzes?
Sounds like a Input/Pilot Bushing.
Old 09-03-2008, 02:01 PM   #11
Vinny
Vinny's Avatar
When I disengage the clutch it buzzes but it also buzzed when I went to higher rpms and let go. It was my first time today actually hearing it do that.
I usually hold the shiftknob lightly when I'm driving, but not holding onto dear life with it or using it as an elbow rest or whatever.
How unsafe is it driving around on right now? This is a daily driver.
Old 09-03-2008, 02:14 PM   #12
Dream240
Dream240's Avatar
Dream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond repute
Bingo.
That sound is actually a harmonic vibration caused by having too much free play on your input shaft. The free play is coming from having that brass bushing worn down to practically nothing. The sound will get worse until the bushing completely disintegrates. Then you will have input shaft on crank shaft direct contact.....not good.
Do a complete clutch job and this will go away. Also make sure to lube up your new pilot bushing real good. You want it to last you in between clutches.
GL
Don't mess with my monkey...he's loaded.
Dream240 is offline   Reply With Quote
Old 09-03-2008, 02:24 PM   #13
Vinny
Vinny's Avatar
well if that wasn't the most detailed and precise answer yet.
Thank you good sir!
So I guess I really shouldn't be driving my car right now. damn.
