01-28-2010, 03:24 PM | #453 |
because he started a useful thread that removed a lot of clutter from the board.
oh, wait. that is the exact opposite reason why some one would NOT get pinked. i have no idea.
BRICKHOUSE PRODUCTS
IG @brickhouse_products |
01-28-2010, 05:14 PM | #454 |
I have a handful of small questions:
1. What kind of flare are these? (S13, lines to steering rack) 2. Is there a tool I can use to make them at home? 3. How do you "unbend" steel tubing to bend it to a different shape? 4. Do I have to use steel lines/fittings for power steering? 5. Not sure of the name for this, but I know what it does. Is it absolutely necessary?
WTB: PAIR 18x10 0 to -25, less than $1500 shipped please. |
01-28-2010, 05:25 PM | #455 |
1. Can't remember. Someone else chime in!
2. Look for a "flaring kit" Brake Pipe Flaring Kit 3. Not sure if you could without weakening the metal. But if you could I would assume pipe bender would work. https://www.europaspares.com/BRAKE_P...PBT__2707.html 4. Again, not 100% positive. 5. No, get rid of it.
Blow me, bitches. |
01-28-2010, 05:28 PM | #456 |
because he speaks his mind about idiots and uses words that aren't approved here.
http://bhworld.wordpress.com/ |
01-29-2010, 11:22 AM | #460 |
i tried to check the tps on my redtop(thats running like shit) black to ground and red to the middle wire of tps. turn on ignition i get nothing. no voltage everidle or WOT..
is my tps dead? obviously?
@UpshiftEngineering |
01-29-2010, 02:04 PM | #461 | |
01-29-2010, 02:11 PM | #462 |
The KA trannies are identical. They bolt up to either SOHC or DOHC.
Have a pleasant day.
"So here I am, right back at it again, just like I've always been" |
01-29-2010, 03:28 PM | #466 |
I would say yes it should be, but it's not exactly a part you want to have to replace twice.
And honestly, what does a rear main seal cost? $20? Just get the right one... Edit, appears to be the same. http://www.courtesyparts.com/240sx-p...1420_1423.html
01-29-2010, 03:29 PM | #467 |
Im 99% sure they are the same. To double check just go to an auto parts website and see if they use the same part number.
instagram: madness_garages14 |
01-29-2010, 07:47 PM | #469 |
Kinda of a vauge question. but what bolts/nuts/washers or anything, do i need to bolt up the stock exhaust. the exhaust manifold is already on the block. but all the rest isnt on. lol.
01-29-2010, 09:19 PM | #470 |
Trader Rating: (53)
Feedback Score: 53 reviews
When doing an Auto to 5 Speed swap can you avoid having to do the little bit of extra wiring if you remove the Automatic lower harness and replace it with the 5 Speed lower harness?
01-29-2010, 10:06 PM | #471 | |
Bandwagon.
get the bolts and nuts to bolt onto the manifold o.o |
01-29-2010, 10:42 PM | #473 |
when doing auto to manual the only wiring needed to be done is connecting the inhibitor(sp) wire together and your optional reverse lights.
when life gets hard, i pick up the card with the smiley face |
01-29-2010, 11:28 PM | #474 |
01-30-2010, 12:46 AM | #476 |
Trader Rating: (53)
so if i was going to swap in an SR, having a harness that was originally auto wouldn't matter, correct? i am under the impression that it wouldn't but i just want to make sure.
01-30-2010, 10:42 AM | #478 |
I have two questions:
1 what number wedge bulbs do I need to replace my stock indicater bulbs in my gauge cluster. I'm doing an LED swap. I already bought the big 194 bulbs for the backlighting.(i still have to buy a red 194 for the batt. indicater) 2 I've heard that the LED bulbs for the green blinker indicater arrows aren't compatible because of the anolog signal. or is it wired into the turn signal switch, wich clicks on and off like a digital signal?? thanx in advance! |
01-30-2010, 11:32 AM | #479 |
one of my favorite threads
http://zilvia.net/f/chat/212964-dope-vert-thead.html
**CoUpe LOve** #3 |
01-30-2010, 12:37 PM | #480 | |
Bandwagon.
well when i broke my studs on my cat i just drilled it out and got bolts that fit and used it, i dont recall springs lol.
- Hong Last edited by hOngsterr; 02-01-2010 at 10:12 AM.. Reason: wrong answer. |
