Old 10-21-2009, 07:13 PM   #1
tuketo
tuketo is an unknown quantity at this point
Is it necessary or waste of money. Megan Racing Front lower control arm ball joint
For S13
My car is not slammed but it is lowered to the point where the FLCA are not horizontal, they are tilted up a little. I'm wondering how low does the car have to be for the ball joints to be necessary?
I forgot what the hight was, but the tires sit at same level as the fenders do, maybe 1/4" into the fender.
Car is built for grip and drift, so I'm trying to figure out if these will help me out.
tuketo is offline   Reply With Quote
Old 10-21-2009, 07:22 PM   #2
kris
kris's Avatar
kris is an unknown quantity at this point
Originally Posted by tuketo View Post
For S13
I would say not worth. Get other parts like T/C rods, coilovers, tie rods etc etc before those. You will need to piss with alot of settings to get it back on point. i am sure some one will chime in with the technical mumbo jumbo. Even then for a part like that if your serious go SPL or some other higher quality brand with a more durable joint
kris is offline   Reply With Quote
Old 10-21-2009, 07:22 PM   #3
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
waste of money go with SPL. go to this site
splparts.com
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 10-21-2009, 07:29 PM   #4
tuketo
I already have tension rods, and the tie rods to fix the bump steer, and coilovers with adjustable upper mount. I'm just not sure at what point does the balljoint start binding. That's the only part that I know of why the joint is crucial to replace but I don't think I'm there yet, and the other reason is to get the back the track width that's lost because of the LCA angle.
Anyone else has any more info on when the joint should be replaced with the megan racing to correct the arm?
Old 10-21-2009, 07:44 PM   #5
EDacIouSX
EDacIouSX's Avatar
Trader Rating: (53)
EDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfection
Feedback Score: 53 reviews
well... i got the SPL lower control arm, what a big difference!
If your arms have worn bushings and worn outer ball joints then you do need to at least fix that but it depends how serious you are. Also, you can widen the track to get more grip and raise your lowered center of gravity to where it is suppose to be.
Old 10-21-2009, 08:19 PM   #6
Slammed180
Slammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of light
I have them, and know of a few cars that run them locally.
It helps only if you're really low.
Blow me, bitches.
Slammed180 is offline   Reply With Quote
Old 10-21-2009, 08:33 PM   #7
burnsauto
burnsauto's Avatar
adjusting roll center on a low vehicle is always a good thing to do.
Old 10-21-2009, 08:33 PM   #8
GSXRJJordan
GSXRJJordan's Avatar
It helps the most when you're really low, but any roll center adjustment helps - and having new ball joints sometimes helps the feel a lot. I'd say that compared to the other replacement joints, they're not bad if you can get them for close to cost. I can't see paying $140 or whatever retail is for them though.
Old 10-21-2009, 08:42 PM   #9
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
I have a set of Chinaspeed FLCAs and RLCAs and they're junk
Ikeya Formula are the only ones I've personally seen that are quality and worth the money
one day I'll make my own
Old 10-21-2009, 08:44 PM   #10
GSXRJJordan
Same lol, Luke (Blu808) and I have been talking about it for about a year now haha. Eventually, I'll probably hit you up too, we can brainstorm.
Old 10-21-2009, 10:06 PM   #11
Slammed180
Originally Posted by GSXRJJordan View Post
It helps the most when you're really low, but any roll center adjustment helps.
Correct. That's what I meant.
My statement was more towards someone with lowering springs or mildly low on coils. These aren't really necessary for someone only slightly lower than stock.
If your car is slammed or close to it, then these are definitely worth the money IMO.
Blow me, bitches.
Old 10-22-2009, 10:31 AM   #12
WISH ONE
I was actually looking at these, online yesterday. Pictures look ok, but eh.. who really knows what quality is like? has anyone personally tried them?I have heard all kinds of nightmares about the RUCAs and the poor quality welding on some, while others have had no problems. Seems sort of sketchy, but nowadays almost everything is made in china/wether you know about it or not, so who can you really trust??
The spl ones are nice but $700+ for lca's is a good chunk of change and unless you really are fine tuning,IMO its unecessary for daily/light track use.
Old 10-22-2009, 10:36 AM   #13
g6civcx
g6civcx's Avatar
I'm deftly scared of suspension tuning, even after taking 2 years of motorsports engineering.
I don't know how the pros do it, but on my personal car, I don't mess with the factory suspension geometry.
Say what you want, but the only thing I change is the strut and spring at most, and maybe replacing worn out bushings with polyurethane ones. I don't even change the factory ride height.
For the hardcore suspension tuning guys, how do you know what's working and what's not?
Old 10-22-2009, 10:54 AM   #14
landins13
landins13's Avatar
landins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choices
trial an error, practice, experience. every car will act different under different circumstances, tire compound and pressure come into play as well, its a matter of setting up the car through many test passes and tweeking it as you see fit, one thing you need to do though is continue to run the same compound tire to keep consistency, if you tune a car for an r compound and then run street compound tires the car will handle a lot worse than if it were tuned for the tires its on.
NO HANDS IN PANTS!!
landins13 is offline   Reply With Quote
Old 10-22-2009, 11:05 AM   #15
g6civcx
g6civcx's Avatar
That's first semester suspension class, and it's fine and good, but with factory suspension, it's impossible to change just one variable due to the way it's designed.
You change one component and a bunch of variables change.
Even if I were able to change one variable at a time on a stock suspension, I'm not good enough a driver to where I can sense a minute change in a single variable.
How do you know if you're doing more harm than good?
Old 10-22-2009, 03:36 PM   #16
GSXRJJordan
All very good points ~ for me, I always compare overall performance (speed through a given corner) and feel (steering feedback/confidence/etc, which plays a huge roll in overall speed lol) with my dad's Z06 vette. This helps a ton, especially when you have (had? ) Angeles Crest Hwy at your back door.
For me personally, I got the car to a ride height and camber setting I liked, drove it, eventually raised it a little, then started playing with damping. Once I changed an alignment setting (toe, caster, camber again, etc), I'd play with damping again.
Old 10-22-2009, 04:26 PM   #17
surge s14
surge s14's Avatar
surge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymore
i think anything megan is a waste of money
surge s14 is offline   Reply With Quote
Old 07-24-2018, 07:30 AM   #18
supersayianjim
supersayianjim's Avatar
supersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enough
bump, I need new front ball joints, anyone have a breakthrough for a lowered (not slammed) 240sx?
supersayianjim is offline   Reply With Quote
Old 07-24-2018, 08:03 AM   #19
tuzzio
tuzzio's Avatar
Gktech grip knuckles.
Updated geometry. Stock balljoints. win win.
