Old 02-19-2014, 09:36 PM   #31
sleepyS14se
sleepyS14se's Avatar
sleepyS14se is an unknown quantity at this point
i want to see the mounts used. I posted awhile back about doing a sbc carb'd in my s14 and everyone went ape shit and said "GO LS OR GO HOME'
sooo, lets see the motor mounts and how would it be any easier doing a ford small block rather than a sbc?
Questions:
Who sells the mount kit?
Is the stock 5.0 oil pan usable or does it require a ton of modifying
this thread really surprises me being no one has done the typical zilvia BS and flaming.
95 S14 se RB25DET 348whp
sleepyS14se is offline   Reply With Quote
Old 02-19-2014, 10:44 PM   #32
ashilling101
ashilling101 is an unknown quantity at this point
Lol I know me too and the block I'm using was already in a s13 to I shouldn't have to mod the oil pan and I have mounts with it assuming their sill good
"If you're not first, you're last"- Ricky Bobby
ashilling101 is offline   Reply With Quote
Old 02-19-2014, 11:03 PM   #33
Jarhead0612
Jarhead0612 is an unknown quantity at this point
I was looking into doing a 5.0 swap a couple years ago with low compression pistons for boost but sold it and dropped in a sr20. now im about to do a vh45de swap. The guy I bought my sr from was doing a vh swap in a buddys 240 and it snapped the axle at the joint. Its a hit or miss with the axles.
Jarhead0612 is offline   Reply With Quote
Old 02-19-2014, 11:06 PM   #34
ashilling101
Yeah that seems to be the consensus. I'm gonna try to use the stock ones until either they break or when I go turbo. I'm sure the place that's making my drive shaft can make axles too
Old 02-19-2014, 11:58 PM   #35
Kingtal0n
Kingtal0n's Avatar
there are only 2 ways to V8 a 240sx.
Cheap way: "new" old school 1-piece rear seal chevy block or similar year ford roller blocks (89+), carb or TPI or mpfi on the factory ECU with a self-tuned chip, hypereutectic piston or stock bottom end, pick a transmission and make 300-350 horsepower
Proper way: LS-x nuff said
pros and cons of each.
Cheap way is cheap, if fuel infected you get 25+mpg too. 300 horses nothing to sneeze at. Lots of aftermarket support that is very cheap. cheap cheap cheap. Cons? Poor efficiency. Old designs. slow computer. batch fire. tune it yourself or it's waste of time and money.
LS-pros / cons. More expensive but you get technology, efficiency, ls edit, new designs and the potential for more than just 300 horses on a factory bottom end.
I've done the cheap way before. Blower/carb. TPI. Holley stealth ram. Twin Turbo small block.
In the end, I came to appreciate the simplicity of the Nissan sr20det.
tinyurl.com/4l80er
Old 02-20-2014, 12:21 AM   #36
Jarhead0612
You can do a vh45de swap for under $3000. 310hp or more with a good exhaust, intake and a tune. There you get technology that nissan is still using, internals of a race engine and the sound of a monster. The engine even with 10.2:1 compression can still handle boost with the pistons nissan used.
Old 02-20-2014, 04:44 AM   #37
Corbic
Corbic's Avatar
Questions:
Go read those links I posted.
Old 02-20-2014, 08:33 AM   #38
collegekid
collegekid's Avatar
collegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to all
Can you give an estimate of what your budget actually is? I too am on a collegekid budget. I have enough cash to build a nice car but then I would be broke. So even when it comes to spending 1 grand I still research every possible alternative before spending it.
So many builds that never get completed or cars that get sold because of bills and other financial priorities, just take a look in the cars for sale section. I definitely want to see how you plan on finishing this project because I am in the same boat. I'm not flaming you, I just want to compare my "build outline" with yours.
collegekid is offline   Reply With Quote
Old 02-20-2014, 08:44 AM   #39
ashilling101
My budget is around 1000 maybe a little more depending on what I can sell the stuff coming out of the car for
5.0 swap, help a kid out, s13 240sx
