Old 05-22-2016, 06:56 PM   #1
zombiewolf513
zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513
Transmission breather tube
Has anyone driven for a long time without a breather tube in their M/T?
Anyone have a hack for replacing a missing one?
zombiewolf513 is offline   Reply With Quote
Old 05-23-2016, 09:29 AM   #2
jedi03
Yes..just makes a mess...get a hose that matches and route it firward...
Old 05-30-2016, 09:55 PM   #3
NoPistons!
NoPistons!'s Avatar
NoPistons! is an unknown quantity at this point
Had my hose open vent zip tied up high to my battery cable lead i ran down the trans tunnel. I wouldn't run without it or with it blocked off. However the shifter isn't air tight i dont think so maybe blocking it off completely wont hurt anything. I've taken the 71c apart before for inspections and i dont see why it would't just simply vent excess pressure/heat through the shifter. Just my 2 cents.
Just another broke ass drifter
NoPistons! is offline   Reply With Quote
Old 05-31-2016, 12:06 AM   #4
zombiewolf513
I can see a hot day and steep incline causing a leak along with dust and bugs getting in there. I was thinking of cutting some brake hardline that could fit in the port. Anybody able to measure the I.D. of the hole on a manual KA24de trans they have?
Old 05-31-2016, 01:08 AM   #5
rawgarage
Banned from the Marketplace
Trader Rating: (75)
Feedback Score: 75 reviews
I can measure the hose
Text me 9792366891
Old 10-22-2018, 08:57 PM   #6
240sxTuck
240sxTuck's Avatar
240sxTuck is an unknown quantity at this point
Hey sorry to revive a dead thread, but since we're on the subject of transmission vents, is there a way to test whether it's clogged? My M/T frequently lets out a loud hiss when I let off of the gas under load. I'm worried that it's clogged up.
240sxTuck is offline   Reply With Quote
Old 10-25-2018, 02:30 AM   #7
gaz_moose
gaz_moose is an unknown quantity at this point
blow down the pipe.
gaz_moose is offline   Reply With Quote
Old 10-25-2018, 02:47 AM   #8
240sxTuck
240sxTuck's Avatar
Originally Posted by gaz_moose View Post
blow down the pipe.
Easy enough. Wasn't sure if i should blow or suck
Old 10-25-2018, 03:03 PM   #9
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
Do both and don't forget to spit
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 07-28-2020, 05:13 PM   #10
zombiewolf513
Just wrapped this up. A new breather tube can be fashioned with 5/16 OD hardline. Welded a washer to it to bolt it to the engine at the top with the turndown. Made a slight fillet with hardline cutting tool. Hand press fit into the trans.
