01-21-2015, 02:34 PM | #6631 | |
01-23-2015, 12:57 PM | #6632 | |
Trader Rating: (28)
Feedback Score: 28 reviews
02-02-2015, 08:03 PM | #6633 |
Aligned my s14 this past weekend.
Front: Camber -4 Toe 0 Caster 7 Rear: Camber -1 Toe 0 I'll see how i like this setup. I'd like to do an event or two on it, then mess with the caster and see how i like it. The setup: |
02-04-2015, 03:31 AM | #6634 | |
I ended up machining the rotor hat down something like .2", can't remember the exact number. Figured the amount by placing washers on the studs until everything cleared and then measuring the amount. This also solved another issue in that the caliper would not have been centered over the rotor with the PBM knuckles by the same amount. Everything lined up perfectly with the stock knuckles though, except my rotor did dig into the stock control arms at lock. Maybe AZ ZCar updated the design from when I bought mine to give more clearance? Pushing the rotor out further though on the stock knuckle would have required a different mounting bracket though. |
02-04-2015, 12:06 PM | #6635 | |
It sucks, as I loved my Wilwood setup, but I have already sold the kit for a price im happy with and will be running a fresh 30mm Z32 front setup for 2015. But atleast I am able to move forward and actually put the car on the ground haha.. Thanks for the help guys! |
02-04-2015, 01:14 PM | #6636 |
Just got a batch of these done, looking forward to scalloping out my own lcas and really seeing potential angle of our knuckles. We will be working on making our own version of toe/traction/tension/rucas as well for the schassis hopefully later this month.
DLG - DIRTYLOVE |
02-06-2015, 07:49 AM | #6638 |
There is such a thing as moving the tie rod pick up point to far in. You can add more stress and over center easier if its to short. So these are setup to avoid that, you still get quicker steering and plenty of angle with these while avoiding the issues from having a extremely short pickup point.
DLG - DIRTYLOVE |
02-06-2015, 07:50 PM | #6639 |
Hoping this is the correct place to post this.
I've got a set of Zeal Function D coilovers I'm trying to install on my s14. Fronts are currently valved for 9k and run a 7" 9k swift spring. I want to swap springs to 7k and while I'm at it if I can go to a 6" spring that would make things so much cleaner. Measured piston stroke at 80mm Current 7" Swift 9k has a usable stroke 87mm and max stroke 113mm New 6" Swift 7k has usable stroke 89mm max stroke 96mm When I look at the numbers it seems I should see no difference in ride quality or suspension travel due to the shorter spring. Same usable stroke and though the max stroke is shorter it's still much larger than the piston stroke which would hit it's bump stop first. Am I oversimplifying it? When I called Endless the person I spoke with said the shorter spring would definitely change how the car felt. I don't see how and hoping one of you suspension gurus can explain it to me since I can't find any in depth info on this. Thanks. Background info for those interested. Running 17x9 +30 GTR33 wheels with 255/40/17 tires. Currently fit perfectly flush with fender and sides with my Tein SS coils. Zeals have a smaller offset from knuckle to strut and an oversized spring perch. The spring perch is digging into the side of the tires. 1" shorter spring would allow the perch to sit above the tire and solve my issue. Otherwise I have to run a 10mm wheel spacer or 5mm spacer and camber bolt with positive camber to offset the top of the wheel away from the strut and then compensate by adding more negative camber at the camber plates. Would also require pulling the fender or adding more negative camber to prevent fender rubbing. I don't consider the car as that low. Have about 3/4" tire to fender gap. Last edited by dionkouki; 02-07-2015 at 12:41 PM.. |
02-07-2015, 11:35 AM | #6640 |
Yeah I don't like the tierod arm shortneed too much. I've driven a couple other peoples' knuckles and think that it's "too twitchy". In terms of stress, I wouldn't be worried about it if your welds are good. (I also gusset the pick up)
I noticed most people (at least around here) make knuckles, but they don't calibrate bump steer when relocating tierod arm. I've driven some horrid knuckles like this lol. They feel "fine" sideways, but I'm pretty anal about getting bump calibrated from lock to lock, as well as 'static'. |
02-09-2015, 07:53 AM | #6641 |
Yeah, was referencing stress on the tierod itself. I have no worries about the quality of the weld and any stress placed upon it causing any issues.
DLG - DIRTYLOVE |
02-10-2015, 07:37 AM | #6642 | |
Good for circuit as well? |
02-10-2015, 10:04 AM | #6644 | |
Correct
DLG - DIRTYLOVE |
02-12-2015, 07:46 AM | #6645 |
Ah I'm mainly interested in the RC adjustment without all these other tweaks unfortunately for me most of the stuff available is aimed at drift and hardcore steering angle.
02-17-2015, 12:07 AM | #6649 |
you can see that the ball joint pick-up is not moved, hence no roll center correction.
I am still developing and refining angle kit. Really excited! But along the lines of circuit, next month I should be doing an auto-x stock ackerman, quick steer, roll center corrected knuckle. I can do that for people. |
02-18-2015, 05:19 AM | #6650 | |
02-18-2015, 03:24 PM | #6651 |
Any more info on this? If they offer 15mm of correction, that's pretty good considering that at approximately 20mm the LCA begins to interfere with the brake rotor. Seems like a simple, cost-effective option.
02-19-2015, 10:54 AM | #6653 |
This is true.
My TDP kit is currently undergoing hell in this Michigan winter. The tie rod heims have developed a small amount of play with all this salt water, but I kind of expected that. It is pretty fun though. I need to find a better way to update the first page, I should have probably split it into a few more posts haha.
02-19-2015, 11:13 AM | #6654 |
Trader Rating: (115)
Feedback Score: 115 reviews
I only read this thread when you post haha. You're nuts driving a car with a suspension kit that costs more than the whole car is worth in the snow.
02-19-2015, 04:50 PM | #6655 | |
I know! Haha. I figured it would be a good torture test... but really it's my only car and I couldn't stand going back to stock parts after experiencing the awesomeness that is this kit, hahaha. Definitely not driving it next winter, the snow here is wayyyy too deep and destructive honestly.
02-21-2015, 12:31 PM | #6657 | |
The want is so strong: Interesting that Robbie@TDP doesn't feel the need for anti-roll bars front or rear for drifting. I'm not sure if it's just a ride height thing or if it's genuinely not needed. My car feels awesome right now, but it's 4x4 at the moment. It'll be interesting to feel it at it's summer ride height.
02-21-2015, 06:52 PM | #6659 |
I was looking into the GKtech rear uprights and found it curious that they increase anti-squat. I thought the general consensus was that the s-chassis has too much anti-squat as is?
What are the best knuckles/uprights for grip anyway? I currently have Geomasters and I'm not sure how I feel about them.
My S13 SR Street Mod Build |
