07-17-2017, 08:07 PM | #1 |
Help! R32 caliper
Can someone help!!!!!!I recently bought a set of front caliper to do a big brake conversion on my s13. The caliper i got was from a r32...the caliper are aluminium and i need to buy some rotor but sure if the caliper are 26mm or 30mm.. i did a measure of the gap where the rotor sit in it and it's like 1 3/8 about 2inch off from being 1 1/2. The guy that i bought it from say that 300zx rotor fit but i just want to verify before i buy the rotor.
07-17-2017, 08:32 PM | #2 |
1 3/8th of an inch is just shy of 35mm. So I'm not sure what you're asking. Use the search function, there's a lot of info about OEM brake upgrades.
Sent from my iPhone using Tapatalk |
07-17-2017, 09:38 PM | #4 | |
Look again
Heres from another forum. ______________ Front S13 CA18det = 256mm x 22mm 1-Pot (88-91) S13 CA18det = 280mm x 22mm 1-Pot (91-94) theres no S13 with 4 pot even not the Type-X so far i know S14 SR20det = 280mm x 28mm 4-Pot Z32 TT VG30dett = 280mm 28mm 4-Pot BNR32 RB26dett = 296mm x 32mm 4-Pot ECR33 RB25det = 296mm x 30mm 4-Pot BCNR33 RB26dett = 324mm x 32mm 4-Pot ER34 RB25det = 310mm x 30mm 4-Pot BNR34 RB26dett = 324mm x 32mm 4-Pot ____________________________ So I gave you all the information you need that you could've found maybe within minutes if you reword or worded differently. Now this is all the info you need 99.9%. Last edited by 3NDLESS; 07-17-2017 at 09:42 PM.. Reason: More information found. |
07-18-2017, 04:22 PM | #5 |
I doubt the OP has r32 GTRs.
Post a pic and we can help you identify the calipers. It sounds like you have R32 GTS brakes which use a 280mm rotor similar to Z32TT and S14SRs as listed. Sent from my iPhone using Tapatalk |
07-18-2017, 04:50 PM | #6 |
R32
GTS-4 280x26mm ? GTST 280x30mm 297x18mm GTR 296x32mm 297x18mm GTR V-Spec 324x30mm 300x22mm
| 92 S13 Hatch | 92 S13 Coupe | 95 S14.5 | |
07-18-2017, 10:13 PM | #8 |
http://zilvia.net/f/showthread.php?t=169695
Go ^ and upload your pictures to something like imgur or imageshack. Avoid photobucket because its a pos now. |
07-19-2017, 08:52 AM | #9 |
you just need z32 rotors. not the 26mm thickness, but the 30mm thickness.
you can special order gtr rotors for that extra thickness if you indeed have gtr calipers, but its not worth the wait. no one states-side will stock them, or very few will. |
07-19-2017, 09:26 AM | #10 |
All R32 GTS-t's use 30mm rotors
This a BNR32 Caliper this is R23/Z32 aluminum Caliper 26 and 30mm look identical
07-19-2017, 11:49 AM | #11 |
Trader Rating: (106)
Feedback Score: 106 reviews
R32 GTR calipers use specific rotors, 30mm Z rotors will not work. To the best of my knowledge the GTS-T's did use 30mm rotors, but the diameter is larger (29x mm vs 28x mm). You need to know for sure what calipers you have so you can get the right rotors, which will not be cheap or easy to find. As shown in the post above the GTR calipers have no fins on them...
07-20-2017, 12:00 AM | #13 |
thats shit advice
i am posting a screengrab from the older DBA catalog. if you cant figure out what you need from this, then you need to stop modifying cars. you can get rotors from stillen if you want to be bent over, or try ebay UK |
07-20-2017, 08:37 AM | #15 |
Thanks for all the help and advice..the caliper i have look like the gold caliper on the pix above.it does have fins and it seen to be a gts-t 30mm aluminum caliper.
08-01-2017, 01:46 AM | #16 |
And people used to think 26mm and 30mm z32 calipers were the diameter of the physical pistons . Some people Mis represent facts. It's indeed the size or thickness of rotors each type will accommodate.
Im immune to bullshit....so put your shovel away. |
