Old 02-05-2017, 11:43 PM   #811
rawgarage
Banned from the Marketplace
Trader Rating: (75)
Feedback Score: 75 reviews
Congrats on getting settled back in
Old 02-06-2017, 08:55 AM   #812
idlebad
idlebad is an unknown quantity at this point
The fleet looks great altogether! Forgive me if I missed it, but what all do you have done to the coupe?
idlebad is offline   Reply With Quote
Old 02-06-2017, 11:29 AM   #813
ehhhregartless
ehhhregartless is making a name for him/her selfehhhregartless is making a name for him/her self
And the SR86? That's the one that still needed some work to get going right? Regardless that's a great Nissan fleet. I can see lots of hard work paying off these pictures.
www.zeedakay.com
IG: @zeedakay
ehhhregartless is offline   Reply With Quote
Old 02-06-2017, 06:53 PM   #814
Sileighty_85
Sileighty_85's Avatar
Domo, Feels good to have a big home but miss Japan soo much :/
Domo coupes was reincarnated from my fastback.
Got its own build thread
http://zilvia.net/f/showthread.php?t=178498
SR86 runs and drives, just needs somethings redone to make it better.
But I am sad to report that come the 18th the Hachi will be sold
I just don't have room for that car up here and building the R32's are gonna take all my attention, so it will be going to a better home.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 02-06-2017, 07:06 PM   #815
angrychicken!
angrychicken!'s Avatar
angrychicken! is an unknown quantity at this point
This thread is so full of win. Fucken epic that it all started in Japan and continued state side.
I'd love to hear more about that G-Sensor once you have more seat time. Looking at all the options to there, what made you go with the do-luck?
I'm considering one for my bnr32, but the "tarzan g-box, but I'm still researching the various options.
Is there a huge price difference in small items like this in Japan vs the USA? I'm doing a trip later this year. I'll be hitting some shops for fun and would love to bring some smaller items back.
angrychicken! is offline   Reply With Quote
Old 02-16-2017, 10:39 PM   #816
Sileighty_85
Thanks man lol,
Haven't had much of a chance to put to test on a track but from dailing it it's a lot more senstive then the analog one, which is good.
Depends on what to are looking for and how much. Buying misc parts and having to pay companies to ship them state side adds up a good chunk of change. So buying yourself there could save you a few hundred bucks
後輪駆動車1番
1986 SR86 - 200ish
Old 02-19-2017, 08:51 AM   #817
Bspilner
Bspilner will become famous soon enoughBspilner will become famous soon enoughBspilner will become famous soon enoughBspilner will become famous soon enough
Midori also has one out, price wise the do-luck is the winner.
Bspilner is offline   Reply With Quote
Old 03-06-2017, 11:18 AM   #818
Sileighty_85
Yep, I almost bought a Midori one but doluck having one over 10,000¥ cheaper I decided to go with them.
Finally got pads for the brembos and was able to bolt them up and utilize the stock hardline with a bit of flexing lol
Need to buy some extended studs so I can use a slip on spacer since the 15 mm bolt on spacer is too much.
Damn that's a whole lotta brake haha
後輪駆動車1番
1986 SR86 - 200ish
Old 03-25-2017, 07:19 PM   #819
Sileighty_85
after scouring through all my parts boxes i finally found my long lost tension rods lol now i can take it to get an alignment ^_^
When i installed the brembos i had to run a spacer to clear the rim, putting a 15 mil on there pushes the wheel out a little bit too far than what i like.
So bought some gktech extended studs to use some 10 mil slip on spacers.
tried to do this without taking then brakes off, was a little worried and upset when I knocked out the first stud to find out it was hitting a dust shield around the hub.....
Pulled the brakes off and noticed a grove/cut out for removing the studs (whew)
後輪駆動車1番
1986 SR86 - 200ish
Old 03-25-2017, 09:49 PM   #820
Will.
Will.'s Avatar
Will. is an unknown quantity at this point
are you planning to upgrade the BMC?
Will. is offline   Reply With Quote
Old 03-26-2017, 06:03 AM   #821
Sileighty_85
Yeah I'll be installing a BCNR33 one
後輪駆動車1番
1986 SR86 - 200ish
Old 03-26-2017, 07:15 PM   #822
Will.
Will.'s Avatar
Sweet, i'll be doing the same then.
I just put BCNR33 Brembos on my S15 for the fronts
Old 03-26-2017, 09:49 PM   #823
Sileighty_85
I have a 1" BM50 on it right now, for just the front it works pretty good, pedal feels a little softer but manageable. When I put he rears on it im sure it'll feel a bit softer than what I'd like and mess with my heel toe clutch and braking.
後輪駆動車1番
1986 SR86 - 200ish
Old 03-29-2017, 08:14 PM   #824
Sileighty_85
lots of electrical work lately, finally getting around to fixing these old gremlins.
DS window would sometimes not work, kinda the Typical S13 Amp problem.
Cleaned the contacts on the relays and reflowed a broken solder joint on the PCB pin.
Works like a charm now
Then the one I dreaded, the Blend door motor. Controls the temperature for the HVAC.
most of the time it was unresponsive and id have to reach across and wiggle the plug to get it to adjust.
relowed all the broken solder joints and BAM good as new
後輪駆動車1番
1986 SR86 - 200ish
Old 03-30-2017, 06:46 AM   #825
drftngs14
drftngs14 is an unknown quantity at this point
Always enjoy jumping back in this thread! One of my favorites here. Nice to see you're back and settled, let me know if you make it down to Charlotte! There's quite a few R32s down here now
drftngs14 is offline   Reply With Quote
Old 04-02-2017, 05:17 PM   #826
Sileighty_85
Thanks man, yeah still workin on that, still really miss Japan though
Will do!
Finally got an alignment done after finding my front tension rods.
Then was able to find a replacement fuel filter at autozone
Yeah it's about that time
This showed up in my driveway last week. My buddy just came from Misawa as well and brought back a Pulsar GTiR.
Lifted up his carpet to find the absolute worst rats nest of wiring I have ever seen from a Japanese dude.
This was all the extra wires I ripped out.
Much better
後輪駆動車1番
1986 SR86 - 200ish
Old 04-02-2017, 08:21 PM   #827
gostrider
gostrider is an unknown quantity at this point
Nice work!!! Subscribe
240 with illegal engine mod.
gostrider is offline   Reply With Quote
Old 05-07-2017, 08:02 PM   #828
Sileighty_85
It's been a hot minute since I've been able to do anything with the engine. Trying to get use to living in the US now, living overseas I was getting spoiled with getting paid COLA money (Cost Of Living Allowance)
But Finally able to get some big priced items to get the engine one step closer to be finished.
Tomei springs and retainers. Can finally finish the valve train until the engine is running on stock cams then look into upgrading those.
ARP head studs, finally get the head bolted down and start bolting on the intake manifold and turbos once I buy some ARP manifold studs.
Got some bolts for the rear brembos.
後輪駆動車1番
1986 SR86 - 200ish
Old 05-07-2017, 08:19 PM   #829
gostrider
What alignment specs do you use ? Since R32 don't come to the US
Old 05-08-2017, 07:04 AM   #830
Sileighty_85
The guy that does alignments up here locally is apparently the guy to go to for alignments. I just told him to give me good tire wear cornering abilities.
But essentially I don't think it should be much different than an S13
後輪駆動車1番
1986 SR86 - 200ish
Old 05-08-2017, 07:25 AM   #831
RalliartRsX
Trader Rating: (32)
Feedback Score: 32 reviews
Zero toe all around and camber as the heart desires vs tire wear
Shouldn't be much different than a standard 4wd alignment
Old 05-14-2017, 05:04 PM   #832
Sileighty_85
So finally after a year probably I'm finally making headway on the RB26.
Finally was able to have some free time and install the Tomei springs and retainers and bolt the head down.
My work bench lol
Happy to see that after 1 month of being on the sea the cylinder walls were rust free.
Copper Gasket spray on the HG
ARP's trq'd
At a stopping point since its mothers days lol. Should probably spend some time with the wife
後輪駆動車1番
1986 SR86 - 200ish
Old 05-15-2017, 06:52 AM   #833
sixmassive
sixmassive is an unknown quantity at this point
coming along nicely over the years
sixmassive is offline   Reply With Quote
Old 05-15-2017, 10:29 AM   #834
bardabe
bardabe's Avatar
looking good man, keep it up!
Review Thread
bardabe is offline   Reply With Quote
Old 05-21-2017, 08:27 PM   #835
Sileighty_85
Thanks guys, just really hates it's taken this long to get to this point :/
Tried to get intake bolted up today but seems I have misplaced the ITB's somewhere in my shit ton of parts and boxes:/
When for a ride today and clicked the Up switch on the DS window to only hear the motor turn and the window not move...... Yey -_-
Pulled the window assembly to find the the clutch packs in the motor cracked.
Luckily I have spares, so swapped in a spare and it's good to go now.
後輪駆動車1番
1986 SR86 - 200ish
Old 05-22-2017, 06:21 AM   #836
RalliartRsX
Trader Rating: (32)
That is such a bizarre failure
Old 05-23-2017, 06:06 AM   #837
Sileighty_85
Yeah that's the first one Ive seen break.
Normally its the motors that seize
後輪駆動車1番
1986 SR86 - 200ish
Old 06-10-2017, 09:34 AM   #838
Sileighty_85
Finally nearing completion.
Got the Tomei cam cap bolts installed and cams bolted in. Just need to order a water pump, timing belt, some ARP exhaust bolts and find out where I hid my ITB's and can finish this thing.
後輪駆動車1番
1986 SR86 - 200ish
Old 06-10-2017, 10:05 PM   #839
tricky_ab
tricky_ab's Avatar
I hope you end up finding those ITB's sooner then later. Going by the pictures posted, it's going to be quite the treasure hunt.
Instagram
Back for round two... 4 doors this time around...
Old 06-11-2017, 06:09 PM   #840
DJTTon
DJTTon's Avatar
DJTTon is on the path to ruinDJTTon is on the path to ruin
I see you got some new wheels + spacers for the G35? Im starting to throw mine on as well. Definitely loving the look with the OEM rays wheels
Skurr Skurr
DJTTon is offline   Reply With Quote
