Old 09-10-2015, 03:43 PM   #1
p00t
p00t's Avatar
p00t is an unknown quantity at this point
s13 Old Susp Parts, RSR Springs, Koni Yellows
These are some parts from my previous suspension setup.
RSR Race Springs (rate: 5k front/4.5k rear) - $100 shipped
Heres how the drop looks:
To make these springs work properly:
1. You will need to use an adjustable type shock, if you use GR2s or stock shocks you will likely have a very bouncy ride.
2. You need to cut the stock strut bumpstops on the front or use a shorter Koni bumpstop. Otherwise you will have insufficient suspension travel (again bouncy). Example:
Koni Yellow Sports (Front inserts, externally adjustable, PN: 8641 1364Sport) - SOLD
Koni Yellow Sports (Rear, adjustable, PN: 8040 1081Sport) - $BO
I have one rear that is in good operating condition (minus the surface rust) and one that is blown. You can possibly have the bad one rebuilt. Or just buy the good one if you are already running yellows and need a spare.
They have surface rust but nothing that affects the integrity of the part. They include the bottom spring perches which they do not include when new. They also have the top mounting nuts and plastic bumpstop washers.
Nismo Top Strut Bushings - $BO
One has a worn bearing with play, the other bearing is worn but no play. To me it seems like the bearing can be replaced if you spend the time to investigate. The bushing rubber in very good shape and not worn or dried out. It is stiffer than stock.
s13 rear knuckles - $BO
Dust shields are cut-up and rusty, they should be removed or replaced. Everything else is in good shape including the bearings.
Current Crazy: KA with SR56 and meth injection for HDPE and steet duty
p00t is offline   Reply With Quote
Old 09-10-2015, 07:03 PM   #2
gills
gills's Avatar
gills is a jewel in the roughgills is a jewel in the roughgills is a jewel in the roughgills is a jewel in the roughgills is a jewel in the roughgills is a jewel in the roughgills is a jewel in the rough
PM sent.
You sure that those are the Race springs? Sure looks like a lot of coils for them to be that stiff. Can you measure the wire diameter by any chance?
gills is offline   Reply With Quote
Old 09-14-2015, 05:08 PM   #3
p00t
p00t's Avatar
Yes they are. I'll send you a PM.
Old 10-18-2015, 07:43 PM   #4
p00t
p00t's Avatar
bumpy
koni, springs, suspension
