09-27-2012, 05:24 PM | #1 |
Help !!! S14ka24de to s13 swap
Hello guys, I'm having starting issues with my swap S14 engine/s13 transmission and I'm using my stock dohc wiring harness(top and bottom) with the stock s13 ecu. I noticed there's like 3 plugs in the back that don't hook up at all, I got the car to start but it died shortly after and only because I sprayed starting fluid into the TB. I don't know if it may be a wiring issue or just a bad sensor somewhere any help/comments you guys have is greatly appreciated I'm located in okc as well if you have extra time and can fix it you'll be compensated for your time.
10-02-2012, 11:29 AM | #7 |
I've heard that between s14 kas and s13 has there are things you have to change if you run s14 ka > s13 wire harness.
I've heard but am not positive that there are a couple different plugs on the intake mani. and the distributor is different somehow i was told..but i never really cared to look into it since its a pretty pointless swap |
10-02-2012, 11:46 AM | #8 |
Where in the "back" are those plugs that are not connected?
I have swapped S13 KA's into S14's and never the other way around. But every time I did I used my S14 intake manifold and S14 distributor. Did you swap your S13 intake manifold & S13 distributor over to your S14 motor? |
10-02-2012, 11:53 AM | #9 | |
and to the op deffinatly check for fuel first. make sure the injectors are all working i had a ka the was running on 2 cylinders from bad injectors lol. report back with your findings from this. and btw did u pull the dizzy out at all? if you did. double check its at TDC. feel free to pm me with questions -Mike |
10-03-2012, 08:26 AM | #11 | |
240sx, ka24de, swap |
