Old 05-19-2014, 08:39 AM   #1141
FutureFab
Trader Rating: (32)
FutureFab is an unknown quantity at this point
Feedback Score: 32 reviews
Good luck on your 26 swap, I think you got it.
1. The shifter sits in the tunnel cut out just as it should. Its the awd transfer case that's the issue.
2. I would ditch the 20 trans unless you are totally out of money. Swap to a 25 trans and be done. Shifter lines up great, just beat the trans tunnel mouth the fit bell housing. When you think its big enough, hit it some more.
3. I make my own piping, can't testify on any kits figment. I suggest learning to tig weld. Not expensive at local college. Something you can use the rest of your life.
4. I hate eBay too, buy if you can't weld, then try it out or McKinney has a pipe for 26.
5. Again, I made my mounts so can't testify on other mount kits. If you have a rb20 in already, the 26 will fit too with the same kit.
6. Any of those Ecus will work, just depends on your mods. The first 3 are retunable which is mandatory in my eyes. The mines are good too, but you are limited to what its tuned for. It would be my last choice, or a short term ride at the most.
futurefabrication.com
FutureFab is offline   Reply With Quote
Old 05-19-2014, 10:29 AM   #1142
Linux2501
Linux2501 is an unknown quantity at this point
Thank you FutureFab I am pretty good a MIG welding at the moment I picked it up and just started doing it and I am wanting to take a class as soon as I get the chance in tig just havent had the funds the past few years, I was thinking about making the pipes myself but I dont trust my welds enough for charge piping, but surely some couplers over the welds shouldnt hurt.
And I am thinking about reusing the kit and I didnt know if they where the same or not, did you do this? or hear about it?
I won the mines m/t ecu for the 26 for about 130 so Its pretty cheap as a backup if i dont go with a power fc do you have any previous usage with one?
Linux2501 is offline   Reply With Quote
Old 05-19-2014, 12:45 PM   #1143
FutureFab
Trader Rating: (32)
Maybe there is someone you can have fab the pipes for you. Shouldnt be very expensive, especially if you have enough alum pipe in good shape to reuse.
The mount bosses are the same, just bolt it on. Just watch out for the 26 Awd alum pan. You can put on a 25 pan/pickup with a little messing around.
I've used both ecus. The mines is fine, I'd get the engine running on stock ecu first tho. Once you drive it and get a baseline feel for it, then toss the other on and see how it feels. A wideband O2 is a good investment to see what's going on Afr wise. Keep an ear out for knock, because you don't know what octane or elevation the ecu was tuned for. This is why pfc/aem/ect is nice, it can be tuned to your specific everything. Add a big turbo and injectors, just retune for it, no guessing, no bandaids.
Also, if you don't plan to make gobbs of Hp then you shouldn't need to rebuild it, unless its already toasted.
I would however read up on Rb oil problems and some fixes. Hopefully you got a R33 or newer Gtr engine so it has the oil drive flanks fixed from the factory.
Old 05-20-2014, 06:08 AM   #1144
Linux2501
The reason why I am rebuilding it is because when I first bought a used motor I thought it had been babied...then it blew a hg. So I bought another 20 and I rebuilt it from bearings up and was much happier with how the motor ran and how much healthier it sounded and that's why I am rebuilding the 26 to get the collar issue fixed
Old 05-31-2014, 09:07 PM   #1145
240Z28
240Z28's Avatar
240Z28 is an unknown quantity at this point
will the z31 motor mounts fit the rb20??
SPEED KILLS!!
Drive a Honda and live forever!!
240Z28 is offline   Reply With Quote
Old 05-31-2014, 11:35 PM   #1146
Linux2501
Alright I belive it was on here that I asked about the oil pan issue with the 26/20 swap i noticed the bolt holes will fit the 20 oil pan on the 26 block but when i go to put it on the pickup is not in the correct spot. I thought about cutting it but that would of course damage the baffle plate.
I also another question I thought alot of oiling issues of 26s where the crank collar issue and also the baffle plate. well I took my pan off my 26 tonight and there where baffle plates on the bottom of the girdle and on the pan, I thought there wasnt any baffles and that caused the oil pump to run dry sometimes. any suggestions on the sump situation?
Old 06-03-2014, 08:53 AM   #1147
redline racer510
redline racer510's Avatar
redline racer510 is on the path to ruinredline racer510 is on the path to ruin
I have the syko performance mount kit for my rb s14 and it is extremely high quality but the customer support is non existent, I tried getting a hold of them for like a week when I was doing a swap trying to order there piping kit and ended up making my own
WARNING: User has a low tolerance for stupidity. Post at your own risk.
redline racer510 is offline   Reply With Quote
Old 06-16-2014, 09:30 PM   #1148
fearlessKouki
fearlessKouki is an unknown quantity at this point
Hello, I am in process of wiring my rb25det in s14. It was previously wired but when i got the engine from the seller the wiring was a mess.
So my question is I have 2 wires coming out of a little brown square box/plug by the ecu connector. 1 is black with red strip and 2nd is black with yellow strip. Are these ground wires?
fearlessKouki is offline   Reply With Quote
Old 06-17-2014, 07:01 AM   #1149
baube
baube is an unknown quantity at this point
this box is a "ground block"
baube is offline   Reply With Quote
Old 06-17-2014, 07:23 AM   #1150
fearlessKouki
So the 2 wires coming out would be grounded on motor?
Sent from my SCH-I545 using Tapatalk
Old 06-18-2014, 08:04 PM   #1151
240Z28
240Z28's Avatar
i just got an ecu from an s1 rb25, will it work for my rb20?
SPEED KILLS!!
Old 06-21-2014, 01:02 AM   #1152
khai01
khai01 is making a name for him/her selfkhai01 is making a name for him/her self
All the RB guy. My power steering pump on the Rb26dett bearing went bad and it leak fluid. Any where to have it rebuild?
What is the alternative power steering may work instead of the RARE R34 RB26dett?
A professional think a rb26 r33 power steering pump may work.
Please help
khai01 is offline   Reply With Quote
Old 06-26-2014, 10:52 AM   #1153
redline racer510
Search ka24 p/s pump on rb25 I did it to my rb25 and it works like factory.
Old 06-27-2014, 07:04 PM   #1154
silviaNC
silviaNC's Avatar
silviaNC is an unknown quantity at this point
If it is a r32. Does the ka pump will fit as well? I know crank pulley offset if different between r32,33,34
Sent from my SCH-I535 using Tapatalk
silviaNC is offline   Reply With Quote
Old 07-01-2014, 01:23 AM   #1155
terrance john
terrance john is an unknown quantity at this point
hey guys i have a rb20 and i am trying to make my tach and spedo work in my s13, i have a ws harness and im stuck at what to do if someone could point me in the right direction i would greatly appreciate it!
terrance john is offline   Reply With Quote
Old 07-01-2014, 01:27 AM   #1156
Sileighty_85
Sileighty_85's Avatar
install S13 KA VSS into tranny for the speedo.
Tach forgot I think there is a Potentiometer you can adjust for it, or install a Maxima Tach
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 07-01-2014, 01:48 AM   #1157
terrance john
i am putting in a digital nx1600 cluster. lol any other ideas for the tach?
Old 07-01-2014, 07:52 AM   #1158
Sileighty_85
Dakota Digital
後輪駆動車1番
1986 SR86 - 200ish
Old 07-01-2014, 11:32 AM   #1159
terrance john
Dakota Digital
well i know the ka vvs works with the nx1600 idk how to make the tach work tho.
Old 07-01-2014, 11:04 PM   #1160
Sileighty_85
Dakota Digital........ It does Tachs too
後輪駆動車1番
1986 SR86 - 200ish
Old 07-02-2014, 01:07 AM   #1161
terrance john
ok so wire the dakota digital 8k rpm pick up into the harness but what off the tranny do i wire the dakota digital into? thats what im asking haha my bad for being an idiot, i am awful with wiring.
Old 07-23-2014, 08:26 AM   #1162
_kouki_monster_
_kouki_monster_ is an unknown quantity at this point
So what do you guys do with ps hoses? i can make hydro hoses where i work, but my question is in the fittings there are some coiled pieces in them that were damaged. so i removed them will it function normal without? i figure they were some sort of resistor or something.
i didnt get any response in the small question thread, so i thought you would know more in this thread. Thanks for any help!
_kouki_monster_ is offline   Reply With Quote
Old 07-23-2014, 12:39 PM   #1163
fearlessKouki
I recently put in rb25det in my 1997 s14 with 96 fusebox harness (inside & outside fusebox). Using wiring specialties conversion harness. It starts up but dies right away? Any clue on what could be the problem? Thanks
Old 07-25-2014, 11:45 AM   #1164
redline racer510
Check fuel and spark.
Old 07-26-2014, 01:23 AM   #1165
240Z28
240Z28's Avatar
Is there a difference between the ka tranny bolts and rb ones?
SPEED KILLS!!
Old 07-28-2014, 11:42 AM   #1166
fearlessKouki
i have fuel and spark. I unplugged the MAF and it started and idled in limp mode. I used starter fluid and all 6 injector holes were leaking. the o ring/gasket was not properly seated. going to remove the intake manifold and screw up all 4 bolts and see if that would fix it. Hopefully that will solve the problem.
Old 08-19-2014, 08:24 PM   #1167
terrance john
can i use a rb25 oil pan on my rb20 block?
Old 08-19-2014, 08:32 PM   #1168
Linux2501
Don't see why not. Same bolt pattern. I think they use a different sump
Old 08-20-2014, 12:49 AM   #1169
terrance john
The slump is the same it looks the same
Old 08-20-2014, 07:17 PM   #1170
smellslikerubber
smellslikerubber is an unknown quantity at this point
s13
RB20
i have a mostly stock rb20. i just got it running strong but i still feel like it has a fuel issue. it has a walboro fuel pump and stock injectors. im looking to upgrade the fuel sytem and i want it to be top notch to where i only need to do it once. so im wondering what would be the best installs. 440cc injectors? or would something bigger be better. what would i need as far as fuel rail and lines? i also know i will need a FPR. im also started to look into the Greddy Emanage, would that be a good option as well? just looking for a good set up. i wanna make somewhere around 400hp when im done with the car. so suggetions and set up ideas are welcome
smellslikerubber is offline   Reply With Quote
