Old 12-11-2013, 03:04 PM   #1
Balukasz
Balukasz is an unknown quantity at this point
18RG engine for sale
For sale is a complete early year 18rg engine (Needs assembly) minus carburetors. Email with questions and offers.
Engine was intended to be a period correct replacement for my 1973 Celica RA21 no expense was spared. When built engine should be close to 300HP-ish with an amazing RPM range.
Just to give you an idea of my cost pistons alone were 600 and block machining was 400, not to mention having to find the engine. Rare opportunity to own an early twin came Toyota engine that's also a hemi.
Price 1200 OBO or 1500 firm with W50 transmission (5 speed)
Here is a comparison price for engine with non-performance parts
RARE 18R G 18RG Engine Spec Clutch and Flywheel Koyo Radiator Many EXTRAS | eBay
Details (Read these)
Engine block cleaned and bored to 91mm (done by Yo at Contemporary Auto Machine in HB)
Crank has been balanced and polished (Specific measurements are on a tag attached to crank)
Also been cleaned by Yo
New in the box bearing set for crank
New in the box bearing set for connecting rods
Stock connecting rods (will need new bushing for pistons, Joel at ToySport has them)
Wiseco 91mm piston set (New in box, with all rings etc... High Compression pistons)
These pistons were custom designed and ordered by Joel at ToySport.
Brand new FelPro gasket set for 18rg
Original timing gears and chains
Original Aluminium timing cover
Multiple oil pans (depending on your configuration there should be one to fit your car, includes pick ups)
Early Year 18rg Cylinder Head (has larger ports, that have been ported and polished.)
Could use a once over and assembly from Joel
Custom ground CamShafts (specs unknown but they are in great condition and recommend using)
Original Valves, Springs, seats, etc...
Comes with two head covers 1 semi-polished and 1 with the original black matte finish.
multiple intakes included (short carb, long carb, fuel injection, etc..)
Original exhaust manifold.
Original and complete distributor assembly
You will have to purchase Spark Plug wires and Plugs
Original water pump and housing
Original Oil Pump (includes new filter)
Original Flywheel
Unknown clutch and pressure plate
Original Starter
Original Alternator
Original Fuel pump
I'm sure there is more, but that's all I can remember.
Balukasz is offline   Reply With Quote
Old 01-23-2016, 12:09 AM   #2
austinvw
austinvw is an unknown quantity at this point
Talking 18rg
Is this motor still available?
austinvw is offline   Reply With Quote
18rg, engine, twin cam
