Old 07-17-2012, 07:57 PM   #1
donjoel
donjoel is an unknown quantity at this point
sr20 Trans won't line up.
Just installed the sr20 the other day on my 89 240 hatch,
and to my surprise the transmission didnt line up straight.
It was a real pain trying to get the passenger side mount
to go in the hole, and after it did right away i could tell the
engine was crooked. after so many tries of kicking the trans
towards the passenger side, it just kept bouncing back to
the drivers side. so i decided to try and and just put the
crossmember on there like that to hold it straight, but all
of the bolts would not want to go in.
my motor mounts i got are for the ka24e from o'reillys
and the trans mount i got from my old engine.
So any suggestions on how to make motor and trans straight? It sits like 1 inch towards the driver side.
donjoel is offline   Reply With Quote
Old 07-17-2012, 08:02 PM   #2
teh smithers
teh smithers's Avatar
teh smithers is an unknown quantity at this point
My god, Holmes, I think we've found it. Get mounts that were designed for the SR!
teh smithers is offline   Reply With Quote
Old 07-17-2012, 09:32 PM   #3
donjoel
theres a sr20 swap guide on here and they state that motor mounts are the same for
ka24e de and sr, and ive read it it other places too, plus i compared them to the messed up ones that were on my sr and they were identical.
Old 07-17-2012, 09:35 PM   #4
roboticnissan
roboticnissan's Avatar
roboticnissan is making a name for him/her selfroboticnissan is making a name for him/her selfroboticnissan is making a name for him/her self
Yeah they are the same. But check out your motor and see how its crooked. My bet something is messed with over.there. and you're looking at the tranny
roboticnissan is offline   Reply With Quote
Old 07-17-2012, 10:07 PM   #5
Slammed Assassin
Slammed Assassin's Avatar
Trader Rating: (34)
Slammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud of
Feedback Score: 34 reviews
Send a message via AIM to Slammed Assassin
ka and sr use the same mounts bruhh!!
Slammed Assassin is offline   Reply With Quote
Old 07-17-2012, 10:35 PM   #6
teh smithers
I'm aware of that, but I wouldn't trust KA mounts from O'Reilly to work on an SR, even if they are "identical" as the OP stated. I'm probably wrong though, and the issue is somewhere else.
If you can, pull the motor/transmission back out and reinstall it. Pain in the ass, but you'll have a great view of whatever's wrong.
Old 07-17-2012, 10:51 PM   #7
memphis180sx
memphis180sx is an unknown quantity at this point
god your a idiot. unless your chassis is tweaked then you should have no problem getting a trans on under the car i would have left the trans on the motor and kept trying or you could drop the subframe stick the motor on that and try putting in in with the subframe attached but thats just an idea.
memphis180sx is offline   Reply With Quote
Old 07-17-2012, 10:55 PM   #8
mendozasport
mendozasport's Avatar
mendozasport is an unknown quantity at this point
unless you have 2 left side motor brackets or 2 right side brackets , that would make the motor shift, not sure on sr's but ka's are marked left and right check that first
mendozasport is offline   Reply With Quote
Old 07-17-2012, 10:58 PM   #9
teh smithers
You're an*
Old 07-18-2012, 08:55 PM   #10
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Is it possible you got the mounts switched? I'm kinda in the same boat with my KA. I dropped my tranny to change the clutch, loosened the engine mounts so I can angle the engine a bit when I was putting the tranny back in. When I got everything in, the damn tranny was shifted to the driver side like yours. No idea what the fuck happened.
CLICK HERE!!!
Old 07-18-2012, 09:09 PM   #11
darkroom1428
darkroom1428 is an unknown quantity at this point
Is the trans an engine bolted flush. I have tried to bolt up a trans an engine many times forgetting to remove the guides on the left or right of the block.
darkroom1428 is offline   Reply With Quote
crooked, mounts, sr20det
