Old 11-18-2020, 09:12 AM   #1
crashedintowall
crashedintowall is an unknown quantity at this point
SR20-DET Breaks up at 5k rpm
Hey guys,
I recently imported a s14 Silvia from Japan. The motor keeps breaking up at about 5k rpm. If you give it a little gas and just slowly raise the rpm in neutral it doesn't break up. I just did spark plugs and that didn't help. Any Ideas on what it could be?
crashedintowall is offline   Reply With Quote
Old 11-18-2020, 09:20 AM   #2
S14rebuild
Check fuel pressure at 5k rpm, check for boost leaks.... ckil.pack condition and voltage
Old 11-18-2020, 09:28 AM   #3
2_Liter_Turbo
2_Liter_Turbo's Avatar
Trader Rating: (28)
2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough
Feedback Score: 28 reviews
What gap did you set the plugs to? Definitely check for boost leaks and fuel pressure as mentioned above. It sounds like you're either blowing out spark or getting a boost leak under full boost (typically a hole in a coupler or loose coupler clamps).
96 S14: Grip Track Car
90 R32: Bucket List Car
92 S13: Just for Fun Car
Instagram: @SS.Maxey
2_Liter_Turbo is offline   Reply With Quote
Old 11-18-2020, 09:42 AM   #4
crashedintowall
Spark gap was set to .030 the coil packs look to be in good condition but I'll check them with a voltage meter. I'll check for anything obvious for boost leak and try and find someone with boost leak smoke machine. Thanks!
Old 11-18-2020, 12:53 PM   #5
S14rebuild
Meant battery voltage at 5k rpm
U can make a diy boost leak tester check out utube for that... coupler, pvc, air fittings and compressor... soapy water. Done
Old 11-19-2020, 10:20 PM   #6
LtSlayer
LtSlayer is an unknown quantity at this point
make sure your tps is set correctly. My buddy had an s14 or s15 sr that had other problems but one of em was that it would bog at ~3k then boost to 5ish but hang out around there. I knew this wasn't right since my7 s13 revs to over 7k. I cracked an arm but it happens lol. Look up a guide on the tps setting. It's something simple that's often overlooked. I know we did. Good luck.
LtSlayer is offline   Reply With Quote
Old 11-24-2020, 09:17 AM   #7
Slideurmom
Slideurmom is an unknown quantity at this point
Check the timing chain , I had a similar issue with my vct sr. I was off a tooth and boom fixed
Slideurmom is offline   Reply With Quote
Old 11-26-2020, 11:54 AM   #8
!Zar!
!Zar!'s Avatar
Have you changed the fuel filter?
Check the spark plug condition & gap?
Is your maf clean? Try a different maf.
Old 11-30-2020, 08:51 AM   #9
crashedintowall
I just changed the spark plugs, fuel filter and put a new maf in. I still need to check for boost leaks and check fuel pressure at 5k rpm.
Old 05-29-2021, 09:00 PM   #10
240boosted
240boosted has a little shameless behavior in the past
Def check plugs and look for boost leaks mine had same issue
240boosted is offline   Reply With Quote
issue, motor problems, s14, silva, sr20 blacktop
