09-06-2012, 02:19 PM | #1 |
1995 S14 KA-T for sale Fully built
This has been my pride and joy for years always garaged kept and driven only in the summer months I have spent well over 15k into this car. I rarely get to enjoy it and it time to let her go to a new home. Wiseco coated, forged pistons (9:1) Eagle forged H-beam rods block tanked, cylinders bored 1.0 mm over (90mm bore), fully component balanced NEW cylinder head w/Wiseco MLS headgasket PDM Racing stage 2 Tri-flow cams, 272/278 advertised duration All Supertech valvetrain, SS nitrated, 1mm oversized valves, dual SS springs, Ti retainers and seats Mild porting and de-shrouding done to the head with 3 angle valve job Toga high volume oil pump, and new lower front cover, toga high performance bearings 740cc DW injectors Walbro 255lph fuel pump Fuel Pressure Regualtor with a in-line gauge Z32 Maf with adapter plate Apexi air filer JW Ecu ISIS V2 Tubular Exhaust Turbo Manifold Garret Gt3071r (A/R .50) (.86) exhaust Internally Gated (14psi) Oil feed and return SS lines with oil restrictor Coolant feed and return (AN) CX intercooler with HKS SSbov Koyo Aluminum Radiator Altima fans and DIF fan controller Nismo thermostat Silcone coolant hoses JGS motor and trans mounts Excessive lower motor mount brackets MR. Gasket copper exhaust gasket Oil,Coolant and Boost Gauges Megan 3-inch downpipe Catco 3-inch Cat Apexi Megaphone Exhaust Fully built Auto trans by IPT Suspension Rear Spc UCA Front Tein tension rods J30 Diff Also the car has AC Alarm: Viper 5902 alarm system Viper Smart Start - has about more than 6 months left on subscription - can track car using iPhone, Android, or Blackberry Window Automation System 530T for Viper System - when car is locked windows roll up automatically Digital Tilt Motion Sensor 507M for Viper System - calibrates when car is turned off and if car is raised when alarm is on, it will go off Backup Battery Siren 515R for Viper System Backup Battery System 520T for Viper System Audio Glass Break Sensor 506T for Viper System Audio: Panasonic 200w Motorized AM/FM/MEA Model# CQC8803U Hybrid Imagine 6.5" Convertible 2-way Coaxial/Component System audio speakers Front and rear ( BTW the word convertible means that you can separate the tweeter from the 6.5 mid-bass speaker which I did in the front and installed the tweeter in the stock A-Pillar location.) Signal Auto Carbon Fiber Center Taillight Cover (Pretty Rare) Parts not installed: Brembo Evo 8 calipers with adapter plates (fronts only) Megan racing lower control arms for the rear (BNIB) Asking 5,500 Firm no trades. __________________
http://zilvia.net/f/chat/354550-nothing-easy-build.html Last edited by koukidriver; 01-06-2013 at 08:57 AM.. |
09-08-2012, 02:03 PM | #3 |
^^^ Thank you
http://zilvia.net/f/chat/354550-nothing-easy-build.html Last edited by koukidriver; 09-14-2012 at 02:46 PM.. |
09-10-2012, 08:30 AM | #5 |
^^^ About 375hp at 14psi. Can easily handle 4 to 500hp. The and trans is built to hold 600hp and the engine can go beyond those numbers.
http://zilvia.net/f/chat/354550-nothing-easy-build.html |
09-14-2012, 02:45 PM | #7 |
^^^ I don't have any at the moment as far as the interior goes its all stock inside except for the head unit. I was going for the sleeper look stock body and stock interior. Just pm me if you want to see interior pics.
09-17-2012, 04:41 PM | #8 |
Price drop: 7,000. She need a good home.
09-20-2012, 07:48 AM | #9 |
Last and Final Bump
09-26-2012, 07:19 AM | #10 |
$6,500 firm !!!!
10-03-2012, 10:46 AM | #12 |
Pending sale
10-05-2012, 10:34 AM | #13 |
Another buyer flaked lol , why come look at the car when you don't have the cash for it.
10-13-2012, 10:17 AM | #14 |
Last Bump !!!
10-16-2012, 09:38 PM | #15 |
To the top . . . . .
10-21-2012, 07:39 AM | #16 |
I have had alot of interest in the car but I just want to make it clear yes this car is automatic but far from a stock trans it has been fully rebuilt and modified by IPT Performance its was magna-fluxed and cryo-treated. Along with a high stall converter, modified valve body, trans cooler and finally filled with AMSOIL synthetic trans fuild. I have receipts for all of the work done trans alone was just under 5K parts and labor. I was informed that 600hp would be a breeze for the transmission. I opted to go this route because the car was going to be used for drag racing.
Here is the link to the site: Nissan | Infiniti | High Performance Automatic Transmissions | Racing Transmission
11-02-2012, 10:30 AM | #18 |
Price reduction $6,000 (Due to Sandy) Btw I have the car garaged so thankfully everything is fine with the car.
11-18-2012, 06:51 AM | #19 |
To the top
11-30-2012, 04:18 PM | #20 |
Bump it up...
12-05-2012, 10:58 PM | #24 |
This is the kinda sale post that makes me want to blow my fucking brains out for buying my car for 5k. What the fuck was i thinking, my car looks like a pile of dicks with a stock sr swapped in like shit.
12-16-2012, 03:22 PM | #25 |
Yes its still available the built trans was just under 5K when u think about you are getting the rest of the car for free. And for anyone who doesn't fancy auto just swap it over to a manual. I have a lot of interested buyers no one has been able to come up with the cash. My loss is your gain. Over 15 k invested I have receipts for the trans as well as everything else.
12-22-2012, 01:27 AM | #26 |
All PM's replied too.
01-04-2013, 07:51 PM | #27 |
Car needs a good home, Not meant to be a garage queen.
$5,500 takes it. (Parts not installed will not be included.)
01-07-2013, 04:48 PM | #29 | |
OP, what a deal!!! some one buy this and slap this a 5 speed and yo're set!! GLWS |
01-15-2013, 08:40 PM | #30 |
^^^^ Pretty much. But a stock 5-speed won't last long,lol.
