Old 05-24-2009, 12:51 PM   #1
Mfox
Mfox's Avatar
Mfox is an unknown quantity at this point
KA s13 electrical won't start, radio wont turn on, grounded properly
Here is the issue I am having.
Bought everything separately getting this 240 rolling.
92 shell chuki
93 ka24de
apexi stg 2 clutch
I did the engine mounting and all the wiring myself. After the whole car was complete the car turned on first crank no problem. After the test drive and a car wash the car just died on me.
The car appears to be dead.
*clutch started
*used jumper cables
*starter works, by using the jumper cables directly towards the battery in the positive poll.
*Gas pump, radio, and starter are not getting power.
* made sure the harnesses are grounded
* check fuses all works except for two but replaced with two working one but dont get 12 volts back when i test it with a volt meter.
I am officially with a headache towards what it can be.
Mfox is offline   Reply With Quote
Old 05-24-2009, 11:04 PM   #2
slider2828
slider2828's Avatar
ECU codes? Sounds like your ECU fried... Check ALL your fuses under the hood. Inspect them closely.
Turn and Burn!
battery, electrical harness, fuel pump, ground, ignition
