Old 12-23-2015, 02:35 PM   #1
rwpowell015
rwpowell015 is an unknown quantity at this point
Wheel/Tire Sizes FC RX7
I tried running some 17x9.5 +15 battles up front w 235/40s on stock fenders and I guess I was being a little ambitious as they have a bit too much poke and will rub like crazy at full lock.
What wheel/tire combo are you FC guys up front? Pics would be helpful. Would bumping down to a 17x9 up front rectify the situation or do I need to go narrower still?
Sent from my SM-G900V using Tapatalk
rwpowell015 is offline   Reply With Quote
Old 12-23-2015, 03:10 PM   #2
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
The width of the wheel will make no difference if you're running the same tire. You need a higher offset. If you would post a pic with a tape measure showing the poke for reference it would likely lead to more helpful replies. This is a Nissan forum, most of us aren't RX7 experts.
Old 12-23-2015, 03:14 PM   #3
rwpowell015
Working on getting pictures, they sit a little better in the rear. They only came in one offset for the 9.5s, the 9 is a +30. I realize it's a Nissan forum, but there are a few rx7 guys lurking around.
Old 12-23-2015, 03:30 PM   #4
rwpowell015
Old 12-23-2015, 04:15 PM   #5
reallygood101
reallygood101 will become famous soon enoughreallygood101 will become famous soon enoughreallygood101 will become famous soon enoughreallygood101 will become famous soon enough
running extended ball joints and neg camber will help you fit them but you'll need to pull the fenders a bit still, 17x9+30 would probably wrk better but i guess it depends on wat your trying to do, i run 17x8+5 205/45 25mm extended ball joints and a good amount of neg camber i also have modded knuckles so with the setup i have the inner barrel doesn't hit the sway bar at full lock
reallygood101 is offline   Reply With Quote
Old 12-23-2015, 04:16 PM   #6
rwpowell015
Drift/fun street car. Not daily driving it. What car are you using? Pics?
Old 12-23-2015, 09:28 PM   #7
racepar1
racepar1's Avatar
Pull the fenders a little, more camber, smaller tire (225/45). That's not that bad, you could make it fit without doing anything stupid or extreme.
Old 12-24-2015, 05:54 AM   #8
bermiqi
bermiqi is an unknown quantity at this point
bermiqi is offline   Reply With Quote
Old 12-24-2015, 06:18 AM   #9
rwpowell015
I couldn't find a shop willing to put a 225/45 on around here
Old 12-24-2015, 09:13 AM   #10
jedi03
Discount should if the others dont...
Old 12-24-2015, 09:14 AM   #11
rwpowell015
I'll keep that in mind. I'm getting some bodywork done, so may just get the fenders flared while I'm at it
