Old 02-23-2010, 01:11 PM   #661
I LUV MY S13
I LUV MY S13's Avatar
Originally Posted by irritatedmax View Post
Hmmm, I am a bit confused by that. The second mark on the crank pulley is the base timing mark (0* I think). I don't recall if it indicates TDC (it has been over a year since I had to do mine). Here is what I did:
With timing light on the crank pulley and the spark pickup on the number one wire, I checked where it was firing in relation to the timing mark. It was off so I rotated the distributor to bring it back in. It was off more than that so I pulled the distributor rotated it like one tooth in the direction I needed and then checked the timing. Using the timing light, I saw it was closer, so I rotated the distributor and got it to where I wanted. (Repeated this process a few times)
It was a bit confusing at the time, but it started to make sense. Without a timing light, it is going to be quite hard to determine when your engine is getting spark.
I think your other option is to align the timing marks on the timing chain and then reset the distributor. You would still need a timing light to bring it into spec.
well this is all i could find Ka24e Timing Off? - Nissan 240SX Forums
i never took the timing chain off so the crankshaft and valvetrain should be dead on as it was before..but when i replaced the oilpump i did take off the spindle and dizzy without putting it back in the same specific order...
could you kinda explain how this gun works? i would have to go to autozone to get it later on tonight
-Jorge
I LUV MY S13 is offline   Reply With Quote
Old 02-23-2010, 02:00 PM   #662
stinky_180
stinky_180's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
you have never used a timing gun before?
the gun flashes when the number 1 spark plug ignites... you aim it toward the crank pulley and you can see what your ignition timing is at...
WheelsDirty
Old 02-23-2010, 05:15 PM   #663
Mr.Bobble
Mr.Bobble's Avatar
Mr.Bobble is an unknown quantity at this point
Anybody know where i can obtain these old center caps.. I know they are rare or what not.. even just the logo chips in the middle..
Mr.Bobble is offline   Reply With Quote
Old 02-23-2010, 06:49 PM   #664
I LUV MY S13
ok so i messed around with it a little bit more and now it just backfires even more but still doesnt start...
ive been reading on the timing gun and even watched a few vids on youtube, and all featured the car running...this will work with my car not running correct?
no ive never had a need for it
-Jorge
Old 02-23-2010, 10:13 PM   #665
stinky_180
stinky_180's Avatar
Trader Rating: (26)
the car needs to be running in order to use the timing gun
WheelsDirty
Old 02-23-2010, 10:16 PM   #666
I LUV MY S13
see thats the problem, im trying to get the car to start
-Jorge
Old 02-23-2010, 11:01 PM   #667
wh0aitznic0
wh0aitznic0's Avatar
wh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enough
Just bought a new car. 91' Hatch. Idiot kid snapped the left rear license plate bolt. And the other bolt hole apparently won't take a bolt since he's a fucking idiot. How do I go about changing the license plate bolts out?
Especially that snapped one that's still in there.
SPLparts.com * PoweredByMax.net
Originally Posted by hailandkill View Post
wh0aitznic0 -- has or had a shocker sticker on his car at one point, is asian with a gooey white center
<3
Nothing says, 'I'm broke and still trying', like aftermarket steelies.
wh0aitznic0 is offline   Reply With Quote
Old 02-24-2010, 07:57 AM   #668
datboibrad
datboibrad can only hope to improve
s15 injector seals? what do they cross too?
datboibrad is offline   Reply With Quote
Old 02-24-2010, 09:34 AM   #669
irritatedmax
irritatedmax's Avatar
irritatedmax will become famous soon enoughirritatedmax will become famous soon enoughirritatedmax will become famous soon enoughirritatedmax will become famous soon enough
Not true.
If you are cranking and getting a spark, the timing gun will work.
First, timing gun basics: there is a spark signal wire that clips on the #1 spark plug wire; there is a power that clips onto the positive battery terminal; and a negative that clips onto the negative battery terminal or any chassis ground (any metal really).
Second, using it. Hook the gun up. When you crank the car, every time the first cylinder gets its spark, the timing light will flash (flashlight type light is emitted). While it is doing this, point it at the crank pulley to determine where it is firing in relation to the timing marks and the timing indicator arm/thing. (Have someone crank it while you watch the timing marks.)
If you don't see the marks on the pulley, you'll need to adjust your distributor. If it's way off (like 180*), it will need more correction than just turning the distributor. You will need to pull it, spin the distributor a bit, re-install it, and re-check the timing.
A couple helpful things to read (for DOHC KA):
KA-T.org - The Home of 1000+ whp/7 sec Turbo KA's
BRICKHOUSE PRODUCTS
IG @brickhouse_products
irritatedmax is offline   Reply With Quote
Old 02-24-2010, 10:59 AM   #670
MisawaJason
MisawaJason's Avatar
MisawaJason is an unknown quantity at this point
You can buy or borrow an easy out kit. Basically you drill the center of the bolt and then this "screw looking drill bit" goes in that hole and backs out the bolt for you
MisawaJason is offline   Reply With Quote
Old 02-24-2010, 11:05 AM   #671
stinky_180
stinky_180's Avatar
Trader Rating: (26)
can you run wheel spacers with wheels that have two PCD (4x114 & 4x100)? 15-20mm specifically.
WheelsDirty
Old 02-24-2010, 12:37 PM   #672
killer240
killer240's Avatar
Trader Rating: (24)
killer240 is an unknown quantity at this point
Feedback Score: 24 reviews
S13 coilovers question
i know both are some good coils
but which would you get if they were at the same price used.. well kei office go for 600 the cheapest and i found some tein flex for 450 + my old suspension w/ tein springs
kei office or tein flex w/out EDFC?
killer240 is offline   Reply With Quote
Old 02-24-2010, 01:46 PM   #673
stinky_180
stinky_180's Avatar
Trader Rating: (26)
kei office...................................
WheelsDirty
Old 02-24-2010, 02:39 PM   #674
blackalicious95
blackalicious95's Avatar
blackalicious95 will become famous soon enoughblackalicious95 will become famous soon enoughblackalicious95 will become famous soon enoughblackalicious95 will become famous soon enough
does anyone know or know where i can find the dimensions for a zeta II seat.
I have an offer on the table to trade my zeta III type L for a zeta II but im scared i might not fit in the zeta II
i wear a size 36 and the type L fits me nice and snug but not uncomfortablly and since this is my daily i dont want to get something that will make me hate driving my car.
all of my searches have only turned up with dimensions for brides newer seats.
And if there is anyone around the fresno area that has a zeta II that i could test out that would be great.
blackalicious95 is offline   Reply With Quote
Old 02-24-2010, 03:48 PM   #675
g-via
g-via is a glorious beacon of lightg-via is a glorious beacon of lightg-via is a glorious beacon of lightg-via is a glorious beacon of lightg-via is a glorious beacon of lightg-via is a glorious beacon of lightg-via is a glorious beacon of lightg-via is a glorious beacon of lightg-via is a glorious beacon of lightg-via is a glorious beacon of lightg-via is a glorious beacon of light
With the combination of NRG's short hub and gen 2.5 quick release, is the steering wheel exactly in the OE position?
From the Nardi website:
(DEEP CORN)
350 mm = 80 mm offset
330 mm = 53 mm offset
Is this offset (concavity) the same for their entire lineup of concave wheels (i.e. Sport Rally), and is this measurement from outside face to outside face of the steering wheel?
Thanks
"I'm a rage-aholic, I just can't live with rage-ahol!!!"
g-via is offline   Reply With Quote
Old 02-24-2010, 04:53 PM   #676
NMs14.5kouki
NMs14.5kouki's Avatar
Trader Rating: (38)
NMs14.5kouki is an unknown quantity at this point
Feedback Score: 38 reviews
Originally Posted by fckillerbee View Post
http://zilvia.net/f/tech-talk/115916...nsion-faq.html
hope this helps, as I did not fully understand the difference. Most people that I have seen get a "drift" alignment stay around the 6.5-7 degree mark.
Pro drivers please chime in to correct me if I am wrong.
That thread just confused the hell out of me... i understand all the other suspension adjustments except caster. I can't get even a close grasp onto caster. Thanks for the thread tho it helped with other stuff.
NMs14.5kouki is offline   Reply With Quote
Old 02-24-2010, 07:31 PM   #677
P_856
P_856's Avatar
P_856 is just really niceP_856 is just really niceP_856 is just really niceP_856 is just really niceP_856 is just really niceP_856 is just really niceP_856 is just really niceP_856 is just really nice
im going to say no i think you need atleast 25mm to clear the stock studs/back hub of the wheels, if you use 15-20mm a small amount of the stock studs will stick out and hit the wheels
P_856 is offline   Reply With Quote
Old 02-24-2010, 07:56 PM   #678
repda916
repda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymore
what would cause my guage cluster lights to lag when i turn my lights on?
also what would cause my high beams to turn on when its suppose to be the regular lights and my high beam switch turn on my regular lights.
repda916 is offline   Reply With Quote
Old 02-24-2010, 10:37 PM   #679
datboibrad
plz?
msglngth
Old 02-24-2010, 10:41 PM   #680
garagelu
Trader Rating: (60)
garagelu is on a distinguished road
Feedback Score: 60 reviews
plz?
msglngth
same as KA. Just buy for any dohc ka so 91-98 240sx.
Think about it. S15 injectors are upgrades for s13 and s14 sr. s13 and s14 sr 370cc injectors are upgrades for ka-t guys. All those injectors and injector o-rings interchange.
Instagram: @garagelu
garagelu is offline   Reply With Quote
Old 02-24-2010, 11:12 PM   #681
drftkng951
drftkng951's Avatar
drftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond repute
J30/Z32 VLSD w/s13 cover is leaking.
1)which gasket do i use?
2)anyone using friction modifier for a nissan vlsd?
J.SUN
drftkng951 is offline   Reply With Quote
Old 02-25-2010, 01:37 AM   #682
hOngsterr
Bandwagon.
hOngsterr's Avatar
Trader Rating: (73)
hOngsterr is an unknown quantity at this point
Feedback Score: 73 reviews
people always use silicone to seal up diff covers.
- Hong
OCD isn't so bad just means you'll spend more money then most people, but you'll have a quality car not a POS put together with POS parts.
Old 02-25-2010, 03:53 AM   #683
Spring Break '92
Spring Break '92's Avatar
Spring Break '92 can only hope to improve
Has anyone with a knock off Tial wastegate replaced the diaphragm and spring with authentic Tial parts successfully?
BOOYAH!
Spring Break '92 is offline   Reply With Quote
Old 02-25-2010, 03:59 AM   #684
ayuaddict
ayuaddict's Avatar
who the fuck makes cool shank lugs?
i found some nifty ones on summit and shit but no nice pretty ones.
Old 02-25-2010, 08:38 AM   #685
MisawaJason
Rtv works like a champ
Old 02-25-2010, 04:01 PM   #686
hOngsterr
Bandwagon.
hOngsterr's Avatar
Trader Rating: (73)
maybe gorilla locks or mcgards?
- Hong
Old 02-25-2010, 04:09 PM   #687
jdm2191
jdm2191's Avatar
Trader Rating: (79)
Feedback Score: 79 reviews
Any suggestions on where i can find a "Left Side S13 Silvia Aero Sideskirt"?
jdm2191 is offline   Reply With Quote
Old 02-25-2010, 06:58 PM   #688
Geezy
Geezy's Avatar
Geezy is an unknown quantity at this point
asdf
double posted it
Geezy is offline   Reply With Quote
Old 02-25-2010, 06:59 PM   #689
Geezy
Geezy's Avatar
need some known resources
so i been looking at the Rota Grids. (i know, bad juju already)
but on the their website it doesn't say it offers them in 18x9.5 4 or 5 lug sizes. unlike the P45Rs.
like these. (actual ones i'm lookin for)
how or where would i go about to find these?
I KNOW I KNOW! FLAME SUITE ON!
Old 02-25-2010, 07:09 PM   #690
datboibrad
no the s15 sr injector seals are not as thick. the ka seals like lets say 1" OD while s14 and s15 sr are like 3/4"
anyone else?
