Old 10-02-2013, 08:23 AM   #3001
delado
delado's Avatar
delado is an unknown quantity at this point
Looking for some tips dudes,
Currently running
front: 225/40/18 on 9.5+15 rolled fenders with 12mm spacer and -4.5* camber
rear: 255/35/18 on 10.5+15 pulled/rolled no spacers and -2.0* camber
Fronts rub a little on full lock.
Rears rub consistently when car squats.
Tires are Federal 595s.
From my understanding, federal tires run big. But is this true? Like, are they substantially larger than other tire brands? Im in the process of buying new tires and would like to go wider in the front, and would like to stay with the 255's in the rear. Would like to run 245's in the front or ideally run a 255 square setup. I like the Hankook Ventus V12s. I wouldn't want to change my ride height though. Any suggestions would be great.
Originally Posted by G240 View Post
I'm glad the Zenki Unite thread isnt lame like this one. Sheesh bunch of girls in here.
Originally Posted by silviaks2nr View Post
That's because everyone with a zenki feels sorry for themselves and they find commonality in the fact that there's no hope for making them look remotely good.
delado is offline   Reply With Quote
Old 10-02-2013, 10:51 AM   #3002
RedSiBaron
RedSiBaron is an unknown quantity at this point
that looks pretty stretched dude^^^
you need to be putting 275 or preferably larger on those wheels, or go to the stretched tire/fitment thread.
RedSiBaron is offline   Reply With Quote
Old 10-02-2013, 05:05 PM   #3003
jr_ss
Yeah Delado, completely wrong thread...
We can't help you unless you raise the car at inch atleast. 245's are going to rub fender well quite easily at full lock. If you like your stance, then leave the tires as is. Otherwise, tub it or come back with a taller ride height for more tire.
Old 10-02-2013, 07:55 PM   #3004
shiftdrift
shiftdrift's Avatar
Trader Rating: (42)
shiftdrift is an unknown quantity at this point
Feedback Score: 42 reviews
Yes federals run wider. The 255/35 is almost the same width as a 275/40 sumitomo htrz3
SW Fab
shiftdrift is offline   Reply With Quote
Old 10-02-2013, 08:46 PM   #3005
spooled240
spooled240's Avatar
spooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfection
Are they at least as short as they should be?
spooled240 is offline   Reply With Quote
Old 10-02-2013, 11:21 PM   #3006
Sumslapper
Sumslapper's Avatar
Sumslapper is an unknown quantity at this point
I ran 255/35/18 Dunlop star spec which supposedly run large. All around on 18x.9.5 +17 front and +13 rear and Im about the same height. I had to beat the inner fender wells, pull fenders and tuck the harness and I didn't rub at all. -3 camber front, -2 rear.
Sumslapper is offline   Reply With Quote
Old 10-04-2013, 04:21 AM   #3007
Kingbaby
Kingbaby's Avatar
Kingbaby is an unknown quantity at this point
Heavenly baby Jesus
#0191 "Lin'da" 2AMR>2AMR>
Originally Posted by Bambi View Post
That's pretty cool. Never sell it, you'll regret it.
Originally Posted by thisisastickup View Post
I donut see an FC on this page, man
Kingbaby is offline   Reply With Quote
Old 10-04-2013, 09:53 AM   #3008
_kouki_monster_
_kouki_monster_ is an unknown quantity at this point
sumslapper, i love you car one of my favorite s14 so clean and simple!
_kouki_monster_ is offline   Reply With Quote
Old 10-06-2013, 08:31 PM   #3009
InsTanCeZ
InsTanCeZ's Avatar
InsTanCeZ is an unknown quantity at this point
Originally Posted by jr_ss View Post
How the hell is a 255 going to perform better on a rim it has to be stretched on to, to fit? A 255 is perfect for a 9" wheel, hell a 265 is better for a 9" wheel.
Less sidewall flex for a more responsive tire, and that's not really stretched at all, stretched would be 215 on 10".
ACE マジック HEART
InsTanCeZ is offline   Reply With Quote
Old 10-07-2013, 05:08 AM   #3010
S14DB
AFC #1
S14DB's Avatar
Are we talking the same sidewall ratio? Because the same tire height a wider tire is going to have a lower ratio and perform better.
Old 10-07-2013, 01:47 PM   #3011
taco_stamp
taco_stamp is an unknown quantity at this point
18x9.5 f 18x10.5 rear +12 all around. Tires are 265 f, 285 r, 1.2* front camber, 0.5 in the rear. Running a 10mm spacer for front only.
-Matt
taco_stamp is offline   Reply With Quote
Old 10-07-2013, 03:43 PM   #3012
InsTanCeZ
InsTanCeZ's Avatar
I was just talking about 255/40-17 on 10j vs 255/40-17 on a smaller width rim such as 9j. Usually the bigger the rim is, without stretching, the less sidewall flex there will be. Honestly though, I'm sure the difference is minuscule. To give you an idea though, 255 mm equals almost exactly 10 in, so IDK why you would want to use a smaller rim width if you had the option to use a 10j rim.
ACE マジック HEART
Old 10-07-2013, 07:51 PM   #3013
forzanoob
forzanoob is an unknown quantity at this point
I know a couple of people on here use these and wanted to know how big of a lip do these have?
forzanoob is offline   Reply With Quote
Old 10-07-2013, 09:34 PM   #3014
S14DB
AFC #1
S14DB's Avatar
With the same section width and height you math doesn't add up.
Old 10-08-2013, 11:03 AM   #3015
InsTanCeZ
InsTanCeZ's Avatar
I'm not sure what you mean. If you look at most tire companies' websites they will recommend 10 in. rims for 255/40-17 tires.
ACE マジック HEART
Old 10-08-2013, 09:39 PM   #3016
jr_ss
No, they recommend a 9" wheel as being the ideal width rim. 10" is the largest width wheel the tire can safely be mounted on per the manufacturer.
Here is the Nt05 website for example.
Nitto Tire NT05 Specs and Sizes
Old 10-09-2013, 12:24 AM   #3017
Bubbles240
Bubbles240 is an unknown quantity at this point
s14
S14 RB25DET
18x9 +30 R34 GTR wheels with 5mm spacers front and back
245/45/18 Nitto NT05 Tires
I am really wanting to look for an option of tires and wheels that I can put on this to fit the most tire I can with stock fenders at 0 camber in the rear and 2.5 degrees of camber in the front.
What do you all think?
Bubbles240 is offline   Reply With Quote
Old 10-09-2013, 12:08 PM   #3018
InsTanCeZ
InsTanCeZ's Avatar
Try 255/35 f 265/35 r. might need 1 or 2 degrees of camber in the rear and about 3 in the front but that's okay. For grip 1 or 2 in the rear is good, I would only use 0 for drift. Front will probably need bigger spacer for inner clearance though with 255s.
ACE マジック HEART
Old 10-09-2013, 01:04 PM   #3019
spooled240
spooled240's Avatar
Still undecided on tires
18x9.5 +19 F and 18x9.5 +22 R (rear track is spaced out a bit with adjustable LCA's)
235/40r18 is too skinny
245/40r18 is too tall
245/35r18 is too expensive/limited
255/35r18 might rub
fuck me
This is nice. Did you have to pull the front fenders as well? They look stock
Old 10-09-2013, 01:16 PM   #3020
Black R
Black R's Avatar
Black R is an unknown quantity at this point
Originally Posted by e1_griego View Post
PJ's running 315s all around now. Panda just went 1st and 2nd at SCCA solo nationals, so clearly he's doing more than a few things right.
Aceinhole!
S13 XE coupe: Aristo GTE, R154, GT37, Defsport Wilwood kit, KTS coilovers
Black R is offline   Reply With Quote
Old 10-09-2013, 03:49 PM   #3021
Bubbles240
Ya that's the plan on the car is drift and I really want to get to 0 rear. I can still roll my stock fenders since they are not rolled yet in the rear but I am not sure what wheels to get. Goal is 275 in the rear on 0 offset but maybe I am just dreaming.
Old 10-09-2013, 04:04 PM   #3022
Sumslapper
Sumslapper's Avatar
Thanks for the love guys!
Yes the front fenders are stock and pulled/rolled. My biggest issue was the tires rubbing on the inside fender well and the drivers harness. I drove around town rubbing really bad at first, then pulled off my wheels and looked at where there were rub marks and beat those areas in with a hammer until there was no more rubbing lol
Old 10-09-2013, 05:07 PM   #3023
2muchboost
Trader Rating: (33)
2muchboost is an unknown quantity at this point
Feedback Score: 33 reviews
Sumslapper.....never disappoints
2muchboost is offline   Reply With Quote
Old 10-09-2013, 09:42 PM   #3024
InsTanCeZ
InsTanCeZ's Avatar
Okay then, for drifting you don't really need "max rubber". I would recommend trying 225/40 in the front with anywhere from 3 to 5 degrees of camber (huge spacers or extended FLCA with knuckles for more inner clearance and angle) and 235/40 in the rear since they're cheap (maybe 265 if you have an LS1 or something) with anywhere from 0 to 1 degree of camber. You really don't need big tires unless you have huge power. To give you an example, Daigo Saito has 1200hp and he only uses 265/35-18 front and rear. Basically, for drifting the "max rubber" idea doesn't really apply, but you can run big rear tires and crank up the psi for more smoke if you want, it just burns tires quicker and wastes money. Good for contests though.
ACE マジック HEART
Old 10-09-2013, 10:39 PM   #3025
Bubbles240
I understand what you are saying and I do have more power than your typical local drifter since I am running an RB25. My main reason is asking to find out what works so I can buy wheels now to grow into. Right now I have only 300 HP and I will not need very wide tires but as I up the power level with my skill level I want to just start to purchase wider tires if possible.
So as I said before what wheel combo would get me "max rubber" under the stock fenders at 0 degrees of camber on an S14 with rolled fenders.
I have been trying to go through all the pages of this thread but most people I find do not run 0 degrees of camber
Thank you for all of your help.
Old 10-10-2013, 12:04 AM   #3026
InsTanCeZ
InsTanCeZ's Avatar
If your rear is 18x9+30 (no spacers) then I believe the biggest tire you could fit would be 275/35-18 with no major fender work (just a roll, maybe slight pull) and 0 camber. In the front you really want as much inner clearance as you can get if you plan on using knuckles, but you could go with anywhere from 225/40 to 265/35 depending on a lot of things like camber, offset, etc. If you want 265s in the front, then you should probably get wider fenders.
ACE マジック HEART
Old 10-10-2013, 12:20 AM   #3027
Sumslapper
Sumslapper's Avatar
^^you just need to run a combo that isn't super low offset like most of the cars on here. You could run 18x9 +20 front on 255/35 with minor rolling/pulling and 10j with a 30+ offset in the rear under stock rear fenders with 295's with little to no camber. Check out silviaks2nr car i think he runs 18x11 +30 with a 295 I believe with what looks like a mild roll
Old 10-11-2013, 09:25 AM   #3028
Black R
Black R's Avatar
I'm just checking in to see if anybody runs wider than 265's up front on an s13.
That's what I'm running now, but want to run 285 up to 305 up front now.
I don't mind cutting and running bigger flares.
Old 10-11-2013, 09:32 AM   #3029
Drift_FX
Drift_FX's Avatar
Drift_FX is an unknown quantity at this point
im running 265's up front with modded knuckles, so with normal knuckles there is no reason you can run a 285 up front...
Drift_FX is offline   Reply With Quote
Old 10-11-2013, 09:32 AM   #3030
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
Jason on NRR is testing fitting 315s on the front right now and seems to be doing ok.
