09-14-2017, 07:26 PM | #1 |
External waste gate vacuum line setup
Hi guys, I need some help with my vacuum lines , I have a tial 38mm ext wastegate.As I have it setup now which I'm sure is wrong , I have the barb on the top of the wastegate running directly to the vacuum source from the throttle body , I have also my bov vacuum line to the throttle body. I have no source from my gt3076r turbo . It's also a top mount turbo setup with dumptube. Thanks guys
09-14-2017, 08:35 PM | #2 |
I believe you're supposed to leave the top port open. And you should run a vacuum line from a boost source, preferably the hot pipe, to one of the ports on the side of the wastegate. Which model tial do you have?
10-03-2017, 09:52 AM | #4 | |
Trader Rating: (58)
Feedback Score: 58 reviews
If you're not using boost control, you leave the top vented Side port of wastegate goes to vacuum source PRE throttle body, typically on the compressor housing, or on the hotpipe coming out of the turbo. EDIT: If you're using a Tial MVS/MVR you need to use the associated plugs to block off all unused ports. In my example, the redline goes from the wastegate side port to my hotpipe for it's pressure source. The blue line goes from teh top of the wastegate, over to my boost control solenoid on the shock tower. The green line then goes from the other side of the solenoid to a pressure source which i also have on my hotpipe.
10-03-2017, 10:07 AM | #5 | |
Sent from mTalk |
10-03-2017, 12:51 PM | #7 | |
Trader Rating: (58)
I am running my boost gauge off the manifold though to know the actual boost pressure there, so I sorta (would assume) that regardless of what the 'source' sees so long as your final boost control nets you the boost pressure you want to see on the gauge, then it shouldn't much matter. However I have always sourced the WG and EBC from pressured sources, not so much 'vacuum' sources (as in all before throttle body)
04-15-2018, 02:35 PM | #8 |
Useful stuff from the manufacturers and for those too lazy to google
http://www.tialsport.com/documents/MV-Install-Guide.jpg http://aemelectronics.com/files/inst...noid%20Kit.pdf
As long as you're not a ham-fisted retard there shouldn't be a problem. |
