06-23-2003, 09:05 AM | #1 |
ABS 5 lug Hub
this might be a stupid question, can you use a non ABS 5 lug hub in ABS equipt s14.i though i read it before that you could. just double checking. I'm doing a 5 lug conversion and my s14 is a base with abs.
Pls help. i have access to a non abs 5 lug hub. THANKS! |
06-23-2003, 09:51 AM | #2 |
No, unless you don't mind losing your ABS.
The front hubs incorporate the toothed wheels for the ABS wheel speed sensor. The rear hubs are the same, though. |
06-23-2003, 04:35 PM | #4 |
Nuclear
The hubs are identical, it's the tooth ring that needs to be removed from the current hub and put on the new hub.
RACECAR spelled backwards still spells RACECAR |
03-21-2005, 05:12 PM | #6 |
call me a grave digger but i didnt want to start a new post and just add to this one. i have ABS in my S13 and i want to keep it but i want to go 5lug with ABS. i know id have to get S14 ABS parts to do that, what parts do i need and where can i find them? i have a nissan account so i can probably get them there if i knew the part numbers. is there anyone that can help me with this?
03-21-2005, 10:13 PM | #7 |
S14 ABS hubs and spindles. The hubs have the ring gear in them, the spindle has the tab required to mount the sensor. You'll need both.
FYI, OE hubs are ~$110 each, spinldes are ~$260 each. Better to find them used if you can.
03-22-2005, 05:08 PM | #10 | |
