07-14-2011, 11:35 PM | #1 |
1993 240sx Coupe
VIN:
JN1MS34P2PW304350 Location: Garland 5 Speed $2000 TITLE IN HAND!!!!!!!!!! This is the low down on the car so there are no surprises. Motor runs strong, reliable, and has good mpg. I have driven from dallas to austin multiple times. This was a swapped motor and it idles a little rough sometimes(Could be TPS, IACV, Ignition etc.). Before I put in the motor, the rear main seal and oil pan gaskets were replaced Car is fun to drive but is rough on the street due to the high spring rates of the coils. The ACT clutch($400 new) + braided clutch line give a quick grab. The transmission shifts smooth and Redline MT-90 gear oil is being used. Super The sound deadening was removed and the carpet put back over. The interior needs some TLC with a new dash some door panels and the HUD needs to be fixed. The Powersteering works good however there is no AC The car is pretty quick but also very loud. The egr was removed by previous owner. The rest of it needs to be taken off and a block plate put on for a cleaner look. Or you can just keep on driving it like this. Doesnt matter I still have the front bumper but a chunk was ripped off. If you have fiberglass skills then it shouldn't be much of a problem to fix it up. As for the tires, the rears are brand new and the fronts can last a good while. And finally the differential was welded but the welds broke. I driven it like this hundreds of miles and still do everynow and then just because. Either the fluid needs to be changed or the diff replaced. (I dont recommend driving it like this anymore) pm for phone # ACT clutch KSPORT coilovers Aftermarket RUCA Walboro 255lp fuel pump 3" exhaust new battery braided clutch line 17x9 17x10 5zigen FN01R-C 225/45(Nitto Neo Gen), 235/40(Federal 595) Ebay strut bars Cons: Primered(ready for a new paint job after being sanded again) Idle isnt perfect No Door Panels Dash is horrendous HUD stopped working sunroof Small Oil Leak(I think maybe the oil pump) No Radio or AC needs new ball joints broken weld in diff Last edited by zeitgeist; 08-01-2011 at 01:22 PM.. |
