04-11-2011, 03:43 AM | #1 |
RB25, S14, Exhaust, BOV, Spacers, etc.. oem & am stuff
Made some changes to my setup so I am now offering some parts for sale that should help someone get their RB25DET swap up and running. Also some misc aftermarket and OEM stuff you may need.
*Note : All prices are BEFORE shipping; shipping is on your dime. All parts are in good/excellent condition unless otherwise noted. Modified RB25 oil pan for use with RB26DETT (clears 26 oil pickup) - $65 Was test-fitted and filled with oil but never used. This pan was modified to be used for an RB26 RWD conversion. I’m running a regular old 25 so no need for the extra clearance. Your gain! R33 Skyline crossmember - $150 RB25 OEM motor mounts - $30 RB25 OEM transmission mount - SOLD RB25-into-S14 3-inch mandrel bent aluminum turbo-back exhaust - SOLD Modified elbow to clear LHD steering column Downpipe from elbow to test pipe Test pipe Cat-back section with resonator GT-Spec style muffler with removable silencer included All gaskets, hangers and hardware included; I’d recommend you replace some gaskets. I went straight pipe so I no longer need this setup. Passed a CA modified exhaust fix-it ticket inspection with silencer installed :P RB25 aftermarket turbo dump elbow, divorced wastegate - SOLD RB25 OEM turbo recirculation valve - $20 RB25 R1 Racing Sports intake pod filter with MAF adapter - SOLD This is a good choice for swaps because it doesn't take up a lot of space compared to cone filters, yet it flows well. Fits N60/N62 MAFs. RB25 OEM sidemount intercooler with piping/couplers - SOLD I think this also fits RB20's due to the similarities in the manifolds. Sheepdog PROF blow-off valve on OEM RB25 cold pipe - $110 Super-mad-tight JDM, rare in the states. If you know what it is, you know it sounds awesome. Will not separate from cold pipe. Includes original packaging, vacuum hose, a legit white decal, and Japanese instructions. RB25 OEM clutch kit, includes pressure plate, disc, throwout bearing - $60 Lots of meat on the clutch, was new when motor was swapped. Changed it out for an ACT 6-puck after a couple oil changes..also fits RB20 and VG30DE. RB25/VG30DE/TT OEM Thermostat - $10 Works great, removed to install colder Nismo unit. Includes Permatex thermostat housing gasket maker at no extra charge, lol. Mishimoto 19psi (1.3bar) high-pressure radiator cap - $20 Used for two oil changes..then I installed a PSM swirl tank which came with a different cap. So I no longer need this. I think Nismo caps are only 16psi..this is 19. Accidentally deleted the pic but it is squeaky clean! Samco blue silicone radiator hoses for RB20/25/26 - $70 Brand new, never used. Just collecting dust; someone can use these I'm sure. Miscellaneous R33/240SX AC lines - SOLD The two lines on the left were cut with tinsnips from an R33 front clip so they obviously need to be cut again and welded to work with your lines. Others are extras I don’t need. S14 Nismo Power Brace – $120 I couldn’t use this because I found out it hits the AC pulley on my RB25 after I hooked up my AC. Perfect for those of you who aren’t running AC, or are running KA’s/SR’s/what have you. Wheel spacers: -Powered By Max 20MM bolt-on (5x114.3) - SOLD With removable hub rings. Discontinued part. Includes nuts. -Generic 10MM slip-ons (5x114.3 and 4x114.3) - $25 -Generic 7MM slip-ons (Universal 5-lug) - $15 240SX S14 SE OEM black steering wheel, with airbag and cruise control - SOLD Includes airbag, airbag hub, all wiring, cruise buttons, etc. S14 tiny coolant hose (filler neck to overflow tank, with clamps) - $5 S14 OEM suspension links: RUCA's - $15 Toe rods - $15 Tension rods (oem bushings are a little bit janky but they work fine) - $10 *Buy the whole set for $25. S14 OEM front rotors - $20/pair Great condition, includes dust shields if you want them. I swapped them out for Z32's so no longer needed. S14 OEM black glovebox - $15 Couple of scratches but overall looks decent. The locking mechanism is not in it so you can swap in the matching lock from your car's set..I may have it around somewhere. S14 OEM grey rearview mirror - $20 Great condition, no nicks/scratches. Just dusty from sitting in my garage. PAYMENT: Obviously, cash is preferred if you are local. Please add 3% for all payments made through PayPal to cover fees. If you want multiple items, I may be able to cut you a package deal. It never hurts to ask. No refunds/exchanges, all sales are final. SHIPPING: All items ship from San Diego, CA. Please provide your zip code and a list of the items you are interested in for a shipping quote. Small items will ship within 1-2 days of cleared payment; please allow an extra day or two for large or heavy items as I will have to obtain packing materials for them. If you are interested in picking up locally, let me know. If you’re coming from LA or OC and you are buying a large item or a lot of small items, I can meet you as far north as Oceanside on one of my days off. Please PM me or text sixONEnine-NINEtwoNINE-sixONEnineSIX. My name is Blake. Thanks.
-blakeZX | 1997 240SX SE (RB25DET), 2008 350Z Nismo Edition (VQ35HR) Last edited by blakeZX; 04-25-2011 at 06:39 PM.. Reason: Sold some stuff |
04-11-2011, 08:27 AM | #2 |
S14 sterring wheel
Do you have more pics of the steering wheel like the front. Mine looks like it works out. and shipping to 32579. Thanks
95 SE Serengeti sand- RB25 Neo |
04-11-2011, 11:00 AM | #3 |
Transmission mount is sold.
Received a couple of PM's about the 20mm spacers; they are pending local sale but if that falls through I will honor the order of PM received. As for the steering wheel, it is probably one of the cleanest ones you'll find but if you'd like I can get more pics for you. I'll be at the garage today getting the spacers so I'll snap a couple more for you, and figure out how much it weighs. Thanks,
-blakeZX | 1997 240SX SE (RB25DET), 2008 350Z Nismo Edition (VQ35HR) Last edited by blakeZX; 04-11-2011 at 11:04 AM.. Reason: Transmission mount sold |
04-11-2011, 10:18 PM | #7 |
AC lines, SMIC, and 20MM spacers sold.
Sent pics of steering wheel out with shipping quote. Added silicone hoses to original posting! All PM's replied.
-blakeZX | 1997 240SX SE (RB25DET), 2008 350Z Nismo Edition (VQ35HR) |
04-13-2011, 02:02 PM | #8 |
If you bought stuff from me, it was shipped today and you should already have a tracking number in your PM box.
Steering wheel is sold. All PM's replied with shipping quotes. I bought a scale so if you need quotes I should be able to get them done faster now, lol.
04-21-2011, 05:22 PM | #11 |
Thanks for the nice feedback!
All PM's replied with shipping quotes. Thanks guys
04-23-2011, 08:59 PM | #13 | |
If you asked me for a shipping quote, you should have one in your PM box. If I missed anyone please let me know. Thanks
04-23-2011, 09:28 PM | #15 |
$350 and I'll throw in the rest of the exhaust for free. But seriously, the whole exhaust is pending sale, if I don't receive the money on Monday it will be available again. I am not parting it out at this time. Thanks
04-24-2011, 12:12 AM | #16 |
He'll take the test pipe, ill take the modified elbow (assuming all welds are professionally done) and downpipe. You can sell the cat back separate? yay or nay?
EDIT---bahaha im an idiot and didnt read the rest of the post. . .let us know if the buyer falls threw? Last edited by enjoisk8board891; 04-24-2011 at 12:13 AM.. Reason: EDIT |
04-24-2011, 12:23 PM | #17 | |
04-24-2011, 10:20 PM | #20 |
i can promis yall this...the buyer wont fall through my engine is coming this week and i dont want to pay sumit racing 1000 bucks to come out to make me one. there are no exahust shops out here that i trust to do it...lol
04-25-2011, 08:56 PM | #24 | ||||
460
crossmember, exhaust, rb25, s14, spacers |
