Old 11-17-2015, 08:49 PM   #1
wesismyhero
wesismyhero is an unknown quantity at this point
sr20det has zero power, I need advice.
So I recently got my project car running. When I got it it was a mess, half assed and with a bunch of random parts laying around. I frankensteined everything together and finally got it running. It will idle perfectly all day long at 900 rpm once it warms up. When I try to drive it down the road, it has zero power, barely enough to move when floored. In neutral it will rev to between 4500 and 5000. I have changed the MAF, o2 sensor, knock sensor, plugs (NGK BKR6E) set timing, checked voltage on tps, checked compression (165-175 on all), checked fuel pressure,basically everything but a new ecu. Does anyone have any ideas?
Mods to the car are
Freddy intake manifold
Sard fuel rail and 550cc injectors
Aem fuel pump
FMIC
Fujita intake
Isis turbo manifold and fuel pressure regulator
Chase bay's fuel lines
Brian Brower 264 cams
TRust 3 inch downpipe
wesismyhero is offline   Reply With Quote
Old 11-17-2015, 08:56 PM   #2
derass
What ECU are you using? If it's not something that's been programmed for those larger injectors, that's likely the problem.
Old 11-17-2015, 08:58 PM   #3
wesismyhero
Stock ecu. I was just trying to get it running first. I may switch to the stocks and see if it helps.
Old 11-17-2015, 09:22 PM   #4
KAT-PWR
KAT-PWR's Avatar
coolant temp sensor?
MRP Manufacturing
Old 11-17-2015, 09:22 PM   #5
wesismyhero
It's not throwing any codes on the ecu.
Old 11-17-2015, 10:31 PM   #6
silviamang
silviamang's Avatar
silviamang is making a name for him/her selfsilviamang is making a name for him/her selfsilviamang is making a name for him/her self
What do your plugs look like?
silviamang is offline   Reply With Quote
Old 11-17-2015, 10:54 PM   #7
wesismyhero
Brownish black. Not wet and not really fuel smell. What I would consider normal.
Old 11-17-2015, 11:13 PM   #8
coupesallday!
coupesallday!'s Avatar
Trader Rating: (18)
coupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the rough
Feedback Score: 18 reviews
Send a message via MSN to coupesallday!
Is the clutch good? lol
Throw some glitter flake and crazy glue in there.
coupesallday! is offline   Reply With Quote
Old 11-17-2015, 11:16 PM   #9
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
You're running 550s on a stock ecu?
That doesn't work.
Old 11-17-2015, 11:21 PM   #10
wesismyhero
New clutch.
Old 11-18-2015, 12:42 AM   #11
teh smithers
teh smithers's Avatar
teh smithers is an unknown quantity at this point
Get your ECU flashed, or get a programmable one and get it tuned. The stock ECU/tune can't handle the fuel system upgrades.
teh smithers is offline   Reply With Quote
Old 11-19-2015, 10:29 PM   #12
1988montecarloss
1988montecarloss's Avatar
Trader Rating: (24)
1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough
That doesn't work.
this.
the ecu thinks its firing 370cc injectors
IG: @Haley72692
1988montecarloss is offline   Reply With Quote
Old 11-29-2015, 08:08 AM   #13
rwtf
rwtf's Avatar
rwtf is an unknown quantity at this point
rwtf is offline   Reply With Quote
