Old 02-26-2014, 11:11 PM   #1
S_Cruthirds
S_Cruthirds is an unknown quantity at this point
Hood does not catch latch?
Ive tried it all(adjusting bolts and hood etc) however still does not work. Basically it looks like the hood is short by a little bit it lines up fine but the latch where u pull to open under the hood doesnt reach into the hole where it should go in. It looks as if the hood latch is too far up ive tried tightening loosing etc. Any suggestions? Yes its stock hood
S_Cruthirds is offline   Reply With Quote
Old 02-26-2014, 11:12 PM   #2
S_Cruthirds
By tightening and loosening i mean hood bolts and latch bolts as well
Old 02-27-2014, 06:49 AM   #3
Hiighboost2
Hiighboost2's Avatar
Trader Rating: (32)
Hiighboost2 is an unknown quantity at this point
Feedback Score: 32 reviews
Send a message via AIM to Hiighboost2
If you've aligned the hinges correctly, all that's really left is adjusting the striker.
Loosen the striker/hood latch/ whatever you want to call it and slide it up toward the hood and tighten down.
Keep messing with it till you find that sweet spot. Also try checking to see if your hood bumpers are up too high.
That could be causing the hood to not sit down far enough.
Hiighboost2 is offline   Reply With Quote
Old 02-27-2014, 08:28 AM   #4
Alamo_City_210
Alamo_City_210's Avatar
Alamo_City_210 is an unknown quantity at this point
if none of the above works, try lowing the bumber support (i believe its called). there are two bolts on each side. i just did this the other day, no adjustments to hood or latch were allowing it to catch. turns out, the bumper support was just a little to high.
Alamo_City_210 is offline   Reply With Quote
fitment, hood
