Old 06-30-2019, 07:28 PM   #1
Woodz
Woodz's Avatar
Woodz is an unknown quantity at this point
1994 Nissan 240sx convertible
Selling my 1994 240sx convertible,the engine is a healthy running KA24DE w/ 198,xxx miles and had the heads fully serviced about ~20,xxx miles ago. no overheating. no leaks.
PRICE IS $2500, WILL TRADE FOR MOTORCYCLE
Now hereʼs some facts about the car:
Exterior:
new front tires
rear tires have 75% life left
Rolled fenders
I am putting on a new undamaged OEM hood the week but damaged VIS carbon fiber hood is on for now
OEM mudflaps in the rear only
top works perfectly
no rips on the top
yellowing back window
Suspension:
Ichiba 5 lug conversion all round
Z32 26mm aluminum brakes all around
Z32 ebrake lines w/ SFE engineering
Extension bracket
DIF ss brake lines all around
Drilled and slotted rotors
JDMSpeed coils all around
Front Tension rod brace
Welded J30 Diff w/ energy suspension bushings
New front lower control arms with less than 3000 miles. Ball joints still look new
Energy suspension Rack and pinion bushings
Megan outer tie rods
Unknown After market wheels
Interior :
Very clean crackless dash
I did the seat belt pillar removal, so I could use the coupe door panels because they look better
Driver and Passenger side has OEM leather seats 9/10 no rips
Rear leather seats 9/10 no rips
NRG 3" deep 350mm suede steerling wheel
NRG s13 short hub
SABELT 4 point harness for driver
NETAMI 4 point harness for passenger
Aftermarket radio
Soundstream Stealth 13" sub in the trunk
upgraded to sound stream speakers/tweeters all around
Bought a new quarter window relay from courtesy Nissan because theyʼre known to go out, 6 months old
Engine:
Strong running KA24DE w/ 198,XXX
Heads were serviced ~20k ago (New valve seals, all valves were lashed, resurfaced head and block and new head gasket and head studs)
custom equal length headers
Oil changed every 3,000 miles since ive had it
Ngk spark plugs
K&N Gold Oil filter
Fram fuel filter
New air filter
New coolant temp sensor
New 02 sensor
i have alot of 5 speed parts and other 240 goodies that i will include if asking price is met
Located in Whittier , ca
For more info text please text me at (562)203-2029 or PM me
Sent from my SM-J727T1 using Tapatalk
Woodz is offline   Reply With Quote
Old 07-01-2019, 09:49 PM   #2
DataXUnknown
Trader Rating: (30)
DataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfection
Feedback Score: 30 reviews
Does the AC work? Clean title? Smog?
DataXUnknown is offline   Reply With Quote
Old 07-01-2019, 10:01 PM   #3
Woodz
Woodz's Avatar
ac doesnt work, but it has been pressure tested and the compressor is bad . its salvage title, and has passed smog, tags are due its only $122. im open to trade but shoot your best offer
Old 07-02-2019, 07:14 PM   #4
Woodz
Woodz's Avatar
price drop, $2500 takes it
Old 10-03-2019, 09:48 PM   #5
Philthese93
Philthese93's Avatar
Philthese93 is an unknown quantity at this point
Damn this is cheap. Id jump on it if i wasnt a broke bish. Bump
Philthese93 is offline   Reply With Quote
