Old 11-01-2017, 10:19 AM   #1
p33g
p33g is an unknown quantity at this point
1998 jzx100 mark ii
It's Up for sale is my Factory 5 SPD 1998 Jzx100 Mark II Tourer V, That I have owned for the past two years. I am the first owner of the car in Canada and the car was purchased as a clean, bone stock example. I drove the car relatively stock with the exception of an HKS exhaust and old Cusco coil overs during my first year of ownership but always knew that I would do an extensive over haul eventually. The time came to park the car for winter in 2016 and it seemed to be the right moment to start with the build. Over the span of winter 2016-2017 the car evolved into what you will see below.
I planned to keep this car for quite some time however my situation has changed and I want to focus my attention towards other areas of my life, and so I must part with this Gem of a car.
Almost all of the car was refreshed in one way or another, here are its current specs.
jzx100 mark ii s1 150000km
1JZ VVTI fully refreshed with
-Oem F/R Main Seals
-Oem V/C Gaskets
-Oem Pilot Bearing
-Oem Camshaft seals
-Oem Water pump/timing belt
-Mishimoto Thermostat
-Earls Thermostatic sandwich plate/ Mocal 13 row oil cooler
-CT15B turbo was rebuilt less than 500km ago with a new center -cartrige, Inconel exhaust wheel and new compressor wheel.
-Aluminum Radiator with silicone hoses
-3" front mount intercooler
-De-catted down pipe
-3" Stainless exhaust with resonator from down pipe back, with 3.5" tip
-HKS Pod filter
Transmission/ Differential
-R154 5Speed Transmission (last gen with the upgraded syncros)
- New Oem Slave cylinder
-Os Giken Grand Touring Twin Plate Clutch (Firm Pressure Plate)
-ARP Flywheel Bolts
-Stainless Steel Clutch Line
-Os Giken 2 Way Diff
-KTS Solid Diff bushings
Front suspension/Brakes
-Stance XR1 coilovers
-Cusco Upper camber arms
-Kazama SP Angle knuckles
-Moonface Super lap RCA
-DMAX Adjustable Tension Rods
-Spindles shortened 1" from factory for extra clearance
-FLCA Extended 1" from factory, bushing replaced with SuperPro poly bushings
-Steering rack bushings replaced with superpro poly bushings
-AE92 Moog inner Tierods and Moog is300 outer tie rods
-LS400 Aluminium 4 piston brakes (rebuilt prior to installation)
Drilled/slotted rotors, upgraded pads and stainless brake lines
-KTS Front Subframe brace
-CUSCO Swaybar with New endlinks
Rear Suspension/Brakes
-Stance Xr1 Coilovers
-KTS RLCA
-KTS Tension Rod
-KTS Toe Rod
-Oem RUCA with new bushings and ball joints
-Knuckles have had all bushings/spherical bearings replaced
-Solid Subframe Bushings
-Cusco Sway bar with new end links
-Do luck Floor Brace
-KTS Diff bushes
-Oem rear brakes with newer pads and new stainless lines
Interior
- mostly stock but will include a works bell hub and bride seat rail
-Blitz turbo timer
AERO- BN SPORTS TYPE III
CONS- front fenders are a little rough from rubbing at full lock
-small blemishes in paint
-needs rear abs line
-OEM Aero is in very rough shape however the Bn sports kit is in awesome shape.
PRICE $14000.00 USD OBO PRICE DROP!!
This car is located in Canada
Car is located in Toronto
IMG_0266 by blueboy40982 blueboy, on Flickr
IMG_0270-2 by blueboy40982 blueboy, on Flickr
IMG_0264 by blueboy40982 blueboy, on Flickr
IMG_0288 by blueboy40982 blueboy, on Flickr
IMG_0274 by blueboy40982 blueboy, on Flickr
IMG_0273 by blueboy40982 blueboy, on Flickr
IMG_0278 by blueboy40982 blueboy, on Flickr
IMG_0276 by blueboy40982 blueboy, on Flickr
IMG_0279 by blueboy40982 blueboy, on Flickr
IMG_0284 by blueboy40982 blueboy, on Flickr
IMG_0281 by blueboy40982 blueboy, on Flickr
p33g is offline   Reply With Quote
Old 11-01-2017, 02:11 PM   #2
DJTTon
DJTTon's Avatar
DJTTon is on the path to ruinDJTTon is on the path to ruin
That's pretty dope, sad to see you sell just a meticulously cleaned up car.
Skurr Skurr
DJTTon is offline   Reply With Quote
Old 11-01-2017, 10:47 PM   #3
t's!
t's! is an unknown quantity at this point
One day..........
t's! is offline   Reply With Quote
Old 11-02-2017, 06:57 AM   #4
p33g
Thanks man, it is what it is haha. I don't drive the car much so I know it makes more sense to go somewhere where it will actually be enjoyed
Old 11-02-2017, 06:57 AM   #5
p33g
Originally Posted by t's! View Post
One day..........
*today.....
Old 11-03-2017, 12:30 PM   #6
tricky_ab
tricky_ab's Avatar
Good luck with the sale! If I owned a Mark II, I would have made an offer on that BN kit!
Instagram
Back for round two... 4 doors this time around...
Old 11-07-2017, 05:29 PM   #7
p33g
Thanks you sir!
Old 11-26-2017, 06:19 PM   #8
p33g
BUMP, Car will come with 18x9/10 te37 style wheels. BN is fitted to the car and will have photos up in a few days. Also willing to pull the motor if a US buyer is interested in bringing the car over for parts or off road use!
Old 11-26-2017, 06:28 PM   #9
JustinChillenBallin
JustinChillenBallin's Avatar
JustinChillenBallin is not welcome here anymoreJustinChillenBallin is not welcome here anymoreJustinChillenBallin is not welcome here anymoreJustinChillenBallin is not welcome here anymoreJustinChillenBallin is not welcome here anymoreJustinChillenBallin is not welcome here anymoreJustinChillenBallin is not welcome here anymoreJustinChillenBallin is not welcome here anymoreJustinChillenBallin is not welcome here anymoreJustinChillenBallin is not welcome here anymore
Send a message via AIM to JustinChillenBallin
pics aren't there anymore my dude! reupload them on imgur and post em here.
JustinChillenBallin is offline   Reply With Quote
Old 11-27-2017, 06:45 AM   #10
p33g
Can't drive the car across the border, but willing to help if you need to disassemble it!
Old 11-27-2017, 06:51 AM   #11
p33g
Just did, thanks man!
Old 12-01-2017, 01:45 PM   #12
p33g
Buuummmpptttt
Old 12-09-2017, 09:30 AM   #13
p33g
Tothetoppppp
Old 12-11-2017, 07:59 AM   #14
p33g
Car just had full paint correction/paint seal and looks amazing. Updated pictures will arrive Wednesday.
Old 12-21-2017, 10:14 AM   #15
p33g
Pictures have been updated
Old 12-22-2017, 05:38 AM   #16
reivax
reivax is an unknown quantity at this point
Trade for a flushed ls1 corvette
reivax is offline   Reply With Quote
Old 12-22-2017, 08:05 AM   #17
slidingsideways09
slidingsideways09 is an unknown quantity at this point
bump for a gorgeous car <3
slidingsideways09 is offline   Reply With Quote
Old 12-22-2017, 08:41 AM   #18
t's!
I don't see how this car is still for sale! Thinking about doing some illegal activity to buy it!!
JK!! Someone get this so I can stop visiting this thread!
Old 12-23-2017, 02:54 PM   #19
p33g
Pm me if serious.
Old 12-23-2017, 02:55 PM   #20
p33g
Thanks man, much appreciated!
Old 12-23-2017, 02:58 PM   #21
p33g
I don't usually condone of illegal activity, but in this case it is worth it. Thabksnfor the kind words.
Old 12-25-2017, 06:00 PM   #22
1988montecarloss
1988montecarloss's Avatar
Trader Rating: (24)
1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough
Feedback Score: 24 reviews
Favorite car on here rn
IG: @Haley72692
1988montecarloss is offline   Reply With Quote
Old 12-27-2017, 05:55 PM   #23
p33g
Thanks Dude!
Old 12-27-2017, 11:15 PM   #24
reivax
Any idea how California would go about registering this beautiful gem
Old 12-29-2017, 09:12 AM   #25
p33g
Legally? No idea but I'm sure there is someone on here with more knowledge on how to go about tha!
Old 12-29-2017, 02:50 PM   #26
tjcbar
tjcbar is an unknown quantity at this point
my dream car!!!! sadly it isnt USA legal
tjcbar is offline   Reply With Quote
Old 01-01-2018, 12:22 PM   #27
p33g
Price drop; 14000 usd
Old 01-09-2018, 10:28 AM   #28
p33g
Buuuuummmmpppp
Old 01-13-2018, 11:50 PM   #29
p33g
Buuuumpttttt
Old 01-16-2018, 10:38 PM   #30
Timmy22
Timmy22's Avatar
Timmy22 is an unknown quantity at this point
I’d buy it right now if it was in the states ��
Timmy22 is offline   Reply With Quote
