Old 07-01-2015, 08:53 AM   #121
onehundredoctane
onehundredoctane's Avatar
onehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfection
Originally Posted by nujabe View Post
i run the wilwood kit and i love them..
Untitled by Aallmighty, on Flickr
I LOVE THAT WHEEL, TIRE, BRAKE combo. . . Dear JESUS.
Originally Posted by grimm199 View Post
For you Q45 guys out there that are running Hawk HPS pads, where do you order them from?? When I messaged Hawk for the part number, they sent me this;
"I regret to inform you that we do not make the front pad for your vehicle.
I have access to over 15,000 different applications and fitments. Infinity is the only company to use that pad shape and they used it only on the Q45 for 3 years"
When I had Q45 fronts I ordered my Hawk HPS pads from Rock Auto. Also, my calipers and rotors were from a 2001 Q45 which seems to matter.
onehundredoctane is offline   Reply With Quote
Old 07-01-2015, 01:41 PM   #122
grimm199
grimm199's Avatar
grimm199 is an unknown quantity at this point
Thats what i was afraid of. I'm pretty sure these calipers are off of the first gen Q45. Ive been looking up ways to know for sure what years the calipers are physically, but i guess ill just have to match up the old pads that came with them to know.
grimm199 is offline   Reply With Quote
Old 07-14-2015, 08:45 PM   #123
grimm199
grimm199's Avatar
Hated how plain the Q45 calipers looked compared to the Z32 calipers, so I tried this. Supposed to be high temp decals for calipers, and will be throwing clear coat over them as well so we will see if it holds up. Not sure if anyone has thought to do this before or not. Also, still on the search for performance pads for the 1st gen Q45 calipers so I can finish my brakes up.
Guess i'll just be getting the Akebono ProACT pads and see how those do if nothing else.
Old 09-06-2015, 04:38 PM   #124
ehhhregartless
ehhhregartless is making a name for him/her selfehhhregartless is making a name for him/her self
www.zeedakay.com
IG: @zeedakay
ehhhregartless is offline   Reply With Quote
Old 09-14-2015, 08:27 PM   #125
crzsteveo
crzsteveo is an unknown quantity at this point
installed some CTSV calipers with a mazworx bracket...I gotta say I do not like the mazwork bracket because you have to grind so much material down on the backside of the caliper just to get it to sit flush.... they stop super easy, but I have not gotten a brake portioning system yet. I still have not found anything for the rear of a 240 for bolt on brake upgrades besides dual calipers.
crzsteveo is offline   Reply With Quote
Old 09-15-2015, 01:59 PM   #126
crzsteveo
Old 09-16-2015, 04:32 PM   #127
CHiNo4ReaL
CHiNo4ReaL's Avatar
CHiNo4ReaL has a spectacular aura aboutCHiNo4ReaL has a spectacular aura aboutCHiNo4ReaL has a spectacular aura aboutCHiNo4ReaL has a spectacular aura aboutCHiNo4ReaL has a spectacular aura aboutCHiNo4ReaL has a spectacular aura about
Mazworx brackets, Stoptech Evo 7-9 discs and the Cts-v calipers.
Had to modify the bracket because they are designed for non-ABS hubs and I got ABS..
CHiNo4ReaL is offline   Reply With Quote
Old 09-16-2015, 05:55 PM   #128
billyblaze
billyblaze is a well-known jackass
Have the evolution 8/9 on the front
Wanted to do the e55 6 piston from fever but he want
$400 just for the bracket alone
Has anyone done a 6 piston front brake swap at all
If so pm me I'm interested
Want to do the rears
But want the to match what's up front
Cts 4 piston rears sounds like they would
Stop better evo only has 2
Pm perfer
billyblaze is offline   Reply With Quote
Old 09-17-2015, 09:54 AM   #129
crzsteveo
^ 6 piston will require an 18 wheel up front at minuium... Check out street faction for brackets ... As for the rears, I have yet to see something
Old 09-17-2015, 01:31 PM   #130
billyblaze
Not sure of the with and offset
But have 18 MB battles with evolution 8/9
On the front now
Thanks going their now
Old 03-29-2016, 11:59 AM   #131
adey
adey's Avatar
adey is an unknown quantity at this point
Kouki V35/4-door V36 front dual pot calipers (320mm, clears SSR SL disk faces)
...on drilled stock S13 knuckles (12mm --> 14mm a la R34/Z33 Brembo):
Great when you want to run SL disk (deep dish) wheels in front, less great when you're on LMGT4s!
adey is offline   Reply With Quote
Old 03-29-2016, 03:59 PM   #132
DRFT180
DRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud of
Front:
Wilwood Forged Superlites
Stoptech Z33 Track Rotor
Wilwood BP-20 Pads
Stoptech Lines
SPL Parts Cooling Deflectors
Rear:
Z32 Caliper and Rotors
Carbotech 1521 or AX6 Pads
Stoptech Lines
Motul RPF600 Fluid
This has turned out to be a great setup for the street and track. Have had zero fade in multiple track days. Wilwoods consumable costs are way better then Brembos. Thicker pads last longer and are cheaper for the same compounds.
Still wanting to put in a Z32 master and B13 booster.
S14 Build
DRFT180 is offline   Reply With Quote
Old 03-30-2016, 12:00 AM   #133
fatduece
fatduece is an unknown quantity at this point
^Looks very nice. Did you paint the wilwoods or that's factory paint? Any reason why you didn't go with the 2 piece rotors?
fatduece is offline   Reply With Quote
Old 03-30-2016, 12:41 AM   #134
turboshoebox
turboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymore
u need R35 bbk
turboshoebox is offline   Reply With Quote
Old 03-30-2016, 01:33 AM   #135
Lees_Garage
Lees_Garage's Avatar
Trader Rating: (66)
Lees_Garage is just really niceLees_Garage is just really niceLees_Garage is just really niceLees_Garage is just really niceLees_Garage is just really niceLees_Garage is just really niceLees_Garage is just really niceLees_Garage is just really niceLees_Garage is just really nice
Feedback Score: 66 reviews
Originally Posted by DRFT180 View Post
Killer setup!
What rear pads are you running? Did you run this setup before you installed the SPL brake cooling duct? If so, did you see a difference in fade, etc?
Build Thread
@lees_garage
Lees_Garage is offline   Reply With Quote
Old 03-30-2016, 02:44 AM   #136
Hoffman5982
Hoffman5982's Avatar
Trader Rating: (25)
Feedback Score: 25 reviews
Nothing impressive, but they're as big as I can go with 15s, and would have just barely scraped if I didn't have a 5mm spacer.
Q45 front brakes. Rebuilt/cleaned/painted, Axxis Metal Master pads, Brembo rotors from a 94 Altima (4 lug), and Agency Power SS lines. The increase in stopping power is very noticeable.
Old 03-30-2016, 05:34 AM   #137
corkscrew
corkscrew's Avatar
corkscrew is an unknown quantity at this point
Which year q45? ^
corkscrew is offline   Reply With Quote
Old 03-30-2016, 08:29 AM   #138
Hoffman5982
Trader Rating: (25)
I believe these came off a 96
Old 03-30-2016, 09:05 AM   #139
crzsteveo
I hoping to finish Up my rear upgrade to compliment my ctsv brakes up front. Going with gktech rear dual caliper set and running wilwood calipers and stock ones for ebrake. Only rear setup I've found that will work for what I want.
Does anyone have recommendations on a proportioning valve??
Old 03-30-2016, 09:13 AM   #140
DRFT180
I had the Wilwoods and the Z calipers powdercoated that color.
What they originally looked like
I didn't go with a 2-piece rotor mostly due to budget, and could always upgrade later.
Originally Posted by Lees_Garage View Post
Killer setup!
Updated my original post. I run Carbotech's 1521 or AX6 pads in the rear.
The brake cooling ducts have always been on the car since before doing lapping days, so I don't have a before or after comparison.
S14 Build
Old 03-30-2016, 09:32 AM   #141
adey
adey's Avatar
Originally Posted by turboshoebox View Post
u need R35 bbk
That looks SICK, but...
I wanted to keep:
1) costs down (this cost me 300 incl rotors and pads at my local junkyard)
2) # of caliper pistons/pots to a minimum -- I'm on the original 15/16 bmc and the pedal feel is still very good! and
3) wheel clearance at a maximum -- so I can run super deep dish fronts! (or at least maintain decent lip, especially now that I went and got S14 flcas and GP sports knuckles...)
Old 03-30-2016, 05:56 PM   #142
Lees_Garage
Trader Rating: (66)
Thanks! I have the SPL tension rods, and am trying to decide whether I should run their cooling ducts, or fabricate my own flex tubing ducts.
Build Thread
@lees_garage
Old 03-31-2016, 02:46 AM   #143
TheRealSy90
TheRealSy90's Avatar
Need some info on brake replacement parts. I have Jdm Kouki 180sx/rps13 front calipers and rotors on my 89 coupe.
I cannot figure out what pads and rotors to order to refurbish this setup. The jdm Kouki 180sx brakes are slightly larger diameter than the usdm s13 brakes.
Possibly the spec v Sentra rotors/pads? Maxima? I cannot find the specification for the 180sx brake size online...
Such a good signature.
Old 03-31-2016, 11:19 AM   #144
adey
adey's Avatar
IIRC it's 280mm (diameter) x 22mm (thickness) with single pot calipers. You can measure it...
Pad details (from dixcel website):
(link: http://dixcel.co.jp/sx/e36.php?enode...N+180SX+#n3037)
Old 03-31-2016, 11:50 AM   #145
Lees_Garage
Trader Rating: (66)
the brake swap thread
Check out winmax. Just call and ask, they'll have the info you need.
http://store.winmaxusa.com/winmax-w2...ml?car_make=32
I'm running W2's, and have several friends running the W3's, they are great pads.
Build Thread
@lees_garage
Old 03-31-2016, 08:59 PM   #146
TheRealSy90
Thanks for the info guys.
Old 04-01-2016, 08:20 AM   #147
fatduece
Is that a special powder for high temp brakes? (If there is such a thing) How many track sessions have you put on them, any fade in color?
Old 04-02-2016, 01:31 AM   #148
Mike s14
Mike s14's Avatar
Mike s14 is an unknown quantity at this point
I have z33 track calipers and rotors in the front and in the back. I needed to change one of the "ears" on the knuckles to make the calipers fit. I'm using steel aftermarket knuckles, so it wasn't a big problem. Grind it off and weld it back. Was going with a z32 handbrake setup, but couldn't get it to work. Right side didn't lock up. Probably because of the aftermarktet knuckles. Think i needed to change one of the r33 handbrake cables to a s13 one (which are normally to short if i'm not mistaken). But i just gone with a hydraulic handbrake. BMC is a z32 non abs bm57. Balance if pretty off, rear needs more force. Rear end is just to loose when braking hard. Dancing all over the place when braking hard. As you can see in the picture, the rear caliper is sitting pretty low:
Mike s14 is offline   Reply With Quote
Old 04-02-2016, 09:29 AM   #149
turboshoebox
UGh are you serious? what is all that sticker bomb bull shit you have on ur rear guards
Old 04-02-2016, 10:50 AM   #150
kashira kureijii
kashira kureijii's Avatar
kashira kureijii is making his/her stupidity well-knownkashira kureijii is making his/her stupidity well-knownkashira kureijii is making his/her stupidity well-knownkashira kureijii is making his/her stupidity well-known
God you're such a little bitch , he needs them Bride calipers
Originally Posted by bigs View Post
Just get a big sticker that says "copyright infringement"
kashira kureijii is offline   Reply With Quote
