02-11-2016, 07:12 PM | #1 |
93 240sx speedometer wiring question
I just bought a 1993 240sx convertible car is in bad shape but everything is fixable.
At least thats what I though lol Car was auto and previous owner made the conversion to manual He did not do a very good job but it works Top works Turns on with no clutch sensor But speedometer and reverse light dont work I decide to investigate Notice he didnt plug anything back to the transmission So I did it Reverse switch was broken from the tab on the transmission so I skip that for anpther day Speedometer I have a speed sensor not tested yet but following the wires I came across the first plug from the lower harness and its a gray small 2 wire plug that converts speed sensor wire black solid and green solid to yellow/green stripe and yellow/black stripe Keep going it conects to a grey medium 5 wire plug. At this time I though I had to conect the plug and fix the problem but I encounter theres no plug left this. Next to the battery there a fuse box with 3 plugs on its side One brown 5wire plug One grey 5 wire plug And a grey small 2 wire plug I realize that I have 2 identical plugs coming from transmission with different color wires. I search maybe 3 days allready finding contradicting information and no useful pictures. I also removed the gauge cluster and try following the cable that conect to speed tach. I notice they were Yellow/green stripe Yellow/blue stripe Tried following without removing the dashboard and on passenger side down where the ecu I encounter a big green plug disconected Also found only the yellow/green stripe wire going into the ecu Not sure if its the same one from gauge At this point I think I might have a manual lower transmission harness because I cant find a plug for the speed sensor plug. Did not find any wires chopped off or deleted either so ibe encounter a frustating situation here. Read somewhere that speedometer wires run the same color from one end to the other I cant find any wires color match in between fuse box and ecu. I know it might be a long shot but if anyone can help please lmk Pictures would help me alot more thanks in advance |
