12-31-2016, 12:58 PM | #1 |
sold
asking $5000 FIRM for complete car
kouki parts are gone and has stock seats will come with extra 350z seats ABSOLUTELY NO TRADES! Selling for financial reasons I can be reached at 405-501-3076 Located in Oklahoma city and willing to ship anything that fits in usps flat rate box Engine is still running in car and has about 20k since build s13 red top sr20det with Tuned ECUready to drop in and drive Built by Carters in Okc around 2012 CP 87mm pistons and Eagle rods ARP rod bolts, main bolts, and head studs Cometic MLS headgasket BC adjustable cam gears tomie 262 intake cam (recently installed and shows signs of wear. the 3rd lobe has some scaring but it wasn't bad. I re-installed and car is still pulling strong, however I would keep an eye on it) BC 264 exhaust cam BC valves and springs Isis rocker arm stoppers Isis oil pan ATI super damper Aluminum water pump pulley 740cc deatchwerks injectors ISR RS3871 Turbo Tomei extreme exhaust manifold with cometic exhaust gasket ACT stage 3 clutch with flywheel and sr20det transmission Z32 MAF with intake filter Nistune ECU Engine was tuned by Brandon Carter in Oklahoma city, who does great work on Nistune. Currently street tuned at 15PSI. Estimate to be around 350hp Dual core aluminum radiator Isis radiator silicone hoses Dual Altima fans wired to 180 temp switch Tomei Fuel pressure regulator Power by MAX intercooler Greddy RS BOV Replica Greddy blaffled catch can Turbo back exhaust 1 piece driveshaft walbro fuel pump with assembly Split Fire coil packs Wiring specialties Pro harness Bosch Battery for a miata ISR gold short shifter AEM tru-boost gauge and controller AEM wide band o2 gauge ProSport oil pressure gauge 350z cloth seats (dirty but no tears) 5ZIGEN FN01RC Wheels 17x10 and 17x9 Kuhmo 225/45/17 fronts and Goodyear 225/50/17 rears It has complete interior Sub-frames have been re sprayed. Gas tank was removes and cleaned. welded diff Dash has 2 minor cracks and steering wheel is in great shape. EXTERIOR TEIN basic coilovers 5-lug swap with new bearings new sway bar and steering rack bushings new sway bar end links new inner and outer tie rods with boots rolled and pulled quarters INTERIOR s14 leather seats (lil rough) 180sx JDM cluster with purple needles and blue led lights Bubble shit know (shortened) Bride replica shift boot s13 vented gauge pod PIONEER deck with speakers Tucked fuxe boxes aftermarket coolant reservoir Last edited by juliocesarl_405; 01-26-2017 at 12:15 PM.. Reason: Price drop, Decided to part out |
01-02-2017, 12:20 PM | #2 |
If there is enough interest in an absolutely complete turn key swap and the shell as a roller then i could part with the 2.
$4500 firm for the swap and all engine related components Including but not limited to exhaust, fans, driveshaft, gauges, etc. $4k firm for the rolling shell with type-x kit, tails,coilovers and wheels |
01-08-2017, 02:18 PM | #4 |
Ok so no one is interested in the car?
What about a part out on bigger stuff like Type x kit. $$$ Kouki Tails $$$ Engine $$ maybe trade for stock Wheels $$$ Electronics $$ Part out? |
