Old 06-23-2018, 01:55 AM   #1
6berry
6berry is an unknown quantity at this point
Huge List of Parts for Sale!
Updated 6/21/18 with a bunch of new Parts that we've found or organized. Will continue to add to the list so check back often.
Too many parts to post pictures for everything.
All parts are at Sideways Fab & Customs in Loveland, co.
Ka24de stock header $20
Ka24de intake manifold $20
Ka24de Alternator $40
Ka24de Starter $50
KA24DE Crank Pulley $20
KA24 Lightweight Flywheel $75
Sr20det intake manifold $150
Sr20det turbo exhaust elbow $40
Sr20det OEM turbo manifold $40
SR20DET CAS $120
SR20 Lightweight Flywheel $75
Sr20 coil pack cover $30
RB25DET lower intake manifold $50
RB25DET Factory Engine Mounts $80
LS truck headers $20 each
LS truck rear sump oil pans $60
LS truck water pump $80
LS truck crank pulley $40
LS T56 S13 Swap Transmission Mount $80
LS Valve covers $50
LS gen 3 valley cover $60
LS F body power steering pump $100
240sx Dual Rear Caliper Brackets $140
240sx solid transmission mount $40
240sx Engine Torque Damper $20
240sx Front Subframe Connector Bolts $20
240sx Aluminum Radiator with fan $80
240sx Adjustable rear toe arms $20
4 and 5 lug drift spares $10-$20 each
5x114.3 350z Track Edition Wheels 18x8 18x8.5 $400
5x114.3 Mustang Cobra Reps 17x10.5 $300
Chevy 6 Lug 22" Wheels With Good Tires $300
BMW E46 Stock Wheels $100
Work VSSD 17" 3" Lips $100 each
Work VSSD 17" 3.5" Lips $100 each
Work VSSD 17" 6.5" Barrels $100 each
Work Meister 18" 6.5" Step Barrels $150 each
BMW M Parallel Wheels $400
Factory Silvia/180sx Intercooler $50
S13 hatch privacy cover $60
S13 Silvia front passenger fender $40
S13 hatch taillights $100
S13 Bare rear subframe $80
S13 front subframe $80
S13 rear seats $40
S13 door panels $40 each
S13 chassis harness $150
S13 Engine Bay Harness $100
S13 radio bezel cracked near shifter $20
S13 Bare passenger door $20
S13 dashes cracked $20
S13 glove box $40
S13 electric mirrors $20 each
S13 manual mirrors $20 each
S13 coupe drivers taillight $30
S13 fuel sending unit. No pump $40
S13 Hatch Drivers Side Quarter Glass $60
S13 Differential Case without Pumpkin $40
S13 Plastic Headlight Bezels $40 each
S13 Steering Column Cover Gauge Pod $20
S13 Hood Hinges $20
S13 4 lug hubs $20
S13 rear knuckles $20 each
S13 under dash AC/heat/blower $100
S13 manual driveshaft
S14 drivers door $20
S14 Zenki Taillights $100
S14 chassis harness $150
S14 ka distributor $60
S14 zenki grill $80
S14 front crash bar $40
S14 throttle pedal $40
S14 zenki clear headlights $80
S14 A18-E88 G94 HU Ka24de ECU $60
Aggressive Aero hood vents $120
Gold m12x1.25 lug nuts $20
Misc mufflers $20 each
Magnaflow 3" in 3" out muffler $20
Sideways Fab Hydro Ebrakes $90
LED light bars
Eibach 8" 400lb/in Springs 2.25" ID $60
Greddy Oil Catch Can $60
Misc AN Lines and Fittings
5x112 20mm H&R spacers $50
Forge 007 Diverter Valve $100
Universal roof racks $40
Misc head units $10 each
36" cherry bomb muffler $40
2 48" cherry bomb mufflers $50 each
Misc blown turbos $40 each
Na Miata windshield $60
NB Miata dash $20
NA Miata Bare Rear Subframe $40
NA Miata gauge cluster $80
NA Miata Turn Signals $40 each
NA Transmission $200
NA Miata Headlights $100 each
NA Miata Brake Booster $30
NA Miata Speedo Cable $60
NA Miata trunk $40
NA Miata PPF $40
NA Miata 1.6 manual driveshaft $50
NA Miata brake booster $40
NA Miata clutch and brake pedal $80
NA Miata brake master and prop valve $40
NA6 ABS brake module $80
BMW m52 intake $20
E36 front subframe $80
E36 steering rack $40
E36 gauge cluster $60
E36/e46 suspension arms $20
E36 coupe hood $50
E36 Coupe/Convertible trunk $40
E36 windshield $100
E36 black non-airbag dash $100
E36 stock radiator $20
E36 sedan passenger fender $20
E36 H&R 1" Rear Lowering Springs $80
E36 stock headers $20
99-02 E46 Coil Pack Wiring Harness $20
E46 Barely used Headers with Cats $100
E46 Control Arms Pair $60
E46 Knuckles $25 each
E46 Front Subframe $80
E46 2.93 Open Diff $50
E46 Gauge Cluster $40
E46 Drivers Axle $20
E46 Front Brake Calipers $20 each
E46 Air Lift Suspension with V2 Management $2500
E46 M3 Rear Diff and Subframe $1000
E46 330i Brakes with dual Rear Calipers $600
E46 330i Trailing Arms $350
E38 7 series alpina lip $80
VW VR6 12v Valve Cover $10
VW Mk5 TDI turbo $150
Mercedes OM606 Exhaust Flange $80
350z solid trans mount $40
350z manual brake pedal $40
02 WRX parts- some fit from 02-07
Bug eye WRX hood $100
WRX trunk $40
WRX doors $40 each
WRX header $20
WRX bugeye headlights
WRX gauge cluster $40
WRX cluster bezel $20
WRX subframes-make offer
WRX rear differential-make offer
WRX manual driveshaft $50
FRS/BRZ solid trans mount $50
FRS/BRZ Alternator $30
FRS/BRZ AC Compressor
FRS/BRZ FA20 Cylinder Heads
FRS/BRZ Camshaft Assemblys
FRS/BRZ Misc Engine Parts
FRS/BRZ Oil Pan $80
Mitsubishi starion/Chrysler conquest grill nose $40
Ae86 hood $50
Ae86 hatch $50
Ae86 passenger door $50
Ae86 dash support bar $20
Ae86 passenger taillight $80
Ae86 front bumper support/crash bar $60
Ae86 front fenders $50 each
Old celica seat pulled out of the ae86 $20
AE86 Front knuckles $20
AE86 Tokico Rear Shocks $20
AE86 Drilled and slotted rotors $50
4age 7 rib bare block no main caps $20
Ae86 manual driveshaft $50
Ae86 fuel tank $50
Ae86 passenger quarter window $50
Ae86 steering wheel $20
Ae86 maf/afm $20
Ae86 ecu $50
Ae86 throttle body $40
IS300 Stock struts $20
GS300 Stock struts $20
Lexus GS300 Auto Trans $150
Will ship smaller items if buyer pays shipping.
Call or text me at 3218060526
6berry is offline   Reply With Quote
Old 06-23-2018, 02:55 AM   #2
HannyatheS14
HannyatheS14 is an unknown quantity at this point
can you pm some pics of the greddy catch can ?
HannyatheS14 is offline   Reply With Quote
Old 06-23-2018, 09:56 AM   #3
6berry
Text me 3218060526
Old 06-23-2018, 11:02 PM   #4
RalliartRsX
Trader Rating: (32)
Feedback Score: 32 reviews
Rules say you need to post pics.
With that said, interested in the lightweight flywheel. Can you give me more information?? Who makes it?? Weight?? Can it be ran or or there hot spots??
Old 06-24-2018, 07:30 AM   #5
richmond82
richmond82's Avatar
Trader Rating: (30)
richmond82 has a spectacular aura aboutrichmond82 has a spectacular aura aboutrichmond82 has a spectacular aura aboutrichmond82 has a spectacular aura aboutrichmond82 has a spectacular aura aboutrichmond82 has a spectacular aura about
Feedback Score: 30 reviews
WTB 240sx Dual Rear Caliper Brackets $140
Drake: 95 Swapped S15SR Z32 Swapped TT 1991Vert
richmond82 is offline   Reply With Quote
Old 06-24-2018, 11:05 PM   #6
6berry
Here's a link to info on it and pics. https://sidewaysfab.com/products/lig...n-ka24de-ka24e
Old 06-25-2018, 10:21 AM   #7
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Post pics of the aftermarket stuff at least.
You have 2 days to do so before I delete this.
