Old 10-23-2017, 12:10 PM   #1591
Stumped
Stumped is an unknown quantity at this point
Originally Posted by 2muchboost View Post
Geez Stumped thats pretty impressive. You dont see too many of those diffs getting grenaded. Sorry I have no diff related info for you but mind giving an overview of your setup?
Its just a head/cam ls3 with a 250 shot of nitrous. It has a 4l80 trans which is just a turbo 400 with overdrive. 27x11.5x15 hoosier quick time pro tires. The pass it broke on was actually without the bottle and it goes low 1.40 60's off the bottle.
Stumped is offline   Reply With Quote
Old 10-23-2017, 12:34 PM   #1592
jr_ss
Originally Posted by Stumped View Post
yes but the q45 diff is still 200mm and thats what I broke
Time for an R230...
Old 10-23-2017, 07:46 PM   #1593
TheRealSy90
TheRealSy90's Avatar
I can't remember who maybe Mazworx but someone was developing a kit to drop in the 03/04 Cobra IRS components.
Such a good signature.
Old 10-23-2017, 08:12 PM   #1594
hanzbrady
hanzbrady's Avatar
hanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura about
Close...
This is for S14 subframes only and uses the Ford Explorer IRS 8.8 rear end. This setup can handle over 1,000HP with absolutely no issues.
http://www.mazworx.com/mazworx-240sx-8-8-irs-kit.aspx
If you send in your subframe and get the custom DSS axles you're only looking at $3,345.00
Includes:
Laser cut unwelded brackets
Rear Cover
Solid Aluminum Diff Bushings
Hardware
Customer must use:
07-10 Ford Explorer 8.8 Diff (comes 28 spline)
Q45 or Z32 TT rear hubs (32 spline)
You can get a spool dirt cheap as well as a 1350 chromoly slip yolk and an upgraded pinion with a better spline count.
The best part, everything can be over nighted from Summit or Jegs, if you're in a real bind many local speed shops will have 8.8 parts.
The bad part is that I don't work there anymore to sell it to you guys lol. In all reality though if someone does seriously want the kit I could sell it through Real Street for the same price.
[email protected]
hanzbrady is offline   Reply With Quote
Old 10-23-2017, 11:25 PM   #1595
Stumped
The 8.8 would be the ultimate but I'm really trying to avoid the aftermarket axles and the cost associated with it if possible. Thats a lot of coin to still be irs at the end of the day
Old 10-24-2017, 07:51 AM   #1596
hanzbrady
hanzbrady's Avatar
I see where your coming from, the setup is for guys who want the ultimate compromise in street car handling and drag car performance.
Another nice thing is that this allows you to remain class legal for classes such as Street Fighter that don't allow for modification of the chassis to fit a proper 9" with a 4 link.
Just a note this setup has cut a 1.16 60'
[email protected]
Old 10-24-2017, 10:24 AM   #1597
jr_ss
Agreed, if you're strictly drag, it doesn't make sense. However, I'm sure any fab shop can duplicate this setup relatively easily.
Old 10-24-2017, 02:59 PM   #1598
RedSled
RedSled is making his/her stupidity well-knownRedSled is making his/her stupidity well-knownRedSled is making his/her stupidity well-knownRedSled is making his/her stupidity well-knownRedSled is making his/her stupidity well-known
Using the handbrake to load the transmission,can anyone say what rpm you launch at ,do you hold the rpm steady or fan the rpm ,average about 500hp with et drag slicks 26x10
RedSled is offline   Reply With Quote
Old 10-24-2017, 09:25 PM   #1599
TheRealSy90
I'd assume you want to hold it steady, as if you had a stall on the torque converter.
Old 10-25-2017, 10:14 AM   #1600
jr_ss
There are too many variables to offer you a set rpm. I'd raise and hold steady, slip the clutch as you can. You really should look into some type of launch control. I'm assuming you're boosted? If so, it'll be a dog off the line if you have a decent size turbo.
Old 10-25-2017, 12:27 PM   #1601
RedSled
Well got nitrous coming in at 4500rpm and at 80% throttle
Old 11-06-2017, 06:21 AM   #1602
Sforteen
Sforteen is an unknown quantity at this point
I used R32GTR axles with my R230 swap, i did a small write up on the swap on this site.
Sforteen is offline   Reply With Quote
Old 11-06-2017, 07:30 AM   #1603
hanzbrady
hanzbrady's Avatar
Hey guys,
Since I didn't see anyone mention this, at Import vs. Domestic this past weekend Mazworx broke the world record for fastest and quickest SR20 running a 6.685 @ 217.35 MPH.
https://www.instagram.com/p/BbE3VsSF...ken-by=mazworx
[email protected]
Old 11-06-2017, 01:21 PM   #1604
Sky80
Sky80's Avatar
Sky80 is an unknown quantity at this point
Hey guys,
Damn.... Video?
'98 Kouki Build in Progress
'10 Subaru Legacy 2.5GT
Sky80 is offline   Reply With Quote
Old 11-06-2017, 02:16 PM   #1605
Tom N
Tom N is an unknown quantity at this point
Originally Posted by Sky80 View Post
Damn.... Video?
just go to mazworx FB page and you`ll see it.
98 240sx w/ S15 SR20DET, T2 20g, 11.22 @ 124.98
Tom N is offline   Reply With Quote
Old 11-06-2017, 07:08 PM   #1606
Flicktitty
Flicktitty's Avatar
Flicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to behold
Send a message via AIM to Flicktitty
And Duy, with the "White Rice" 2JZ-GTE S14 went 6.99 @200 MPH. then went 204MPH in a later pass, apparently, it still has more left in it.
2JZ-GTE Swapped S13 Coupe - 1994 Supra Turbo
Flicktitty is offline   Reply With Quote
Old 11-06-2017, 07:52 PM   #1607
Sky80
Sky80's Avatar
Chris Delgado at Prospeed is who tuned my 2j s14. Amazing tuner, not surprised that car ran that fast
Old 11-20-2017, 09:12 AM   #1608
Tom N
Curious to hear how far anyone using the DSS "600hp" axels have managed to push them with out breaking?
Starting to break stock axels every couple passes now.
Old 11-20-2017, 09:15 AM   #1609
hanzbrady
hanzbrady's Avatar
I'm pretty curious about this too since at that power level the realistic weak points become the ring and pinion as well as the stub shafts.
The only value I see int hose 600HP axles is for street cars or drift cars that don't plan on dead hooking 600HP with a sticky tire.
[email protected]
Old 11-20-2017, 09:26 AM   #1610
Sforteen
why even use the DSS axles? small spline still..
Old 11-20-2017, 09:30 AM   #1611
hanzbrady
hanzbrady's Avatar
Like I said they make sense on higher HP cars that slip the tire vs hooking it like in a drag car.
Drift cars tend to rip CV joints apart and snap the actual axle so the DSS kit makes sense for that.
I just don't think it's fair to call them "600HP Axles" I'd say they should be called something more along the lines of drift or road race axles.
A 600HP kit for drag racing would at least need to come with better stub shafts imo.
[email protected]
Old 11-20-2017, 09:53 AM   #1612
Tom N
The DSS axels are the easiest way to upgrade a part that’s currently breaking every couple passes.
Just trying to see if there are people actually getting away with using the 600hp ones as there’s a big cost difference between the 600 and 900hp ones.
This is a 600hp SR20 S14 that has a race weight of 2750 and uses a 26x10 ET Street bias ply tire.
Old 11-20-2017, 09:57 AM   #1613
hanzbrady
hanzbrady's Avatar
The setup that seems to be the best compromise between price and benefit is the R230 differential with modified stub shafts and 350z axles or a R230 with the Q45 and 300ZX TT axle.
I've personally seen the latter make it until the 1200HP mark.
If it were me and we were ignoring the cost I'd do the IRS 8.8 in a heart beat because it solves every issue at once.
[email protected]
Old 11-20-2017, 09:59 AM   #1614
Tom N
Also from what I'm told the difference between the 600 and 900hp Axel is the outer cv. The 600 has the Porsche cv on the inside only where the 900 has the Porsche cv on the inner and outer. The rest is the same.
It's the inner cup on stock axels that breaks every time on the driver side axels right now.
Old 11-20-2017, 10:01 AM   #1615
Tom N
I've personally seen the latter make i until the 1200HP mark.
Finding the q45 with proper axels is the hard part. Has to be the later one as a 3.54 gear won't work. Looking for a more simple solution. Fabbing in a 8.8 isn't happening right now.
Old 11-20-2017, 01:28 PM   #1616
greenpat01
greenpat01's Avatar
greenpat01 is an unknown quantity at this point
I would like to know this too , How much the 600hp dss axle on stock s13 r200 diff setup can hold ? 500whp s13 street driven and occasionally 1/4 mile ..
greenpat01 is offline   Reply With Quote
Old 11-25-2017, 02:00 PM   #1617
juiced305diesel
juiced305diesel is an unknown quantity at this point
I have a s14 sr20det powered by a pte6262. It currently makes 680ish to the wheels. I have a tomei 2way and dss 600hp axles and i have yet bust them. The car is currently on a 285 nt555r drag radial.
"Being a SSR wheel nude model is NOT easy, I just make it look like it is!"
juiced305diesel is offline   Reply With Quote
Old 11-25-2017, 03:40 PM   #1618
Tom N
What kind of 60 foot do you pull? What’s your cars race weight?
Old 11-26-2017, 11:06 AM   #1619
juiced305diesel
I do not drag race. Car weighs 3080 with me in it full interior fully loaded model.
Old 11-30-2017, 09:14 AM   #1620
RedSled
What will be the most ideal diff ratio for 550hp and a 26x10 et drag slicks
