04-11-2018, 10:05 PM | #1 |
Fresh Rebuild, LS2 CAS P0343 Code Help Please
Hey guys,
I recently finished a rebuild on my 2002 5.7L and have had some weird issues. Let me start out by saying that my engine is in a Nissan 240SX using the factory harness modified and merging with my Nissan body harness. I keep getting the P0343 code related to the cam sensor voltage above normal. I did relocate and extend the harness as I switched to the LS2 front timing sensor and sealed off the hole on the back of my block where the initial sensor was located. I will also say that I did swap the two outside wires on the connector as I have read to do so since the wiring changes. I have since replaced the sensor with a brand new GM sensor, and the original sensor didn't show any signs of wear or touching cam gear. Motor Specs: 2002 5.7L 109k Miles before rebuild Forged rods, pistons 243 Heads 3-angle job, slightly decked for flatness Clevitte bearings for Mains, Cam, Rods Fluidampr Crank Pulley GM Hot Cam .525/.525 LS6 Injectors flowed to 31gpm LS2 Front timing cover with new sensor Double roller timing chain GM Blue BeeHive springs Manley Solid Pushrods Factory MAF/IAT sensor Factory Intake with 78MM throttle body 91 Octane gas only Camaro front accessories T56 Transmission with Luk OEM clutch About 1000 miles on the rebuild, did a break in oil change cycle and kept it under 4500 rpm for first 500 miles. So whats odd to me is that the car logs the code and runs decent, then the next start the car wants to die every-time I stop moving but the code isn't active and is a pending state. The ECM was modded with HP tuners but only to turn off the VATS, EGR, and other related items. I have not had it professionally tuned yet that is on the list but I want to make sure that I have this issue corrected before doing so. If anyone has any ideas that would be great as I have read every P0343 thread on the internet including LSTech with no success. |
04-17-2018, 10:11 AM | #3 | |
When switching front timing cover if aftermarket to account for the double roller, make sure the CAS is between the acceptable range in order to pick up the signal. I had to shave the sensor to go in more (I should have milled the front cover but that's too much work for what I want right now) so I trimmed the little tangs off the sensor and it went it just a hair closer and no more code. Thanks for the response man. |
