Old 08-08-2020, 02:06 PM   #1
Corbenik
Corbenik's Avatar
Corbenik is an unknown quantity at this point
Gauge cluster not working
I recently purchased a 1995 240sx, the previous owner swapped a sr20de into it. The speedometer, temp & fuel gauge does not work. I thought the cluster was just fried, so I bought another one and it is still the exact same. Not sure what it could be. Any help would be greatly appreciated.
Corbenik is offline   Reply With Quote
Old 08-08-2020, 02:14 PM   #2
coupesallday!
coupesallday!'s Avatar
Trader Rating: (18)
coupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the rough
Feedback Score: 18 reviews
Send a message via MSN to coupesallday!
Did you try searching? Like on google? 9/10 times google has the answers man
Throw some glitter flake and crazy glue in there.
coupesallday! is offline   Reply With Quote
Old 08-08-2020, 05:17 PM   #3
S14rebuild
You need to download the fsm for your car and ceck wiring. Check your f4 plug...thats where the wiring passes thru from engine to chassis, regarding speedo,rpm, coolant temp, fuel...
Welcome to zilvia, NO ONE WILL SPOON FEED U HERE
Old 08-08-2020, 05:43 PM   #4
Corbenik
Corbenik's Avatar
Thank you for the info I will check that out!
fuel gauge, gauge cluster, speedometer, temp guage.
