07-20-2011, 04:10 PM | #6931 | ||
AFC #1
You will notice speed-bumps and potholes a lot more because there is no rubber bushing to absorb the pull on the rod from the wheel hitting the object. The creaking is probably just the new bearings setting. But a cracking noise isn't good. Are the rod ends centered in the bearing? Also, inspect the TC rod brackets that bolt to the core support and frame. The original owner of my car liked to park on curbs so they were bent and replacing them got rid of the squeaking sound.
07-20-2011, 11:53 PM | #6933 |
^^Dont do it....... Seriously.
and you quote by clicking the little button in the bottom right of your original post. It says "quote" on it.
S.P.P.S. Member #00 **CoUpe LOve** Member #00 |
07-21-2011, 01:16 AM | #6936 | |
silvia front end coils stage 3 clutch smogged tagged CONS: 96 s14 not running or smogged or tagged and salvaged title How is that even a question? Just the fact that your going from a clean title running smogged tagged car to the polar opposite is enough of a reason. Just SR the S13 and buy a clean title cheap s14 down the road. Just take my word for it, stick with the cleanest car possible. Unless your looking for a project. Then still keep the s13 and build a project on the side.
07-21-2011, 01:24 AM | #6937 | |
Yeah ill probablly go ahead and do that ... Already have sr sitting there waiting to be swapped in... Thanks helped alot.
07-21-2011, 11:16 AM | #6938 | |
The brackets are slightly bent on the driver side but I don't think its bad enough to affect the tc rods. As for the alignment. I haven't gotten it done yet. But I did get it checked out and the caster seemed pretty even.
Single Cam Stuff On Deck!!! Last edited by nismonismo240sx; 07-21-2011 at 12:00 PM.. |
07-21-2011, 11:51 AM | #6939 |
Trader Rating: (31)
Feedback Score: 31 reviews
S15 complete Subframe and Rear end - Drop in S14?
Ok..seen mostly threads on fitting it to a S13 (which that can clearly be done) with the Misaligned Bushings Stance makes...but
Will it fit in a S14 with No modifications to Drive shaft (same OEM shaft) and 5speed 13SR Trans?? This will be a Complete Rear end with pumpkin/HLSD,axles,all the Arms etc? Any Confirmation? Everyone seems to say "its the same" Need to know ASAP.
z-tERty-2 |
07-21-2011, 03:46 PM | #6941 |
Moonface Coilovers
so i am about to order some coilovers finally and ive decided i want a set of moonfaces. they have two coilover types damper d style and damper g style, i cant go to their homepage for some reason and ive searched around and cant find what im looking for. what i want to know is what is the difference in spring rate and dampening between the two. also if anyone is currently using them how well they like them and if theyd recommend them, if not what coilover do you recommend for the same price range?
07-21-2011, 03:56 PM | #6943 |
07-21-2011, 05:02 PM | #6944 | |
AFC #1
S14/S15 Front 10kg/mm, Rear 5~9kg/mm(progressive) S13 Front 8kg/mm, Rear 5~9kg/mm(progressive)
07-22-2011, 12:06 AM | #6948 |
My Sr will start hesitating when Im stepping on the gas at a constant speed, but will go away if I step on it or let off. Anybody know what it could be?
Jessefuckinwood Street Prowl |
07-22-2011, 02:03 AM | #6949 |
FLange fell off of my 180sx VLSD pumpkin
My flange fell off of my 180sx pumpkin which i bought a month ago Is there any way of fixing like at a shop or something or if i leave it like that and put the axle would it be secure enough not to fall off
07-22-2011, 02:48 PM | #6950 |
Has anyone used something like this?
It's an 80mm Apexi Exhaust Control Valve. I recently purchased an Isis 4" dual straight pipe and I expected it to be loud, but I was wondering if this would be worth it? Just to quite it down during night times and whenever it is needed. Also, where does it install? In between the cat/test pipe and the exhaust? Thanks! |
07-22-2011, 03:44 PM | #6951 | ||
Email a Seller and ask them to weigh it for you.
Uh what? look in the for sale section, post a wewanted to buy ad, look through or advertisers, or google it. why would you ask that here? Quote:
Plenty of people us them and all the questions you just asked are EASILY answered by the apexi website. Not to mention numerous videos of it installed on youtube. Imagine that....... the Apexi site even has installation instructions.
07-22-2011, 04:51 PM | #6952 |
Ok guys does anyone know off the top of their heads what Wed Kranze wheels are made off. Is it alluminum inner barrel and stainless steel outer lip? Alluminum face? Im trying to get a quote for chroming and the shop needs to know the metal types of the wheel.
BX|Photo LS400 - Slammed | Fitted | Loud |
07-22-2011, 05:56 PM | #6955 |
That's the first thing I do, before I ask questions. I have seen everything you are talking about. I was just wondering if more s-chassis individuals have experience with them. I appreciate it, but I'm not one to ignorantly ask questions.
07-22-2011, 06:21 PM | #6956 |
I need help my e brake doesnt work when i drift ive tightened and loosened the little bolt thing on the ebrake and it doesnt change anything but it will work when i put it in park mode (drift knob) any idea what it could be?
07-22-2011, 07:42 PM | #6957 |
is this the correct spot for this?(vacuum block)?
installed a vacuum block and for some reason its not strong enough to open my BOV ,also i might have a vacuum leavk did the carb cleaner trick and cant find nothing....my questions are is this vacuum block in a good place?(dont mind the black vacuums,their teed into eachother because i didnt have caps) also when i removed my EGR ,i was left with one open vacuum i plugged with a screw scene in this picture,but now using it for my boost gauge ..just figured id show incase i was doing somthing wrong..any ideas?thanks |
07-22-2011, 09:29 PM | #6958 |
Trader Rating: (60)
Feedback Score: 60 reviews
Ok I'm trying to get vlsd for my stock s14 5spd I wanna Get vlsd but still remains stock I got a guy selling me an an s14 vlsd but the guy selling one doesn't know if it's a jdm or usmd or if it came from at or mt. I know they have different gear ratio. My question is there a simple way of finding out and how dose different ratio effect my car?
Want to roll fenders, custom gauge pod pm me |
07-22-2011, 09:35 PM | #6959 | |
07-22-2011, 09:43 PM | #6960 | |
Trader Rating: (60)
The ultimate final drive gear ratio thread. : 240SX Technical Forum
