06-20-2015, 04:56 PM | #1 |
My Midnight Purple S1 S14
Hey guys. My name is Ryan from the Gold Coast, Australia. I have been on the forum for a few years now and I finally got my S14 running a few months ago. I got it at the start of 2013 as a stock shell with no running gear which worked out perfect as I already had a RB25 motor and gearbox from my old S13.
The build was the smoothest one. Which build goes smooth tho. Had alot of drama with the first painter. So I had the get whole car painted again. Here is a run down on the S14: Power: 512Hp on 22psi Engine: RB25 S1 motor RB26 engine covers Solid engine mounts Camtech 256 cams Tomei cam gears New valves Metal headgasket ARP headstuds New water pump gates timing belt Slide industries custom plenum 6boost manifold HPC coated Garret 35r turbo Turbosmart 50mm wastegate Turbosmart bleed valve 3" dump pipe 3" stainless steel exhaust with 5" tip Sard fuel rail 2000cc bosh injectors Turbosmart 1200hp fuel reg Walbro E85 fuel pump Braided lines used through out Custom intercooler pipes Koyo radiator X2 areoflow thermo fans Custom oil catch can and over flow bottle in one Spitfire coilpacks Drivetrain: RB25 gearbox Custom gearbox crossember Solid engine mounts NPC 10" button clutch 1 piece tailshaft R200 R33 shimmed diff 5 bolt drive shafts Electronics: Haltech E11 V2 Racepak Dash Custom engine loom with only whats needed and tucked Engine bay fused relocated to underneath the dash Holden astra electric powersteering pump mounted in the boot. Wheels brakes and suspension: Work vskfs 18x9.5-6 and 18x10.5+2 rear Achillies 215 35 front and 235 40 tyres BC coilovers DBA Slotted rotos all round with red stuff pads Braided brake lines 25mm extended front control arms maxima tie rods Cusco castor arms cusco toe arms Body work and paint: Navan front bar Navan side skirts Navan rear pods JDM front guards JDM rear bar Orgrin boot lip Ganador side mirrors S2 taillights Dmax clear indicators Smoothed and shaved engine bay Rolled front gaurds Pumped rear guards Painted all in Honda Oddessy purple Interior: Stripped rear half of interior Cusco 6 point rail cage with harness bar Bride Zeta 3 seats with rails to suit Crow enterprize purple racing harnesses Nardi deep corn D1 spec quick release wearelikewise gear knob all new roof lining and carpet Battery in boot Painted rear half on interior and boot Some build photos free image uploading 20mb image hosting free upload image hosting image free photo upload upload a picture pic upload how to do a screenshot on a pc how do i print screen image upload without registration free adult image hosting picture sharing image upload no compression screen grab screen shot photo sharing screen capture software image upload no size limit free upload image 20mb image hosting |
