11-22-2014, 02:41 AM | #1 |
91 240sx steering issue
Hi everyone!
New here! Been lurkin for a minute while fixing up my car and so far was able to search and find everything i need until now. So i recently snagged a 91 240sx off craigslist. It had some issues. But I got it running for 700$ total build cost (including car) so far. So heres the issue. I will be driving down the road, and speeds of 40-55mph can (but dont always) cause vibrations. These vibrations can be barely detectable or really scary. Also, at any speed if I hit a bump or turn slightly in the right direction, the steering wheel will turn about 45 degrees left and the wheels will continue straight. BOTH the vibrations and the steering issue can be resolved when the brakes are applied. The steering will straighten up and the vibration will stop. The car has no power steering. I will also hear the occasional clunk from the suspension that I believe to be from bad/failing parts loosening up. I know the radius arms/tension rods and their mounts are bad/worn out and the tie rod ends are basically shot. The wheels/tires were vibration free on another vehicle and both have hub-centric mounting. The hubs, bearings, and brakes are all new and good. But I don't think either one of these things could cause the wheel to turn that far to the left while the wheels stay straight or those massive vibrations. I am trying to get together a list of parts I will need to correct all these issues. So far I have on my to-get list: Megan racing tie rod ends Nismo power brace Megan racing radius rods I think that should clear up most of the vibration but I doubt that will fix the steering issue. That's why I am here. Is there any tests I can do? Am I possibly looking at a bad steering rack? If you don't think its diagnosable with the current known bad parts, let me know and I will fix those first. I was just trying to get an idea of what this will cost overall before I pick up a wrench. Thanks for checking out my post and any help provided. |
11-22-2014, 09:10 AM | #2 |
Replace the tie rod ends and any other bushing or joint in bad condition.
If you still have the issue, refer to the link below. 5th post: http://zilvia.net/f/showthread.php?t=314142 |
11-22-2014, 10:08 AM | #3 |
The Architect.
Trader Rating: (392)
Feedback Score: 392 reviews
You're dealing with an approximately 24 year old car.
If these parts haven't been replaced, you should do so: Front lower control arms Tie rods/ends Tension rods Swaybar bushings/endlinks Steering rack bushings You might also want to verify that your hubs/bearings aren't falling apart. I once had a friend not fully tighten down my front hub after a swap. It shook like crazy, but stopped once I applied the brakes. The majority of the parts listed above are very affordable these days and well worth the money if you want the car to handle as it should. |
11-22-2014, 10:30 AM | #4 |
Lift the front end up and wiggle the wheels side to side like your turning. Feel for play. If there is excessive movement then replace wherever your extra movement is coming from. That would be the cheap way of replacing only the worst damaged parts. On my own car I replaced everything however. As preventative maintenance
11-22-2014, 06:45 PM | #6 |
Honestly sounds like bad steering rack bushings. My car did something similar but not nearly as drastic of a change in the steering wheel. My guess is I just caught mine early on and yours is totally gone. I also replaced everything else suspension wise after that but the problem went away with just the steering rack bushings.
