Old 10-14-2008, 10:50 AM   #1
gripDRIFTschassis
gripDRIFTschassis is an unknown quantity at this point
s13 High idle at start up then stall
Ive had this problem for a few months..havent drove the car for awhile cause of this
I start the car up and idle will go up to 3k and then eventually stall..i would have to give it gas to keep it running until operating temp, even at operating temp idle is a little rough. If i give it gas idle will shoot up and sometimes stay around 3k =(. Ive been searching and im leaning towards the coolant temp. I changed the tps but no luck on that.
gripDRIFTschassis is offline   Reply With Quote
Old 10-14-2008, 02:32 PM   #2
Erjay1
Erjay1's Avatar
Erjay1 is making a name for him/her selfErjay1 is making a name for him/her self
check idle control valve and coolant temp sensor.
Erjay1 is offline   Reply With Quote
Old 10-15-2008, 03:29 AM   #3
cotbu
cotbu's Avatar
good advise!! and check the ecu for codes
Old 10-15-2008, 10:57 AM   #4
gripDRIFTschassis
THANKS...ill let you guys know when i get back to NY
coolant, idle, sensor, temp, tps
