Old 08-10-2014, 07:19 PM   #1
FLG
FLG's Avatar
FLG is an unknown quantity at this point
KA WTB: Looking For Built KA in Florida
Looking for a build KA for my S13.
Decided it might be cheaper if I can find a already built engine instead of buying the parts & paying someone to install them.
If you have a built KA24DE you're looking to sell in Florida please send me a PM.
Thanks
FLG is offline   Reply With Quote
Old 08-10-2014, 09:13 PM   #2
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
Feedback Score: 37 reviews
If you've got a stock motor to trade id do $1200 for a built KA-t with everything you need. $1100 for your stock KA with motor harness and ecu.
15,000 on a rebuilt motor with a t3/t4 turbo last dyno'd at 312rwhp @ 7psi currently running 11psi on a new tail waste gate & spring.
WillEastS14:
mannn u whylin son.
but that shyt has SWAG
KA-T for life!
Old 08-10-2014, 09:40 PM   #3
Memberofthe600hpkaclub
Memberofthe600hpkaclub's Avatar
Memberofthe600hpkaclub is an unknown quantity at this point
FS fully built ka25de (not a mistake)
All new freeze plugs
New oem oil pressure relief valve
New oem lower cover/oil pump
Arp main studs
Clevite77 main and rod bearings
Eagle h beam rods
Wiseco pistons 9:1
Block Cnc decked
Bored .060 over
New front and rear main seals
New timing set
Cnc milled head
Custom cometic hg to retain factory deck height
3angle valve job
New oem valves
New valve seals
New valve guides
Bc dual valve springs w/titanium retainers
Full race port and polish with bowl blending
Crower .280/.280 cams
Jim wolf adjustable cam gears
11mm oversized arp head studs
Steel timecerts in the exhaust bolt holes
New water pump
New thermostat
Trendstone cast t3/4 manifold
Copper exhaust gasket
New felpro intake mani gasket
-10an tapped oil pan
Turbo and lines not included
$2000
Memberofthe600hpkaclub is offline   Reply With Quote
Old 10-07-2014, 06:17 PM   #4
FLG
FLG's Avatar
Bump.
Still looking and got cash to waste.
Old 10-18-2014, 12:59 PM   #5
FLG
FLG's Avatar
Still looking around for one.
Old 10-26-2014, 07:22 PM   #6
Hxc_Nismo
Hxc_Nismo's Avatar
Hxc_Nismo is an unknown quantity at this point
I have one in Missouri, It's fresh and only has 3k miles on it, I just pulled it for an sr swap. I have parts list and recipts. Pm me for details.
Hxc_Nismo is offline   Reply With Quote
Old 10-26-2014, 07:23 PM   #7
Hxc_Nismo
Hxc_Nismo's Avatar
I also have video of it running before I pulled it yesterday.
240sx, built, florida, ka24de, s13
