10-27-2016, 01:21 PM | #1 |
2JZGTE Swapped Jeep Wrangler
Hi Everyone,
Up for Sale/Trade is I believe the only one in its existence like it in the states, my 2JZGTE swapped 97 Wrangler. Don't get much time to drive it, so wanted to see what offers I get. The truck has not been dyno'ed but is very quick, it has an estimated power of 350+ will make a lot more with a bigger fuel set up and aftermarket ECU .Lots of mods. 1997 Jeep Wrangler, About 90k on the body and much less on the JDM Swap Currently RWD but can be configured to AWD with the addition of a drive shaft/half shaft. (all the components are there. Stock motor 2JZGTE non VVTI / Stock ECU 15psi of boost 2JZ motor mated to a Jeep 5spd gearbox with custom adaptor Welded Rear Diff - (does chirp around corners) Greddy Intake Manifold HKS blowoff valve Compound turbo set up ( Borgwarner S372 & Holset HX35 ) Black interior 4x Rsx Type s seats Updated DEFI gauge cluster installed (Gas Gauge needs to be wired in ) NRG quick release wheel Yokohama AT tires / pro comp Mickey Thompson wheels Rubicon Fender Flares Angry Grill LED headlamps Off road bumpers XTI spare tire holder Fresh paint Custom Hood Fairly new Brakes and Suspension (less than 500 miles) Runs and drives great... videos https://www.youtube.com/watch?v=W29NdKx317Y https://www.youtube.com/watch?v=ayqVyxdVq38 CONS: There is no A/C and the heater lines will have to be installed; Additional pics can be provided upon request. **ASKING $18.500 SLIGHTLY NEG** Last edited by 7thgearRacing; 07-17-2017 at 11:56 AM.. |
10-27-2016, 01:42 PM | #4 |
Freakin speechless! GLWS not sure why the 2 big turbos tho other than totally badass! Either way well done sir!
The Sun Rises in the East! |
10-28-2016, 06:31 AM | #16 |
I was being nice but don't even get me started on the hack that put 2 hose clamps on the upper rad hose /radiation connection and the screw shoved in to what used to be the overflow tank line. The more I look the more problems I see and that makes a person wonder what other corners were cut.
10-28-2016, 11:01 AM | #20 |
At first i was like SWEET
but then i was like If less time and money was spent on the accessories and instead put into the motor/engine bay, this jeep would be a legend. like someone else said, wtf is up with the plugged overflow and the shoddy plastic panels. |
10-28-2016, 04:34 PM | #22 | |
10-28-2016, 04:36 PM | #23 |
10-28-2016, 09:55 PM | #25 |
10-28-2016, 09:56 PM | #26 |
10-30-2016, 03:45 PM | #30 |
Just a hint post current pics it will help you look honest and aid the sale. If these things are fixed you should show pics to end the criticism
