Old 08-30-2009, 10:01 AM   #1
(Yoshi)
(Yoshi) is an unknown quantity at this point
240SX ISIS Straight Through Race Exhaust Install and Review
I recently bought ISIS’s new 3in Straight Through Race Exhaust. This exhaust has no mufflers or resonators and is 3 inches straight through that splits into two 3 inch outlets at the axels. The wide open design is great for a turbo set-up and works fine for na KA.
Installation of the exhaust is unbolt, un-hang, bolt and hang. Everything went smoothly and was as straight forward as it gets. I suggest you get new rubber hangers if you are installing it on an older car because the stock ones are probably worn out and stretched causing the exhaust to hang low.
So you know, I have a header and test pipe in front of this exhaust. After I got it on, I fired it up and it is significantly louder than my previous dual n1 style exhaust. The sound is raw, loud, ridiculous, and awesome all at once. It’s loud, yet still sounds good. Driving around at low rpms it’s loud yet you can deal with it. At high rpms hell opens up as you trumpet forward. If you want and exhaust that is no-nonsense and raw, this is it!
Installation:
Tools needed:
Ratchet
17mm short and deep well sockets
17mm box end wrench
Shampoo/soap (I’ll explain in a minute)
PB Blaster
Step one: Raise and support the vehicle safely on jack stands.
Step two: For those of you replacing stock exhausts, spray down the bolts with some PB Blaster to make life easier when you start to unbolt the exhaust.
Step three: Unbolt the exhaust from the catalytic converter, or test pipe in my case.
Step four: Using soap or shampoo soap up the stock hangers to make removing them MUCH easier. There is a hanger off the back of the trans (I removed mine previously), one just before the axels, one after the diff, and two near the bumper. Remove the hangers from the rubber.
Boo Michigan rust.
Step five: Remove old exhaust.
Step six: Bolt up the first half of the exhaust.
Step seven: Soap up the hanger and slide it into the rubber support.
Step eight: Bolt up second half of the exhaust.
Step 9: Soap up the hangers and slide them into the rubber supports.
Installed:
Here is a sound clip of the exhaust from idle to about 3,000 rpms:
http://www.youtube.com/watch?v=D7G0Xqp8c1E
(Yoshi) is offline   Reply With Quote
Old 08-30-2009, 10:39 PM   #2
wiggafly808
wiggafly808's Avatar
wiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to all
Thanks for the writeup and vid, i ordered mine and will be installing in a couple of weeks as well.
wiggafly808 is offline   Reply With Quote
Old 08-30-2009, 10:58 PM   #3
peetiewonder
peetiewonder's Avatar
peetiewonder is an unknown quantity at this point
Send a message via AIM to peetiewonder
damn sounds nice. time to get my car registered in jackson,tn under my uncles name and wreak havock on california.
My Car is a Hybrid.
It Burns Gas and Rubber.
peetiewonder is offline   Reply With Quote
Old 08-30-2009, 11:17 PM   #4
bejota180sx
bejota180sx's Avatar
bejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura about
I've had mine laying around for so many months... it's about time i install it with the other dozens of upgrades my car needs...
good write up! +1 for you
Originally Posted by Taniguchi_Is_#1 View Post
...this is zilvia; prepare to get your feelings hurt.
bejota180sx is offline   Reply With Quote
Old 08-31-2009, 08:19 AM   #5
(Yoshi)
Thanks everyone!
Old 08-31-2009, 08:27 AM   #6
burninskulls0911
burninskulls0911 will become famous soon enoughburninskulls0911 will become famous soon enoughburninskulls0911 will become famous soon enoughburninskulls0911 will become famous soon enoughburninskulls0911 will become famous soon enough
sounds good
i use to have the same exhaust
burninskulls0911 is offline   Reply With Quote
