Old 05-10-2017, 11:12 PM   #1
snow hawk
snow hawk's Avatar
snow hawk is making a name for him/her selfsnow hawk is making a name for him/her self
Quest Alternator Upgrade How-To!
Delete. I don't remember the drill bit size and I don't want anyone to goof up.
NAVY
snow hawk is offline   Reply With Quote
Old 05-13-2017, 02:57 PM   #2
supersayianjim
supersayianjim's Avatar
supersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enough
is this the same as the 90's quest?
supersayianjim is offline   Reply With Quote
Old 05-13-2017, 03:01 PM   #3
snow hawk
snow hawk's Avatar
I believe the early 90's quest was a 110 amp, but I'm not sure if it's the same setup. Should be I think
NAVY
Old 05-14-2017, 10:23 PM   #4
Standard
Standard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud of
Nice write up! One thing I'll add, remember when working with manual belt tensioners to loosen the bolt that secures the accessory to the engine/bracket along with the lock nut and adjustment bolt. Shouldn't need a prybar then. Good work man!
Standard is offline   Reply With Quote
Old 05-14-2017, 10:24 PM   #5
snow hawk
snow hawk's Avatar
You're absolutely right. I couldn't get to mine (on the power steering pulley) so I skimped and used force lol.
Thanks man! Appreciate it! Hope it helps a few people!
NAVY
Old 01-06-2019, 05:31 PM   #6
dreaMervaj
Trader Rating: (18)
dreaMervaj is making his/her stupidity well-knowndreaMervaj is making his/her stupidity well-knowndreaMervaj is making his/her stupidity well-knowndreaMervaj is making his/her stupidity well-knowndreaMervaj is making his/her stupidity well-known
Feedback Score: 18 reviews
Bumping this from the dead. I've done this once before and have forgotten trim step. Does the front or rear top area need to be trimmed? If I trim the front this will screw up the threads..?
dreaMervaj is offline   Reply With Quote
Old 01-07-2019, 08:22 AM   #7
jedi03
https://forums.nicoclub.com/quest-al...t-t482959.html
http://zilvia.net/f/showthread.php?t=350045
Hope this helps!
Old 01-07-2019, 09:13 AM   #8
dreaMervaj
Trader Rating: (18)
I have a KA. I've done this before just seeking confirmation which side of the bracket I need to trim. I suppose if I trim the front and mess up the thread I could just run a nut and bolt combo to secure the top bracket.
Old 01-07-2019, 12:48 PM   #9
EnnEssEnnKAT
EnnEssEnnKAT's Avatar
EnnEssEnnKAT can only hope to improve
I installed a quest alternator on my KADE and didn't need to trim any bracket. I left the bottom mount as-is, and loosened the bracket mount that bolts to the timing cover. Then I installed the alternator and tightened back down the bracket.
The factory belt was a little too short at first, but I finagled it on and has been fine ever since. The only thing I noticed was the threaded hole at the top of the alternator was different so I drilled it out a little bigger and used a nut and bolt to tighten down the adjustment piece.
EnnEssEnnKAT is offline   Reply With Quote
Old 01-07-2019, 01:22 PM   #10
dreaMervaj
Trader Rating: (18)
I've had both model (110amp and 125amp) of the Quest/Villager alternator and the bottom bracket will fit BUT you have to enlarge the bolt holes. I'm surprised you didn't have to trim the top bracket!?!? I am going to attempt to install it without trimming here shortly. Thanks for the responses guys!
Old 01-07-2019, 05:33 PM   #11
dreaMervaj
Trader Rating: (18)
I deleted all miscellaneous things off my intake manifold so I am unsure if it'll work on a stock intake manifold. I followed Ennes's tip and just loosen my alternator bracket, and slipped the alternator in. I did not need to trim the top bracket like I did before on my first car.
Hope this helps someone in the future
Old 01-08-2019, 08:03 AM   #12
tuzzio
tuzzio's Avatar
I used a turnbuckle style tensioner from amazon and through bolted it. Made life easier
