Old 08-08-2021, 08:35 PM   #1
tjdionson
tjdionson's Avatar
tjdionson is an unknown quantity at this point
SR No power to fuel pump
1996 Nissan 240sx with sr20det swap
Issue: Fuel pump is hard wired to the battery via relay and one day all of a sudden loss power. Things I tried
1. Checked fuses
2. Fuel pump works when directly powered via battery
3. Replaced relay with new one
4. Checked my connections and inspected the signal wire (b/y wire)
5. ECU checked by Martin (Rs Enthalpy) found to be in good condition. Tested on another car and works.
Pump does not prime/turn on when car is on position. Is there another relay or something else I can check? Car has been down for several days and would love to get her back on the road. Thanks in advance!
tjdionson is offline   Reply With Quote
Old 08-09-2021, 09:20 AM   #2
crash n' burn
crash n' burn's Avatar
crash n' burn has a spectacular aura aboutcrash n' burn has a spectacular aura aboutcrash n' burn has a spectacular aura aboutcrash n' burn has a spectacular aura aboutcrash n' burn has a spectacular aura aboutcrash n' burn has a spectacular aura about
you checked the wiring on the top hat? You may have a semi-broken connection that's requiring more amperage than that relay can provide.
Show a picture of your setup.
Key'd Performance
@jz_2tone
crash n' burn is offline   Reply With Quote
Old 08-09-2021, 09:58 AM   #3
tjdionson
tjdionson's Avatar
So i actually rewired my Walbro fuel pump directly to the relay. Only connection the the top hat are the fuel gauge, low fuel light. I checked my wiring and all looks solid
Old 08-09-2021, 12:21 PM   #4
xpinoyxmk
xpinoyxmk has a spectacular aura aboutxpinoyxmk has a spectacular aura aboutxpinoyxmk has a spectacular aura aboutxpinoyxmk has a spectacular aura aboutxpinoyxmk has a spectacular aura aboutxpinoyxmk has a spectacular aura about
My fuel pump works intermittently as well. I assumed the fuel pump was just on its way out. I checked and fixed all connections without pulling the top hat off. Walbro 255, relay setup.
Almost same symptoms. Key to ON position, no fuel pump prime but if I keep trying, it'll eventually work.
If you figure out the issue, please post it here.
xpinoyxmk is offline   Reply With Quote
Old 08-09-2021, 12:27 PM   #5
tjdionson
tjdionson's Avatar
Well, at this point I think my issue might be the harness or a relay.. I think I might just end up running my pump to a toggle switch
Old 08-10-2021, 12:07 PM   #6
tjdionson
tjdionson's Avatar
Sigh, simplest issue? don?t assume all wiring is good until carefully inspected? had a broken power wire to the relay
